Question about Acer Computers & Internet
Touchpad left click not working
I have had my laptop since february and about a month ago i spilled some water on the keyboard so i replaced the keyboard. Now after a month it just out of nowhere my left click button on my trackpad stop working. So i was wondering if you knew how to fix this?
    Sergeant:
  • 279 Answers
Have you tried opening the laptop up again to see if perhaps the contacts under the left-click button were misaligned or something? To me, the easiest way (meaning not opening up the laptop again) is to just double-tap on the touchpad to left-click, or just get a cheap wireless mouse.
Posted on Jan 05, 2014
How do i replace a keyboard on a Samsung 470 R notebook
you'll need a new keyboard my friend they are cheap on eBay i fix water damage often keyboards never make it back but motherboards typically do ... you had a lucky one ... take the 80 dollar hit and replace the keyboard
Jun 13, 2014 | Samsung NC10-14ROBL Notebook
Levono g560 right touchpad button not working
If something was spilled on the keyboard, that could happen.
Otherwise, you most likely have a bad button. You will need to have the keyboard replaced.
Jan 10, 2014 | Lenovo Computers & Internet
My touchpad can not click after a spill.
your keyboard is scrapped......go to the nearest service center.....(if you have a warranty) this wont be covered in the warranty you have.
Dec 27, 2013 | Acer Aspire Computers & Internet
Touchpad doesn't work
Step 1:
The touchpad of any laptop is always subject to heavy use.
Most touchpads are designed for their durability to sustain the daily wear and tear for the lifespan of the laptop.
However, there may be instances or accidents that cause the touchpads to malfunction or stop working entirely.
There are ways to troubleshoot such problems and there are also remedies to salvage the touchpad's functionality without heavy repair or replacement cost.
Determine What's Wrong
A laptop's touchpad basically provides the functionality of a mouse for a desktop PC, typically with two buttons located just below it acting as the left and right click buttons on a desktop computer. A touchpad may be damaged by excessive use or foreign substances such as water, dirt or food items. Hit the "Windows" button on the keyboard and then use the right-left keys (or hit 'C') to open "Control Panel." From there, again use the right-left keys to get to "Mouse" and then hit "Return." Use the right-left keys to toggle between the tabs and open each to investigate whether any boxes had been improperly clicked by accident that cause the touchpad to become unresponsive. But if any of these steps fail to remedy the problem, then the touchpad may need to be repaired or replaced. b> Repairing/Replacing Touchpad b> A touchpad assembly cost $100 or more and that's not including replacement installation. Hiring a specialist to replace a damaged touchpad, including parts and labor, may easily cost $200. Unless the laptop in question is worth well over $1,000 and the touchpad is deemed a necessity, such repairs are rarely worth the cost. Attempting to replace the touchpad without certain expertise in laptop assembly may be dangerous and/or destructive. Also, getting a replacement part that's not compatible with the laptop may have catastrophic results, including irreversible damage to the laptop. Long-Term and Better Solution b> The simplest, and best, solution to a malfunctioning touchpad is to replace its functionalities with an external mouse. Most PCs sold after 2000 come with USB ports and getting a USB mouse either a corded or a cordless one--will remedy the problem. A cordless USB mouse may be bought for as little as $10 and some of the better-designed ones allow the user to tuck the USB stick inside the mouse's belly when not in use. Even when a touchpad is working properly, a laptop user should be advised to plug in a mouse anyway whenever possible as touchpads are notoriously difficult to use and also leaves the user in an ergonomically incorrect position.
http://www.microsoft.com/ b> http://www.streetdirectory.com/travel_guide/116002/hardware/touchpad_keyboard_for_personal_computers__pc.html
Feb 19, 2013 | Computers & Internet
Touchpad
Have you tried both areas to double click (the middle of the touchpad and the left touchpad button)? Check your mouse properties and make sure the right click is not the one you should be hitting. Maybe the left and right got switched somehow. Go into the touchpad properties and set everything back to default.
Boot the system in Safe Mode and see if you have the same problem.
Maybe your keyboard has been hijacked so run a virus scan.
Maybe your keyboard cable is loose or the keyboard is going bad. You'll have to remove the keyboard to get to the cable.
Mar 31, 2012 | Acer Computers & Internet
Water spill, mouse on the fritz
honestly, the only thing you can do, or have done, is to disassemble the laptop, get inside and look at the connectors and components. Sometimes the liquid causes corrosion, and some cleaning with alcohol can clean things up.
This is surely hardware, not an easy software fix.
Other times, cables or connectors can be replaced. I have had the keyboard go bad, the touchpad, the cables to the power strip by the power button, and even leak down into the ram, and corrode the ram contacts.
All were fixable, so it is possible. The key is to get deep inside and check out where the liquid flowed, and examine the parts. A good shop that knows laptops can help.
Apr 13, 2009 | Computers & Internet
Dell Inspiron 600M Keyboard Replaced, now touchpad doesn't work
need to pick up the keyboard and make sure the ribbon cable to the mother board is fully seated. if it is. then the touchpad need to come out and clean it very carefully. the sugar and any sticky substances need to be clean off the machine, around the touchpad.
I hope the drink did not damage the touchpad.(it is heat senstive)
if it still don'e work aft reinstalled it. you need to call dell to get a replacement.
Nov 13, 2008 | Dell F3534 Touchpad
Mouse pad wont work after water spill
not difficult..with right tools and patience..the touchpad is part of the upper assembly, and requires that the bottom be removed. When I do this, it takes around an hour.
got backup?
Feb 20, 2008 | HP Pavilion ze2000 Notebook
Computers & Internet Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
