Question about Compaq Hp - 375376-001 - Dc7600 Tower System Board 375376-001
My computer reset itself and has a password but i do not know what it is
I have tried o access my computer after it reset itself and now i can't open windows as i do not have the password could you please help me
Password unknown
FYI, I know this is an old posting but you don't have to go to Dell Tech Support for password reset, just reset the CMOS password jumpers inside the computer. Not a difficult task at all, refer to the owner's manual for details on opening the computer, and for resetting the jumpers. Very easy solution, did it myself. Hope this helps.
Apr 04, 2014 | Dell Inspiron 530s Desktop Computer...
I can't find my WEP Key for the SB5101N Router. I tried the numbers located on the router itself, none of them have worked.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Sep 14, 2011 | Arris SURFboard® SB5101 Cable Modem
My router reset itself and now is unsecure
You need to enable WEP security on router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Jun 14, 2011 | D-Link DIR-615 Wireless Router
Hi am having prob on setting my WI-FI i forgot the WI-FI/WPA Key
May 05, 2011 | Computers & Internet
Hello Need to secure this router but don't know password
hello
if you dont know tghe password you have to reset the password to its factory setting and that way the password gone also, at the back of the router there is small button for reset press that one and it will reset.
thanks
Mar 08, 2011 | Linksys Wireless-G WRT54G Router
How to unlock my computer i forgot my password
I don't know which operational system your computer installed with.
For different Windows OS, there are suitable ways to unlock the computer. Or what preparation you make for before your computer locked.
For example, you can access Windows XP in safe mode. Unlock computer in safe mode is effective way.
If you have a password reset disk, reset windows 7 with boot disk is another choice.
So how to unlock computer or laptop based on the Windows operational system and what you have.
More details, you can refer to:
http://www.isunshare.com/windows-password/unlock-laptop-when-forgot-password.html
Dec 26, 2010 | Compaq Computers & Internet
How to open asus wifi router home page?
In order to access the web interface of the router you should know the IP address of the router. Please try the following steps to check the ip address on the computer which is connected with the router (wired/wireless doesn’t matter).
1. Click on start the go to run and try cmd and click on ok.
2. Type ipconfig and press enter.
3. look for the default gateway numbers.
the default gateway is the address of the router. Open internet explorer and type http://default gateway numbers (for example http://192.168.1.1)
It should take you to the web interface of the router on which authentication is needed. The default user name and password is admin and admin.
Let me know if it help.
Rashish
Aug 09, 2010 | ASUS WIRELESS ROUTER |WL-520G - RT...
I can not access the router on 192.168.1.1
connect your router to computer with ethernet cable.
Then you can access it with following link.
for belkin routers http://192.168.15.1
for other routers
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
IF you are still not able to access then press RESET button for 10 seconds it is in back panel of router.
Nov 20, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Will not let me into router. only have an option for password and nothing works. tried resetting to default and it still doesnt work
are you trying to access the router set up ?
First make sure that your computer will be connected to the router with the ethernet cable.
Now check the IP address and Default gateway on the computer. Default gateway will be the IP address of the router.
When you try to access the router it will always ask you for the password.
Try the default user name = admin and password = admin
or try user name = blank ( do not type anything), password = admin.
if that is not working then the password of the router must be changed.
try some different password that you use most often.
If that doesn't work then you will need to reset the router and reconfigure the router.
once you reset the router , you will loose all the settings on the router.
Reset the router for 30 seconds. unplug the power. plug it back in. wait for 1 minute and try to open the page again.
Click Here to know more about how to reconfigure the router
Nov 17, 2009 | D-Link GamerLounge DGL-4300 Router...
Compaq Hp - 375376-001 - Dc7600 Tower System Board 375376-001 Logo
Top Compaq Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Tom Chichester
Are you a Compaq Audio Player and Recorder Expert? Answer questions, earn points and help others
