Upper agitator just spins around loosely. Does not agitate.
Upper agitator just spins around. Does not agitate.
  • Anonymous Mar 30, 2014
    agitator spins around
    President:
  • 1,136 Answers
Hi, You will need to replace the dog kit in the top of the agitator. The part # 285770. I have them on my web site www.whirlpoolpartssurplus.com
if you need a place to order them
If I can assist you on how to change them, please let me know.
Thanks
Vic
Posted on May 20, 2009
My washing machine does not agitate, 2009 is when I purchased it.
Their is 1 of 2 things wrong causing it to not agitate..does it also not spin or just the upper portion of the agitator doesnt turn while the bottom does??
these tips i wrote will cover the 2 different things that are causing it not to agaitate depending on if it also spins or not
JUST BOTTOM OF AGITATOR TURNS BUT NOT THE UPPER BARREL.. http://www.fixya.com/support/r10294924-top_part_agatator_isnt_turning_top_load
DOES NOT AGITATE OR SPIN http://www.fixya.com/support/r10293994-whirlpool_made_washer_not_agatating
GENE
Aug 31, 2011 | Roper Washing Machines
The upper part of the agitator is loose and just spins. The main agitator turns okay
On a Whirlpool manufactured washers (such as Roper), the problem may be very simple, inexpensive and easy to repair.
Whirlpool uses a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by either worn agitator dogs, a worn agitator cam assembly, or a loose agitator bolt. The following link explains what the dogs are and how to replace them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
The part number is included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs for about $11 or $12.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you have any questions about this repair, please post back with your complete model number (located on a nameplate along the wash tub opening under the lid) and let me know. I hope this helps you.
NOTE: DO NOT overtighten the agitator bolt. This can cause damage to the plastic, or restrict the agitator movement. Tighten until snug only.
Jan 24, 2010 | Washing Machines
Kenmore washer 100.92380200 upper agitator not turning
Just fixed mine. You will need an agitator repair kit. It comes with cover seal, bolt seal ratchet pieces and thrust plate for the bottom of upper agitator. Remove fabric cup and cover underneath. Remove bolt and upper agitator. Simple fix. New parts have instructions to repair. Get the correct model number and buy it from an appliance parts place. Around $20.00 retail.
Jun 15, 2009 | Kenmore Washing Machines
Agitator seems loose and agitates during the spin cycle
HI, the actuator shift device in the transmission is malfunctioning. you will need to replace the transmission soon.
May 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Lower agitator spins, upper portion does not
The top agitator dogs are wore out and need to be replaces that is what works the top of the agitator
Mar 29, 2009 | Washing Machines
Agitator free spins
Remove the top cap on the agitator and see if the bolt has come loose. If it is not there, the agitator will come loose from the gear case shaft and free spin.
Mar 21, 2009 | Frigidaire FWS833A Top Load Washer
Agitator
The center cap of the agitator should just pop off by lifting straight up or gently prying with a flat balde screwdriver in the seam. If the upper agitator is just spinning around, then you probably have worn agitator dogs (yes, there is such a thing). The following link explains how to replace them:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
As far as the smell is concerned, even though you don't use the dispenser, moisture can still get inside from the agitation of the wash cycle. Over a period of time it can mildew. You need to remove the center cap and periodically inspect and clean it. I hope this is helpful to you.
Aug 06, 2008 | Whirlpool LSR7333 Top Load Washer
Washer fills and spins but does not agitate
Im sorry to say, it sounds like the transmission in the washer may have gone out, the unit it self sits at the bottem of the main agitator shaft under the the tub, you may be able to have this replaced, but shop around for the right price.
Jan 26, 2008 | Washing Machines
Washing Machines Logo
160 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
