Question about Baumatic Washing Machines
Omputer reset procedure bflw75 - Baumatic Washing Machines
Baumatic fault code E11 Baumatic BFLW75 60cm 7.5kg
Look under the machine, for a bag with the
diagnostic manual, they do not want you to find
You will need that to run a self check & get it working
again
Try unplugging the machine, but most likely it has
the codes stored on the circuit board
Aug 15, 2014 | Washing Machines
Omputer turns on but wont boot
1. There is no hard drive or has a bad/failed hard drive
2. There is not OS (Operating System)
3. The Boot manager is corrupted
4. The Bios isn't configured correctly
That is all I can think of with your information.
What does the screen display during the process?
Does the computer make fan, or hard drive noise?
Was it working before?
If so what was the last thing you were doing?
Nov 21, 2013 | Dell Computers & Internet
My LG KG110 is not switching on asking for a security code what is it i tried all the no's i know bt its not working
You have to enter the default security code
Default will be 0000 or 1234 or 12345 or 00000(For default code check user manual of user handset).
If these won't works somebody changed security code.
To reset security code you need to flash your handset
To flash you need *USB cable compatible with your handset *A C omputer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE**
**Please don't disconnect while updation process
Jan 17, 2011 | LG KG110 Cellular Phone
Theres no sound on my omputer
install proper sound drivers. If you don't have the disk then download these drivers from the website of manufacturer...
Apr 23, 2009 | ASUS Eee 4G Notebook
Cannot unlock
The only option to use the recovery disc to reinstall Operating system. Windows vista has advanced security software which does not have loop hiles to reset the password or access the computer
Note : Please make sure you take a backup of the data becase when inserted the recovery disc, it restores to the factory settings how you had the omputer when you purchased without any softwares and the data.
Apr 22, 2009 | Sony VAIO VGN-NR260ES notebook
2002 daewoo wont start
Try to listen when you turn the key if fuel pump is making a slight noise.
fuel pump is under the back site
Dec 19, 2008 | 2002 Daewoo Leganza
Keyboard
If the keyboard has a reciever, make sure you press the button on both. also you may try to un-plug the USB cord from the computer for the reciever, turn the computer off, plug the reciever back in and turn the computer on again. it should say " New hardware found" or something to that effect. if it asks you to install it , try that. the omputer may simply nee to recognize the keyboard.
Jul 07, 2008 | Dell Wireless Keyboard Optical Mouse w0147
I need the software for my canon ip6000d i can not print.
1st, a barebone system is a omputer hand built, 2nd
http://www.techspot.com/drivers/driver/file/information/8993/
This will get you printing in no time!
Feb 23, 2008 | Computers & Internet
Washing Machines Logo
Top Baumatic Washing Machines Experts
Einar Axel...
Einar Axel...
Level 1 Expert
Are you a Baumatic Washing Machine Expert? Answer questions, earn points and help others
