Question about Fisher and Paykel GWL11 Top Load Washer
My maytag washer has a burning smell.
I just bought this washer from a friend and he said that he had no problems with it but when I got home and hooked it up and tried to do a load of laundry, half way through I noticed a burning smell so I checked it out and I didnt see anything but after the washer was done, I went in to put the clothes into the dryer and noticed that they were dripping wet. What could the problem be? Please help!!!
  • 868 Answers
What model do you have.?It doesn't sound like it was spinning.A frozen pump would make the belt burn and it would leave some water in the tub .
Posted on May 26, 2008
  • Archie Ferrarini
    Archie Ferrarini May 26, 2008
    This washer if it is around 3-8 years old most likely isn't spinning at all.The brake is probably locking up and if you need more help I'm available & happy to assist you.
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Washer has a burning smell and will not drain
the burning you smell is probably your belt. if you change the belt and it still has this problem then your transmition has failed. This is a very comon problem with maytag washers.
Apr 24, 2010 | Maytag PAV2300 Top Load Washer
Maytag Neptune MAH5500BWW burn smell (doesn't appear to be hose)
if you have a maytag neptune washer that ran up until now you got your money's worth,that's the machine that put maytag out of business,if it's smoking and ripping the boot it sounds like the tub bearing is gone and you'll have to replace the washer,if it's load in the spin like marbles are rolling around in it that's the problem,but i wouldn't put a cent into that machine.
Oct 06, 2017 | Maytag Washing Machines
Washer not spining burn smell
belt burrt out advise new belt or new machine
Jul 12, 2009 | Maytag LAT3600A Top Load Washer
Maytag Washer whines during rinse belts burn
that friend is about the best possibility I can think of. This site has all your parts for the washer you have
Mar 21, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag washer stop spining and smell burned
two main things pump and motor pulley.the motor pulley on admiral designed maytags is plastic and melts and causes belt to burn.also pump pulley spot welds break causing pulley to drag.tip machine so rests on wall in back and you can inspect from there.hope that helps God bless ,tom
Jan 04, 2009 | Maytag Washing Machines
Maytag Legacy top load washer is SMOKING!
this is a bogus website that is trying to push smelly washer real fixes and there are other products out there for less just use bleach first
May 05, 2008 | Maytag Legacy Series Top Load Washer
Burning smell/noise with my Maytag Ensignia MAV7657EWQ Washer
it could be [motor] or 'condensur' for motor, starting to burn out or over heat, check drive belt as well for ware
Dec 08, 2007 | Maytag Ensignia 3.3 cu. ft. Top Load...
Fisher and Paykel GWL11 Top Load Washer Logo
112 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
