Question about Dell Latitude CPX Notebook
Turn it on the battery light comes on red.
When I put a fulley charged battery or just the a/c adpater.The battery light comes on bright red.The laptop will boot and run.But the light is red. Any help.
  • 3 more comments
  • Anonymous May 20, 2009
    The battery is fully charged,Take the battery out use the a/c adpater same thing.Battery light bright red.
  • dewyshd6116 May 28, 2009
    It will run with full charged battery and take it out and use the a/c adapter same thing.Battery light is bright RED!
    The system runs with battery or a/c adapter.The battery houlds a charge about a hour and half.The battery light stays red.
  • Frank Zhang
    Frank Zhang May 11, 2010
    your " use the a/c adapter same thing.Battery light is bright RED!" is not clear about can you turn on screen on boot showing?
  • Frank Zhang
    is it a fully charged battery? ever red light?
  • 3,940 Answers
Does the system run using the battery only? If the answer is no, or if the battery lasts only a few minutes, then the indicator is saying the battery is dead and needs to be replaced.
Posted on May 28, 2009
New bright 12.8v charger the red light won't come on at all don't know if the battery is charging.
Try with other battery since a bogus battery often will not charge, hence no light.
Dec 24, 2016 | Cameras
N7o display fails with full charge during monsoon
disconnect the adapate +battery HOLD the power button by 30 secons aprox, by eliminated ESD. connect again the adpater and battery. and see what happen.
if the problem persist only connect the adpater, and see if the display is working. if is working try putting the battery , if failed the battery is faulty.
However if the computer doesnot turn on the display with only the adapter the ribbon cable display+gum conducter is failed, repair.
God bless you
Jun 23, 2013 | Computers & Internet
Power light is red , does not charge battery, battery light flashes red
The onboard connectors that your battery connect to on the motherboard no longer work that is your battery is not charging.
Dec 04, 2012 | Gateway LT Series Intel Atom N570 1.66GHz...
Charging 2006 trailblazer, dvd started working
The charger puts out about 14 volts, The battery is 12.6 fulley charged. If battery is bad or dirty battery cables the voltage will be to low
Dec 31, 2011 | Panasonic Televison & Video
Hi, I just bought your product SYMA s107. I took it out of it's box and I started flying it. At first it was flying great but after a couple of minutes it started to not even lift of the ground. I charged...
you should have charged your heli BEFORE 1st flight.......anyway,,plug computer end of usb charge
cord into computer......turn heli OFF....before you plug cord into heli look at computer end of cord,,
should be bright red light inside......now plug other end of cord into heli.....bright red light goes out!
when heli is fully charged bright light on computer end of cord comes back on......disconnect
heli right away.....if left on charge your battery could wear out....it takes about 50-60 minutes
Feb 25, 2011 | SYMA Toys industrial New Syma S107 Radio...
My new 18v lithium batteries run out of charge after about 10 mins of continuous use is this about roght as my old Nicad batteries would go for about 20 mins this is using them with a drill driver with a...
This is not right. They should last much longer then that. I have one of the more expensive 18V lithium batteries (the one with the button on it that tells you if it needs charging or not) and I can use mine almost all day before it needs to be recharged. I do construction work and I use my Ryobi products almost all day. Either both batteries are bad (I don't believe that is the case) or the charger is not charging them all the way to a full charge. With this charger, you do need to make sure that you remove the batteries as soon as the green light comes on. It is not good on these batteries to stay charging after they are fully charged. You also should not leave the charger plugged in without any batteries charging.Please tell me more about the charger. When you plug in the charger, does the red light come on? When you plug in a battery, does the red light stay bright and the green light blink? Does the red light go off and the green light stay on bright when you remove it from the charger?
If the charger is not working correctly, then return it for a new one.
Nov 26, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
My 8230 phone will not turn on put battery in and
A red light on a blackberry means the battery is flat. (Requires re-charging)
If you are confident your battery is FULLY charged and your charger is working then you may need to take your handset to a repair shop.
Try charging up the battery whilst in the handset. Let it charge for 30 mins then try and switch it on.
Remember...Blackberry handsets take longer than most to start up.
Jul 05, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
Camera wont charge. when camera placed on cradle, the red charge light comes on for about 5 seconds, then starts to flash.the camera does not seem to have any power to it at all.Any ideas????
well have you made sure that the wire is fulley connected to the cradle? if it isnt, push hard and connect it back in. if it doesnt work, I have no idea sorry lol =)
Oct 10, 2009 | Casio EXILIM Card EX-S770 Digital Camera
My ds will no longer charge . the orange light comes on for a second then goes out . ive tried the battery in another ds and it works fine ive also put a good battery in it but have the same problem any...
Try another ac adapter for your DS, if the battery charges then you know its a faulty ac adpater thats the culprit, if the battery doesn't charge with another ac adpater then that means the main board inside of the DS is bad and at that point if your system is not under warranty then you would need to replace the system.
Aug 08, 2009 | Nintendo Video Game Consoles & Games
Jabra BT150 No power
Make sure the charger is in right. If you put it on wrong you will get a faint blue light, when it is in right you will get a BRIGHT BLUE LIGHT. It WILL NOT charge if it is in wrong.
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT150/Documents/User%20manual/BT150_UM_NA_EN_496.pdf
Link for manual
Mar 22, 2007 | Jabra BT150 Wireless Headset
Dell Latitude CPX Notebook Logo
472 people viewed this question
Alun Cox
