Question about Tom Ford Clothing Accessories
Bend in my glass
When i wear my glass it is bend towards the right side, which makes it little annoying to wear.
2 Suggested Answers
emissionwiz
  • 76109 Answers
SOURCE: driver side front seat back bends
The seat back frame is broken, in most cases it can be welded but all the trim must be removed and the seat dis-assembled down to just the frame, any upholstery shop can do this job for u, about $100-200
Posted on Dec 03, 2008
Bernina virtuosa 155 solutions
Needle threader heads are actually easily replaced and should be replaced anyway every few years because they do wear-out. Get a magnifying glass and, having returned the needle to the top (use the foot controller, so that the machine stops it in the right place), pull the needle threader down until the head rotates towards the needle. Look with the magnifying glass to see if the small hooked part in the centre of the threader head (the light grey plastic part) goes through the eye of the needle - if not, you might be able to bend it VERY carefully so that it does - that should cure it. If the hook is a long way above or below the needle eye, dont try and bend it, the cam that rotates the threader has probably moved on the needle bar and will need adjustment by a service agent. If the hook is passing through the eye of the needle OK, but still not pulling the thread back through when you release it - i.e. the thread is just slipping-off, the hook has become rounded through normal wear and you'll have to replace the threader head. The threader head simply pulls off - you might need to carefully lever it off the round shaft. Replacing it is a matter of simply putting the new one on the shaft and pressing upwards firmly so that the grooves in the threader head go right up to the horizontal pin on the threader shaft.
Dec 12, 2011 | Bernina Virtuosa 160
I have a 2007 Town and County. The rear wiper is not touching window by about 1/4 inch. I can press it back down but it will not stay once you turn on the wiper. How can I fix this problem?
If it is not touching the glass the arm is bent. Raise the arm away from the glass. Grasp the arm near where it is mounted to the body and near the wiper blade with the other hand. Slightly bend the arm toward the glass. Only bend the arm a very slight amount and check to see if there is enough pressure for the wiper blade to work correctly. Repeat this until the wiper blade cleans the glass properly. DO NOT over bend the wiper arm as too much pressure will cause the blade to wear out very quickly.
Dec 22, 2010 | 2006 Chrysler Town & Country
Lock my keys inside my 1994 corolla. Can I use a slim jim to open the door?
  1. yes you can
  2. it is easier to use a coat hanger
  3. on the pass side use a large screwdriver with a rag over the tip to pry the top edge of the door open slightly
  4. straighten then bend a 3/4 inch right angle on one end.
  5. insert the hanger from the top of door frame towards lock button.
  6. you may have to remove and rebend the hanger to a shape that will allow you to reach the button.
  7. wedge the back of the hanger against the glass pushing the tip of the right angle into the side of the button
  8. while twisting the hanger against the glass lift up
  9. repeat if neccessary
Sep 07, 2010 | 1994 Toyota Corolla
My rear wiper does not touch the glass on my 04 4runner. How do I tighten or make it touch glass?
It has obviously been bent. Put the wiper arm in the correct "off" position and observe any space between the blade and the glass. Next pull the arm out so that it is away from the glass. Using two sets of plyers or vise grips place one on the flat shaft next to the mount. Place the other about one inch away and bend the arm toward the glass. NOTE A small bend will make a lot of difference so bend very little, release both tool replace the arm in the standard position and check to see if yoy have bent the arm enough. If not repeat until it works properly. DO NOT bend it so that the pressure is more than you need or your wiper blade will wear out very quickly.
Jan 11, 2010 | 2004 Toyota 4Runner
2000 ford explorer the rear windshield wiper moves but doesn't touch the glass.
The arm on the rear wiper is common to seize up where it pivots on the rivet. spray some penetrating lube like Liquid Wrench on it and work it free by pulling it toward you and pushing it toward the glass/window. you may have to bend the arm a little so it has more pressure on the blade against the window. Replacing the arm is always an option if it wont free up enough.
Dec 31, 2009 | 2000 Ford Explorer
I wear glasses. I can't see through binoculars with glasses on or off.
This is more common than you would think.. Here's how to set up a pair of binoculars to suit yourself.
Any good binocular will be able to do this and the reason is to allow you to adjust them for the difference in strenght between your two eyes. I wear glasses myself and sometimes contact lenses so it's good to be able to quickly adjust them.
1. turn the binoculars over so you are looking at the underside.
2. on the eyepieces can you see on one eye(usually the right eye) a little plus - minus marking. The eyepiece should be able to rotate a little to each side of this marking.
3. Set the rotating eyepiece to the middle setting.
4. Look through the binoculars as normal and bring the two sides together until you form the two circles that you see into one.
5. Pick an object app 10 meters away.
6 Presuming that the adjustable eyepiece is on the right hand side then close your right eye, look at the middle distance object you chose with your left eye and use the central focusing knob/wheel in the middle to bring your left eyepiece into focus.
7. Now, close your left eye and adjust the rotating right hand eyepiece while looking at the same object until your right eyepiece is in focus.
8. The binoculars should now be set for the differences in strenght of your eyes and you can use the middle focus control as normal.
Most binoculars have a soft rubber eyepiece that can be folded back for people who wear glasses but I, like most people I know who wear glasses, find it horribly uncomfortable.
This method allows you to set them for yourself and if someone else uses your binoculars you can quickly reset them for you.
Hope this helps...
Oct 12, 2009 | Bushnell Optics
I see 2 planes of vision on my 8x24 weaver binocular
Hope this helps...
- Oh yeah, sorry, forgot to mention.. This set up is so you can use them without wearing your glasses.. Much more comfortable!!
Sep 28, 2009 | Weaver 849433 (8x24) Binocular
Each eye is clear, but they aren't lined up right...it is like being crosseyed.
Hope this helps...
Sep 26, 2009 | Nikon Travelite V Binocular
Double vision in minolta binoculars
Hope this helps...
Aug 30, 2009 | Minolta Activa Standard Zoom Binocular
Cannot get them into clear focus
Hope this helps...
Aug 17, 2009 | Swarovski Optik Optics
Clothing Accessories Logo
Top Tom Ford Clothing Accessories Experts
Maxumized
Erin Wood
Erin Wood
Paul Parrish
Paul Parrish
Level 1 Expert
Are you a Tom Ford Clothing Accessory Expert? Answer questions, earn points and help others
