Question about Freezers
What is orange light on Kyoto KU88 freezer - Freezers
What is the orange light for on unidentified freezer?
If that orange light is on the front of the freezer, on the top or bottom, it is very likely a light telling you the freezer is not cold enough inside, and the food is in danger of spoiling.
It may also be a "on" light.
If you will find a freezer thermometer and put it inside, you can tell whether it is an "on" light or a warning light.
Usually freezers run temperatures of about 10 degrees Fahrenheit or lower if they are working correctly.
God bless your efforts.
Feb 11, 2016 | Freezers
Orange light is on instead of green light on freezer what does this mean
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees - orange light : pressing the so-called S-switch which means that the compressor is running continuously. The S-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
Dado
Jan 14, 2014 | AEG 10.35 cu. ft. / 293 liter Upright...
Kyoto ku88 freezer
given a second hand Kyoto KU88 Freezer, have let it settle; plugged in and on FF, nothing happening - just red light on?
Oct 22, 2013 | Freezers
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
The standby light is still on
Are you sure it is a standby light? Usually the orange light is showing you it is in fast freeze. Try switching the orange button off and monitor the temperature. The freezer should cycle on and off, not run continuously.
Apr 15, 2012 | Whirlpool 10 cu. ft. / 283 liter Chest...
Orange light is on instead of green in the freezer does this mean anything?
no. the orange light is the temperature light and the green light is the mains light.
Apr 06, 2010 | AEG 10.35 cu. ft. / 293 liter Upright...
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
Buzzing noise -Kyoto KU 9577 Freezer
you may have a bad compressor or a bad compressor relay. The buzzing noise sounds like the compressor trying to start but can't. Unplug the unit and pull the relay off the compressor. If it rattles like gravel in side it replace the relay. If it doesn't then you may need to call a repairman to check the compressor. Hope this helps.
Apr 11, 2009 | Freezers
Defrost light stays on
Try advancing the defrost timer manually.
Jan 16, 2008 | Freezers
Freezers Logo
41 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
