Question about Car Audio & Video
No sound from radio
I replaced the radio in my madza with another factory radio, It has power but no sound
  • 88 Answers
If it has the anti-theft device, then you need the code to unlock the radio. Just take it to the madza dealership to have it unlocked, they should'nt charge you.
Posted on May 20, 2009
Hogar - No sound from Boss Radio after initial installation test.
If you are hooked up to the factory wiring harness i would think there may be a factory amplifier that is not getting power or is bad.
Test the stereo by hooking a speaker up to the speaker out wires from head unit. if it has sound try to find out if there is a factory amplifier.
Good Luck
May 24, 2016 | Cars & Trucks
How do i fix the problem i have power but no sound sterio comes on but there is no sound
depends if there is a internal amplifier int this vehicle some model cars have just a radio some have a radio with built in amp usually in the dash or located in the trunk check your model to see.could be something as easy as a bad fuse or a bad wire to the amp if no amp then your radio is junk you could either replace it with another factory radio or install an aftermarket radio that will not only be cheaper but also perform better as most factory radios are poorly made .hope this helps good luck
Nov 22, 2014 | 2010 Ford Escape XLT
Installed after market radio in my 2002 buick rendevous i get power to the radio but no sound
Why you buy a harness that is factory matched from Best Buy. Could be the speakers were power amped from the factory stereo and the after market is not powering them. Would call Best Buy to confirm it.
Jun 18, 2014 | Car Audio & Video
No volume from factory radio after replacing a dying battery.
Is their any other problems that showed up after the battery change ?
Feb 10, 2014 | Cars & Trucks
Bmw 540I Problems
If the radio lights up then there must be power coming through. I very much doubt that it is fuse related- it sounds to me like a problem with the radio itself.
Nov 11, 2013 | Cars & Trucks
2003 madza tribute radio goes off when stop at red light and come back on when i go again
NOT WIRED CORRECTLY OR SHORTING OUT SOUNDS LIKE SOMEONE WIRED RADIO THROUGH BRAKE SWITCH CIRCUIT
Jun 30, 2013 | Mazda Cars & Trucks
I GOT A 2002 MADZA TRIBUTE THERE A A LIGHT ON THE DASH BOARD THE SHAPE OF A HOUSE i DON'T KNOW WHAT ITS MEAN
I think the warning light is meant to be in the shape of a radiator - check your coolant level - it generally means your coolant is low. The coolant level sensor often fails on Mazda's however, so your 'problem' might actually be a dodgy sensor not a lack of coolant at all.
Hope this helps, Sherwin
Sep 06, 2010 | 2002 Mazda Tribute
Factory radio with no sound
one of the positive power wires to the speakers is shorting out.alot of times it's the door speaker wires.
Mar 08, 2009 | 2001 Pontiac Grand Am SE
How do I remove the radio?
YOU DONT HAVE TO REMOVE THE RADIO TO CHECK THE SPEAKERS. I JUST HAD NEW SPEAKERS PUT IN AND HE JUST CUT THE WIRES FROM THE FACTORY SPEAKERS AND REPLACE THEM.THE FACTORY SPEAKERS CONNECTION IS MADE DIFFERENT THAN THE REPLACMENT SPEAKERS
Dec 27, 2008 | 1997 Kia Sportage
Car radio replacement
Does the radio power up but give no sound? If this is the case, you need to make sure the factory amplifier is first turned on. the aftermarket radio should have a remote turn on lead for amps. The Dodge caravans sometimes have Infinity sound systems in them and there may be a green wire with a red stripe in the factory side of the radio plug. This should be amp trigger. 12volts to this wire should give sound. If at all unsure, please consult a local stereo shop.
Aug 13, 2008 | Elliott's Car Radio Ford-COSF-18808-E Car...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
