I have a Samsung DVD recorder r130 and it will not recognize blank Media. I've tried a couple of different brands but it continually tries to read the blank disk and will not stop so that I can record on it. The "reading" icon stays on my screen for a few minutes then eventually stops and ejects the disc. I've done a factory reset and also cleaned the lens. The recorder has no problem playing DVD's but I'm unable to record onto a blank disc. Any suggestions would be greatly appreciated.
i have this model and the problem was the speed of disc you need itcant be any faster then 2x. the 4x is to fast for it i guess. I was doing ok with the "memorex DVD-RW reritables 2x ,4.7gb,120min.
Ok, Firstly it sounds like you have reasonable knowledge on what you're doing. But just to clarify a few things. 1.You say you have tried a couple of different brands of disc.Unless they are of good quality or compatible with your machine they may not work properly.Try TDK or Verbatim for example. Also make sure they are DVD-R or DVD-RW. 2.If no blank discs are successful,then you may need to clean the laser lens thoroughly. I know you said you cleaned the lens,but was this with a lens cleaner disc? If so it will only remove dust not built up grime from other sources such as smoke from cigarettes. This would entail taking the cover off the unit and cleaning the laser lens directly with a cotton bud dipped in cleaning fluid.If you are not confident in doing this,then you would need to get someone qualified to do so! I have gotten many DVD Players and DVD Recorders working again doing this.
Was this helpful?
Yes
No
Popular Solutions for Samsung DVD-R130 DVD Recorder
My dvd-r130 display shows nodisk when I close the bay door. What is the problem? Is it the optical...
(More)
My dvd-r130 display shows nodisk when I close the bay door. What is the problem? Is it the optical piece that reads the disk or is it something on the circuit board, or something else. Can you help me? Thanks. Mark
No longer able to read rewritable discs DVD -RW
Have tried different brands
Player will play pre...
(More)
Player will play pre recorded discs and discs which have been burnt on PC
I think I've followed all the instructions, but: when I record a DVD it will only play on this unit....
(More)
I think I've followed all the instructions, but: when I record a DVD it will only play on this unit. I put the same disc in my upstairs (Toshiba) player and it does not play. Yes...I do finalize the disc. I'm using TDK DVD-R discs.
