Question about Thomson RCA DCM 226 (DCM226) Modem
Need power plug info
Help........... I lost my power supply for my old but reliable RCA DCM215 cable modem.I cant seem to find any info anymore on the voltages for the 4-pin plug.I recall it had 2 different voltages and a ground for each. Id like to make my own P/S but i need the pin info.. Perhaps somebody with a DCM215 and P/S???I believe it mightve had info on the P/S itself......cant recall though 4 sure.... thanx kookykev
    New Friend:
check out this ebay might help
good luck...Ascott51
Posted on Jun 30, 2017
I see that people are asking about driverss for the RCA dcm425 cable modem. I just bought a new computer, and I connected it to the my old dcm425 modem through a router and it works just fine. I didn't...
The trick about all this is that the software does not configure the computer, but the modem.
So once it has been configured through a computer then plugged to a router, any computer plugged to the said router will have access to the Internet.
The whole process of installing/configuring will happen if you replace the old modem and/or plug a new computer directly to the modem.
Cable modem 315
Have a look at the link below for basic troubleshooting techniques for RCA modem
Troubleshooting DCM 315
Oct 13, 2008 | Computers & Internet
Cant get conected
Can you clarify the problem? I have the same modem. make sure that the coax cable is connected to your wall and that the ethernet cable is going from your modem to your router or computer. If all else fails pull the power chord out of the back (thin black chord) and wait 30 seconds or so, and plug it back in. This will reset your modem.
I accidentally knocked the AC adapter to my RCA DCM425 Cable Modem AC out of the wall outlet while at my computer desk. After plugging it back in, the lights on the modem flashed on momentarily, then shut...
You could have only a damaged power supply, please look in an Eectronics parts store another with the same characteristics (input and output voltage,current, plug type) and retest, maybe your actual AC adaptor is broken inside and that's why it doesn't power up your modem correctly.
When trying to play online either custom match or with a friend I recieve a network error message cant even get through a quarter.
if you are talking about the problematic black ops i heard deleting unnecessary friends helps because black ops tries to keep so much info about every person that it has trouble with connection (sorry i can't quote the site i heard this from off the top of my head but it seemed reliable enough)
Jan 15, 2011 | Video Game Consoles & Games
I lost the disk for the RCA DCM425 digital cable modem the cable company gave me. how can i get the modem to work on my new computer?
Hello Friend,
If you didn't change anything in modem side, that means the modem is still connected to internet. in this case you can connect the modem to your computer via the Ethernet cable. with this cable you will not need to install anything on your computer, just plug the Ethernet cable to the RJ45 port and start browsing internet.
The only case when you will need the drivers is when you want to connect the modem to your PC via USB cable.
Here is a link where you can find everything about your modem: quick guide, user manual, usb drivers ...
Best Regards,
Conect the router?
1. Unplug your DSL modem’s power supply.
Find the cable connecting your modem and computer.
Unplug it from the modem and plug it into the gray port
on the Belkin Router.
If you are replacing an existing router, find the cable
connecting the computer and old router. Disconnect it from
the old router and plug it into the gray port on the new router.
2. Connect the new cable (provided in the box) to the yellow
port on the Router.
Plug the other end into the modem.
3. Plug in your modem’s power supply. Wait 60 seconds for the
modem to start up.
Plug the Router’s power supply into a wall outlet, and the
other end into the black port on the Belkin Router.
As the Router wakes up, lights will come on; recheck your
connections if the “power” and one of the “wired” lights
are not lit up in green after 20 seconds.
4. Locate the CD in this guide and insert it into your computer.
The Setup Assistant should appear automatically.
If it doesn’t, open the CD in My Computer and double-click on the
“Setup Assistant” icon.It will guide you through he rest of the setup.
If you need more help please post back,If this help please rate as a fixya.
May 17, 2009 | Belkin (F5D72304F5D7000) Router
Frequency change
I figured out that with the RCA modems, if you pull them off the network ( disconnect the cable) , do a system reset (push the button on the back) for 45 seconds it goes into (what I call night rider mode) with the lights. After it is done with that it will give a class C address to the PC plugged into it. You can plug the gateway address into a browser and get into a configuration mode. There may be a place to reset the freq. not sure though. Sometimes you have to do it a few times to get it into this mode... once you lock in a configuration change I have never been able to get back into it without doing an other reset. Give it a try.
Oct 01, 2007 | RCA Cable Modem DCM315R (11603540)
RCA DCW615R WIRELESS Cable Gateway , Factroy Installed Firmware needed.
I had the same issue with my RCA DCW615R. First time my ISP Comcast flashed it back to the old version. This time I could not find anyone who new how to do that. I used to have the software and I have searched the net. Seems they provider RCA does not have it.
This time I called Comcast because I noticed that the brought me to their software update. They supplied me with the user name and password. I was able to get into the firmware and change all the settings using the new firmware. I think the only reason they gave it to me is because my printer is a network printer and it would not work unless I could access the firmware.
The old does not work anymore because that was Cable Modem mode or CM mode. The new address does work but you will need the user name and password from your ISP, this is RG mode or residential gateway mode.
Liked the old firmware better but they both do the same thing. Seems the Gateway works better with the new update. Still I would like to find the old firmware not sure why RCA doesn’t have it.
Feb 11, 2007 | RCA DCW615R Wireless/Cable Modem
Thomson RCA DCM 226 (DCM226) Modem Logo
69 people viewed this question
Top Thomson Computers & Internet Experts
jimmy Leo
Raj Patel
Are you a Thomson Computer and Internet Expert? Answer questions, earn points and help others
