Question about LG RHT498H Digital Video Recorder
I want to know how to gain accesss to the disc drive spindle to give it a claen,, as it appears that may be why its not reading / functioning correctly
I what to know how to get sight of spindle in easiest fashion to clean with alcohol
    Sergeant:
  • 376 Answers
Using alcohol will wash away the lubricate that makes the spindle turn properly. If you use alcohol, please remember to re-lube bearing after cleaning and drying.
Posted on Jul 06, 2014
Dvr cd drive won't play cds get message asking to insert a disc when one is already inserted
Your cd drive is damage, the laser head or the spindle is not functioning and is not reading the disc thus causing the message of no cd being insert to appear, however the cd-drive power is still working which the computer is able to still detect, but like I said earlier the spindle/laser head is malfuction. You will need to replace the entire cd rom drive. If you don't know how to replace it, an external cd/dvd drive will also do the job.
Jan 30, 2011 | Dell Inspiron 531s Desktop Computer
The disc has appeared to stop rotating. The info window continously says "reading".
DVD/CD Read/Write process: 1. The tray or carriage places the disc into the spindle or motor. 2. The spindle motor locks into place to prepare motor to spin - the disc is in free space and does not touch anything except the spindle motor. 3. The laser assembly moves into home position and attempts to focus on the disc by emitting infrared light to disc. 4. If a disc is present, the light should reflect back to the laser lens as the lens attempts to focus on the light - you will notice the lens moving up and down to focus. The lens should NOT touch anything. 5. Upon a successful focus, the spindle motor spins. 6. Data is read and sent to a buffer for decoding. 7. Success.
Dec 27, 2010 | Yamaha DVX-S120 System
The eject function is not working, the yellow led is blinking, as if the machin was reding a disk, but it never opens. I tried also to open it using the screen option but it does the same thing, the lead...
Take it apart and see if the laser is moving up and down (focusing). If not, then the laser focus servo is bad. After it focuses, the spindle motor should turn and the disc should spin. Remove the spindle lock from the top of the drive case and before it spins quickly place the lock on the disc before it spins to hold the disc in place. If all these processes occur and it still doesn't read, check the lens to see if it's dirty or foggy - clean the lens with "Q" tip and alcohol. if this doesn't work, remove the disk and see if a red beam shines through the lens - if no beam, the laser is bad.
Nov 01, 2010 | LG (GCR8525BK) Internal 52x CD-ROM Drive
My bluray player is a sony have owned it for 2 years but have primarily only played dvd's on it and have had no problems with it working on all types of discs. However recently I purchsed some bluray discs...
Lens cleaner disk works but it is a cd, which does not heat up a bluRay circuit. DVD too does not heat up the circuit. BluRay disks are denser in data(30gB) and runs closer to the lens, so reading disks is more critical. And some movies may heat up the circuit to freeze the functions. Maybe a moisture problem, keep it power on to drive off moisture on the semiconductor ICs.until bluRay disks work.
Oct 28, 2010 | Televison & Video
Playstation 3 wont read disc can someone help it doesnt read disc at all we have cleaned the disc and nothing is working, someone said the bd drive could be bad if so how do we fix as this is out of...
This could be caused by 2 things
1) The laser is dirty,and needs to be cleaned or
2) more than likely the laser has failed and needs to be replaced
Other than that check the spindle motor by putting a cd in the slot and feel the shell for small vibrations,if you can feel it the spindle motor is fine
If this helps,please give me positive feedback
Jul 08, 2009 | Sony Playstation 3 (PS3) Console
I put a brand new game and i wont play i says disc read error
If your other games still work, take the new one back to the store you purchased it from. If your other games are giving you problems then you probably have a laser problem. If you can hear the disc spin, you generally just need to clean the laser lens within the drive. If the disc doesn't even spin, you either have a completely dead laser unit, or a bad spindle motor. Lets just hope it's the laser unit, they only cost like 50 bucks, I don't even know where you could get a new spindle motor. Best of luck
Jul 28, 2008 | Video Game Consoles & Games
Error message: The disc could not be read
whoeve post this comment is very stupid!! people are asking for a diferent solution ..and u tellin them somehtign they already know //whtathe f u ck !! stupid *** ..
May 29, 2008 | Sony PlayStation Portable (PSP) Console
Won't format and or won't read disc
I have a similar problem in that it will not record at all or not record very well.  It has a drive inside like a PC DVD drive called the DVD RAM drive. The horrible clunking (grinding) sound is the disc slipping in the spindle. Unfortunately here in Australia the fix is to replace the whole drive (AU$350)!!
I have opened it up and tried to adjust the force of the spindle and it works for a while.
Hope somebody has a better solution.
Dec 03, 2007 | Panasonic DMR-ES10 DVD Recorder
LG RHT498H Digital Video Recorder Logo
44 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
