Question about HP 2000-2b19wm 15.6-Inch Laptop PC Winter Blue / 4GB DDR3 RAM
Corrupted bios orange wifi light white power light cap lock blinks twice with a 2 second in between
    Scholar:
  • 32 Answers
Http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5K_SE/e3202_p5k-se.pdf
Look at section 4.1.5 on pg 74
It will tell you how to reset your BIOS incase of such an event like this occurs.
You will probably need a USB drive to transfer the BIOS from there to your motherboard. It will auto-detect once in your USB slot, but if for whatever reason this didn't solve it, there is a good amount of information about BIOS on this link so you should browse around that area/table of contents and you should be able to find the answer if this didn't solve it!
Posted on Apr 18, 2014
tparsenault
  • 170 Answers
SOURCE: HP Pavilion dv4 not booting up, has blinking caps and scroll lock
Compaq and Hp are having issues with several models, My wife just got hers repaired free out of warranty. Go to copaqs website, look up your model and see if it is one they are offering free one time repairs on. Wife's computer was doing same thing, they replaced the motherboard. Took about 2 weeks round trip . Good luck
Posted on Feb 02, 2009
SOURCE: My hp laptop is not
I am too having a the same problem started 2-3 days back.. Please post the solution anyone have
Posted on Jan 18, 2011
anupam19
  • 263 Answers
SOURCE: LED blinking indicates BIOS corruption failure.
Go to your product vendor.they will resolve this
Posted on Mar 05, 2011
  • 107 Answers
SOURCE: i am opening my pc and after 2 second it went off
I imagine the orange flashing light is over the battery? The compaq laptops have a little blue light that will typically light up when it's plugged into the wall. If it is plugged in ensure that the little blue light is on. If it isnt you may have a n issue with your power supply unit, or there may be an issue with the port where the plug is plugged in. Thus causing the battery to be dead and the computer not power on. If you have any other compaq computers you can also try plugging in that power adapter, or try picking up a universal or another hp/compaq charger from somewhere such as best buy to test it out.
Posted on Mar 07, 2011
  • 1288 Answers
SOURCE: My laptop is not booting
Could be one of several possible reasons. (the most likely is not promising)
Firstly, remove the battey and try it on mains power only, if this works, the battery is so badly faulted, it is causing problems in the laptop booting.
Secondly, remove each RAM module in turn and see if it boots with one ram stick, if it does, you have a defective module
Thirdly, and with HP laptops, most likely, the blink sequence you describe is related to the graphics chip. If the laptop was getting hot before this happened, its a fair bet that the chip on this has unsolderd itself (will need reballing). Google and you'll find the V and DV series which were fitted with the Nvidia chipset, were prone to this and the result of a lot of returns to HP. If it is still under any warrantly, i'd take it back, as this problem is not fixable easily
Posted on Apr 18, 2011
I have an hp G42 notebook when i hit the power button i hear it turn on but nothing happens only the caps lock key light begins to blink
hp blink error code:
caps lock blink once: cpu error
caps lock blink twice: bios problem
etc,,,,
please, what is the numer of the blink ?
Feb 14, 2014 | Computers & Internet
Tip
Laptop LED Blink on Startup There are many reasons that a computer does not...
There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
Startup Symptom: LEDs blink but does not start
The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
DO THESE FIRST - Perform a hard reset.
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Identify the number of blinks or beeps
When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
Table of Sample Blink Codes
The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
Meaning of Sample Blink Codes for some EFI Notebooks:
1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
Error Condition: CPU not functional
3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS corruption failure
4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
Error Condition: Module error not functional
5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
Error Condition: Graphics controller not functional.
6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
Error Condition: General system board failure.
7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS authentication failure.
8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
Error Condition: Insufficient power
Common solutions for issues that cause blinking LEDs or beep tones
When the computer can boot into the BIOS, run the memory test to identify other issues.
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
on Mar 21, 2011 | Computers & Internet
What does it mean when your laptop's power lights flash ? Including the power button?
"The following table illustrates the meaning of blink codes used on some notebooks with EFI environment.
The blink or beep codes on your computer may have different meanings. When you contact HP for
support, the agent needs to know the model of your computer and may ask you about blinking LEDs
or beeping tones to help troubleshoot a startup problem.Meaning of Sample Blink Codes for some EFI Notebooks Number of Blinks or BeepsLocation of Blinking LEDsComponent Being CheckedError Condition
Continuous glowBattery power LEDBatteryThe AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
1time---Caps Lock/Num Lock-----CPU------------------CPU not functional
2time---Caps Lock/Num Lock-----BIOS----------------BIOS corruption failure
3time---Caps Lock/Num Lock-----Memory-------------Module error not functional
4time---Caps Lock/Num Lock-----Graphics--------------Graphics controller not functional
5time---Caps Lock/Num Lock-----System board----------General system board failure
6time---Caps Lock/Num Lock-----BIOS-------------------BIOS authentication failure
Continuous blinkAC power adapter LEDPower adapter Insufficient power"
Nov 01, 2012 | Compaq Computers & Internet
2 Caps Lock/Num Lock BIOS BIOS corruption failure how to solutions
Give a little more details as to what happens when you hit the power button. How do you know the Bios is corrupt?
Apr 02, 2012 | Compaq Presario CQ61-310US Laptop
I have a HP Pavilion tx 2000 tablet pc. When i turn it on the power button it shows that its on. The hard drive light does not flash and the caps lock and the number lock button keeps on blinking. My...
Hi
Boss you need to mention here in what sequence do the lights blink.
Anyways you can take help from this
Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
DO RATE MY SOLUTION
Jul 04, 2011 | Compaq Presario Notebook
The capslock and the numlock leds r flashing continously. the screen is blank
How many blinks between pauses if there are pauses? Look at this chart.
Number of Blinks or Beeps Location of Blinking LEDs Component Being Checked Error Condition Continuous glow Battery power LED Battery The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook. 1 Caps Lock/Num Lock CPU CPU not functional 2 Caps Lock/Num Lock BIOS BIOS corruption failure 3 Caps Lock/Num Lock Memory Module error not functional 4 Caps Lock/Num Lock Graphics Graphics controller not functional 5 Caps Lock/Num Lock System board General system board failure 6 Caps Lock/Num Lock BIOS BIOS authentication failure Continuous blink AC power adapter LED Power adapter Insufficient power
Jun 30, 2011 | Compaq Presario Notebook
Power light comes on but not working
First you need to determine how many blinks you are getting when you try to power on the laptop. Check the blinking codes below and reason behind that for HP Compaq laptops Blinking battery power LED Battery Insufficient charge on the battery Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional Blink: 5 - Caps Lock/Num Lock - System board General system board failure Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure You need to first Remove the memory module (RAM)- Try to power on the laptop ? then again reset it and try to power on. Check whether it is coming on or not. try the same procedure with Hard drive. If laptop is getting power on after removing one of the device then we can be sure that that particular device is faulty and we can change that then? Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
May 27, 2010 | Computers & Internet
Compaq 6735s notebook pc goes to HP screen, but wont boot
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
May 24, 2010 | HP Compaq 6735s Notebook
Hp compaq powering and nog display what do i do to
First you need to determine how many blinks you are getting when you try to power on the laptop. Check the blinking codes below and reason behind that for HP Compaq laptops Blinking battery power LED Battery Insufficient charge on the battery Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional Blink: 5 - Caps Lock/Num Lock - System board General system board failure Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure Well Check for the below link it will provide you the steps which you need to perform to isolate the cause so that we can determine which hardware of the laptop is causing this issue. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&cc=us&lc=en&dlc=en You need to first Remove the memory module (RAM)- Try to power on the laptop ? then again reset it and try to power on. Check whether it is coming on or not. try the same procedure with Hard drive. If laptop is getting power on after removing one of the device then we can be sure that that particular device is faulty and we can change that then? Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
May 21, 2010 | HP Pavilion dv6000z Notebook
My laptop does no more boot up. As soon as i start , the caps lock and the scroll lock lights keep flashing continuously and the fan even does not run.
Well hellonihar, As far as your issue is concerned it seems to be some hardware issue. LED
Component
Error Condition
Battery
CPU
CPU not functional
BIOS
Memory
Graphics
System board
BIOS
Apr 19, 2010 | HP Pavilion dv5-1000us Notebook PC
HP 2000-2b19wm 15.6-Inch Laptop PC Winter Blue / 4GB DDR3 RAM Logo
53 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
