Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Lamp indicator is red?
When i turn it on there will be no picture then the light blinks red. Does it need a new lamp? or something else? I have had it since new 2 years ago.
  • cliff74 Mar 09, 2008
    I have a 32'' go video flatscreen t.v. I cannot get it to turn on. It will come on, but goes right back off after about 20 seconds. I've had it about 4 months. Can you help?
    Problem Solver:
  • 5 Answers
The blub burned out and its 300 to get replaced. I just had mine replaced and the mirror cleaning and the screen cleaned but I still blotches all over the screen but I was brighter. In my case its the might engine, which is 2000 worth more then the tv. Now I was told that the engine could be cleaned but it would not be perfect.
He looked at me the tech and said, your getting a new tv. I would suggested a flatpanel lcd. He said he never gets calls on those.
good luck. Jason N
Phoenix, Arizona
Posted on Oct 19, 2007
Does a lamp error message (6 blinking red status lights) mean the lamp needs to be replaced? or could something else be wrong.
According to NEC technical support, if the status light flashes red six times, this could indicate a defective lamp. If a new lamp is installed and the project still won't turn on, the projector will need service.
Jun 15, 2011 | NEC NP400 Projector
Sony kdf e50 a60 when TV is turned on picture goes off almost immedately and red light starts blinking in stand by mode.
Red light blinking is an indication of lamp problem. Check and secure tightly the following:
  1. Outside lamp cover
  2. Lamp door
  3. Lamp
If all of the above does not solve the problem, you need to replace the lamp. Let the lamp to cool for 30 minutes after unplugging. Use XL-2400 replacement lamp.
  1. Remove the outside lamp cover.
  2. Remove the lamp door.
  3. Pullout the lamp
  4. Hook a finger through the loop of the lamp handle and pull the handle upwards. Then pull the lamp straight out.
  5. Mount the new lamp securely.
  6. Reattach the lamp door. Turn the knob back to "CLOSE" and secure the cover.
  7. Put the outside lamp cover back in its place.
or visit
Aug 11, 2009 | Televison & Video
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
May 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Replaced lamp and still no picture.
Does the red indicator flash or blink? How many times it blinks is a error code that tells a liitle about what is wrong. For instance, 3 red blinks means the air filter for the cooling fan is restricted and needs to be cleaned.
This model has lots of complaints against it, get it working and then put it under an extended warranty.
Hope Ya Fix it!
Jan 07, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Lamp indicator blinks red
There is a problem with the lamp or around it? When it turns Orange, the lamp is at or near the end of it's life & needs replacing. What does the temperature indicator show? Orange, Red or Red Flashing? If not, then there is probably accumulated dust around lamp area
Dec 24, 2007 | Zenith E44W46LCD 44" Rear Projection...
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Won't piwer on
Tried to turn it on? Sounds like you need to replace the lamp. However, I got an additional week out of my unit. Although poorly dimmed and the red Lamp light blinked constantly for that one week, at least it gave me enough warning to seek out a replacement. But so long as you're not mistaking the Power/Standby or Timer light for the Lamp light then I would have to agree with you. Includes shipping to the United States and no sales tax outside of California.
Aug 16, 2007 | Sony XL-2100U Projector Lamp for...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
51 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
