Question about Motorola Mobility H710 Bluetooth Headset
Tunnel sound Just bought the earpiece less than two weeks ago. No problem until today. The person I call says it sounds like I am in a tunnel and I am not very loud.
Hoover 30600 max wind tunnel less than a year old makes a whistling noise
Ours did too. I bought a Dyson.
Check for gaps in the hoses and in the wind tunnel canister. Something is not sealing properly.
Nov 11, 2016 | Hoover Vacuums
Picture is going dark to bright and making a clicking noise
Hi, sounds like you`ll need that tech again, your description sounds like a bad color wheel, if you let it continue and it shatters it can & probably will destroy your light tunnell, sorry for the bad news but now you know not to keep running the set, this is a very common problem with dlp`s and it`s exactly why we tell our customers not to purchase dlp`s, gl, video-tek
May 29, 2009 | Televison & Video
New Problem after fixing Light Tunnel on a SP 4805
It sounds like you have mounted the replacement light tunnel incorrectly. It is a common error. What has happened is you have the light tunnel sitting on yop of the positioning stop which is opposite from the color wheel side. If you take it back apart you will see that it's not laying parallel to the casting. if you reposition it so it is just touching where the opening is in the clamp on the color wheel side you will feel it fall into place.
Jan 22, 2009 | InFocus ScreenPlay 4805 Multimedia...
No suction on Hoover Wind Tunnel.
Greetings from GoVacuum.com,
First this is a common problem on ALL bagless vacuum cleaners. Usually it takes longer then 1 day however.
Is there no suction in the suction hose, or is it not suctioning from the floor?
Most people buy a bagless vacuum once, then return to a bagged one after their bad experience, you are not alone!
Please give me the model number to your Hoover, (found on the bottom or the back of the vacuum on a foil label).
Thanks,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Aug 18, 2008 | Vacuums
Wind tunnel supreme sounds very loud
Sounds like a bad motor, you have a years warranty on this, take it in for warranty repair. You will void the warranty if you mess with it.
May 08, 2008 | Vacuums
How much does a light tunnel repair cost?
Hi there
The light tunnel is not a expensive part to have replaced and it is better to do it than to keep on buying new lamps.
You can easily find your nearest Authorised Service Dept online.
Tip : Don't let just any monkey do this type of work on your unit , rather pay a bit more with the authorised agents.
Mar 25, 2008 | InFocus ScreenPlay 4805 Multimedia...
Shadow on left side of image--light tunnel problem?
Hi there
Yes the light tunnel has four tiny mirrors facing each other. If you know what you're looking at you can easily glue it back.
Otherwise you'll have to get it replaced by a repairer.
Mar 21, 2008 | Sharp XR-10X Multimedia Projector
something mite be lose in the motor take to the nearest hoove repair store and have them check the motor
Feb 24, 2008 | Hoover U5450-900 Windtunnel Supreme Bagged...
Infocus x3 video problem
Sounds like it could be the mirror tunnel. There is a very small mirror tunnel behind the color wheel (looks like a long prism) that can often fail as it is very fragile. This tunnel concentrates and channels the light to the DLP chip and if it collapses it can cause the very issue you describe.
Feb 18, 2008 | InFocus X1 Multimedia Projector
Motorola Mobility H710 Bluetooth Headset Logo
125 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
