Question about Philips Televison & Video
Need help for TV remote to work for 19" Magnavox 19PRC10121 tv
I need to know how to reset or activate my Magnavox remote for a 19" Magnavox TV. The batteries have been changed out recently power, volume, and channel buttons will now not respond. Is there possibly a code to reset the remote/tv?
Model# 19PRC1 0121
Serial# 36857657
Chassis Model# 19G601-00AA
Manufactured: June 1994
  • 2 more comments
  • arkbluetech May 20, 2009
    Thank you for the quick response. However, the Magnavox remote that came with the television does not have a code search button or "red" flashing indicator light that is shown for the link you provided.
    The link shows a CL032 Universal Remote (PN: GMIPM435S).
    The remote I have is black plastic with only Volume, Channel, Select, and a setup button on the top right hand corner. There are no model numbers, serial, or ANY type of identification on the outside of the remote either.
    Please note though, there are no red flashing indicators for this remote. I believe this is just a standard remote that came with the tv. Not a Universal type remote. At this point due to the tv being old I may have no other choice than to purchase a Universal remote ..if needed.
    Thank you again for the speedy reply. I don't have the remote in front of me at the moment but I do believe that there is no menu button on this remote. There is though I remember a small (reset) button on the bottom right hand side.
    The .pdf file provided shows a remote that is not the same as mine to perform the reset to Factory Defaults setting from the remote to the TV.
    Is there a user manual for this specific model? Magnavox 19" Standard Model# 19PRC1 0121
    I have researched for hours but have come up w/ nothing.
    Thanks Guru for your help!
    Here is a picture of the remote I have. According to the website it is no longer available and they list a substitute remote that is available in its place.
    http://remotes.com/remotes/servlet/rs?a=...
    At this point, that may be the only option right now.
    Thanks Masteria
    Again, there are no red indicator lights, code search button, or menu button on the remote I have as shown in the picture/link above (Left hand side). 19PRC10121 Original Remote (No Longer Available).
    The remote I have is not universal in order to perform a code search function on the remote. It could be the IR Transducer going bad though as you mentioned. Hopefully, just replacing the remote with a new Universal remote from Walmart might get the TV working again....problem solved.
    If not, in that case guess it's time to look for a replacement tv.
    Thanks for you help ...If any more ideas please let me know....I'll be glad to try them.
  • 355 Answers
Hi go to the below link to get a PDF of the Manual and Code Book for this remote and follow instructions.
MANUAL WITH CODES (PDF):
http://www.replacementremotes.com/store/productdetailp.cfm?productid=61355
CODES ONLY (PDF):
http://www.replacementremotes.com/store/productdetailp.cfm?productid=36735&reset=1
Posted on May 20, 2009
  • 4 more comments
  • Rohit  Asthana
    Rohit Asthana May 20, 2009
    Anyway, in my research, I did come accross the TV manual, and I found
    the instruction on how to reset the TV. I tried the steps, and THEY"RE
    STILL confusing, so I've added my own hints....hope this helps:
    Your TV can be reset to the factory settings in case you
    forget your Smart Lock password, or want to change the picture, sound,
    or features settings.
    1 Press the MENU button on the remote control to see the onscreen menu.
    In the left panel, you will see four icons (from top to bottom)
    • TV INSTALL (a tv)
    • PICTURE (icon of film)
    • SOUND (a piano)
    • FEATURES (icon of pliers and a hammer)
    When the Menu screen is showing the left panel as highlighted
    light grey, the Chanel buttons have Page up/Page down Functionality
    2 Press the the (CH UP) or_(CH DN) buttons to highlight the FEATURES menu.
    Navigate to the FEAUTRES menu (icon of pliers and a hammer -
    bottom of left panel) and you should make sure it is highlighted in blue
    3 Press the (VOL+) button to enter into the FEATURES menu.
    The right panel should now be highlighted in a light grey
    4 Press the (CH UP) or (CH DN) buttons to highlight the FACTORY SETTINGS control.
    This will select items in the right panel, FACTORY SETTINGS in on the bottom
    5 Press the the _(VOL+) or _(VOL-) buttons to reset the TV to the original factory settings.
    6 Press the MENU button repeatedly to clear the menu from the screen.
    The entire manual is found at this link: http://www.m4c.magnavox.com/files/1/15mf...
  • Rohit  Asthana
    http://www.oneforall.com
    Hope this helps.
  • Rohit  Asthana
    MAGNAVOX ..... 002 009 109 118 209 309 402 408
    502 508 510 807 914 917
    Direct Philips Magnavox Universal Remote Code Entry PM335
    1. Press and hold the Code Search button until the red
    indicator stays on. Release the Code Search button.
    2. Press and release the desired mode button (TV,
    DVD, etc.).
    The red indicator blinks, then stays lit.
    3. Enter the 3 digit code from the code tables. Note:
    after a valid code entry, the red indicator turns off.
    For an invalid code, the red indicator flashes.
    4. With your device on, press CHANNEL Up. If the
    device responds, no further programming is
    required. Note: If some buttons do not operate your
    equipment, try one of the other codes for your
    brand.
    Hope this helps
  • Rohit  Asthana
    hmm seems problem like it is probably the IR receiver inside the tv. BUT: Could be a dirty
    lens. Or, you might have something blocking the beam. Move the remote
    right up close to the eye on the tv and see if that helps.
    To replace or repair the IR receiver you must find the part somewhere -
    it is an old set - and pull the old one out and put the new on in.
    They are usually a small module type device, but on some older sets
    are discreet parts. Could be just the IR transducer itself. Replacing
    the light sensitive diode is easy to do.
    Try partstore.com and see if they have the part you will need. Maybe that will be a solution for you.
    Hope this helps.
  • Rohit  Asthana
    or take a one more try
    Programming with Code Search
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
    3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
    4.
    Press the Channel Up button repeatedly (up to 300 times) until the
    device could be controlled changes channel. The red indicator blinks,
    then stays lit. If you accidentally overshoot the code required, press
    the Channel Down button to backtrack through the library until the
    device changes channel. Pressing Channel Up changes direction to
    forward again. Press and release the Mute button to install the code.
    The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
    Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
    Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
    http://www.remotecodelist.com/remot...ps...
  • Rohit  Asthana
    although i tried my best whatever i can ... well i think problem is in IR receiver..you need to change it..or buy a universal remote......well if i have more option to test i will let you..
    good luck
Lost remote in nursing home; Serial # 36447254 and model # 19PRC10121. We have tried universal remotes but can not get them to work.
what is the name of the remote. and the tv you are trying to connect it to. i think the remote is a phillips here is a link to all the codes for you http://www.philipsremotes.com/index.cfm?page=27 let me know if works
Mar 16, 2011 | Motorola Televison & Video
I have a rca remote (rcu404) my tv is a magnavox. I can not find my book so I need help finding the correct code to program the remote to the tv. Thanks I do not have the code book for my remote control....
Code 000 for Magnavox TV Code 004 for Magnavox TV Code 006 for Magnavox TV Code 008 for Magnavox TV Code 019 for Magnavox TV Code 062 for Magnavox TV Code 068 for Magnavox TV Code 069 for Magnavox TV Code 075 for Magnavox TV Code 076 for Magnavox TV Code 077 for Magnavox TV Code 088 for Magnavox TV Code 130 for Magnavox TV Code 132 for Magnavox TV Code 133 for Magnavox TV Code 134 for Magnavox TV Code 183 for Magnavox TV Code 219 for Magnavox TV Code 235 for Magnavox TV
Jan 14, 2009 | RCA RCU404 Remote Control
Analog Pass-Through DTV Converter Box with Remote Control (3 digit code for the Remote Control
i can not get my tv to pick up a signal.I know my antena works i have tried it on other tvs.Has anyone else had this problem or know how to fix it?
Aug 04, 2008 | Philips Magnavox 20MT133S 20" TV
General electric Universal remote control codes
i lost my code book for my ge remote control
Apr 11, 2008 | Broksonic CTVG-5463GVC 19" TV
Magnavox mptv68a
any magnavox controler will work just put in some good batteries . lots retail wholesale stores like walmart carries magnavox tv remotes but make sure its a magnavox.
Apr 10, 2008 | Philips Magnavox 27MS343S 27" TV
Emerson jumbo remote
snowlady: You probably got it already but if not, here ya go:
Magnavox TV: 004,008, 009, 069, 074, 075, 077, 089, 163, 165
Matthew: 173, 183, 198
ronnmelplus4:
RCA TV: 000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 101, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191, 194
RCA VCR: 000, 003, 021, 055, 060, 082, 083, 084, 086, 087, 088, 089, 090, 091, 107, 110, 115, 120, 125, 134, 137
Emerson Combo: My book doesn't list Emerson, only JVC, Philips, Sansung and Sanyo
Jan 23, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Codes for the ge universal remote
Daewoo
149, 159
RCA
104, 116, 126, 157,161,162,167,168
Nov 04, 2007 | Zenith ZN-501S Remote Control
Magnavox universal remote for sanyo tv
ok...got this nice sanyo ds19310 from brother without remote..have a magnavox universal remote but don't have code for tv or if i can use magnavox codes or can i set remote to it another way...thanks for any help i can get! megnavox tv code is Press following key combination 0>6>2>5>9>6>MENU to select item press cursor(up)and (down) to change item value press cursor(right)and (left) cancellation of service mode press POWER button on the set regards thanks
Sep 10, 2007 | Sanyo DS19310 19" TV
My 19" Magnavox won't come on.
LOL its in a demo mode man!! simply hit the menu button on the original remote and go to the special settings and turn them off. If it still does not work, then the painter or the Microprocessor Ic Needs to be replaced.
Sep 09, 2006 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
361 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
