Question about Ubisoft Rayman 3D
I have forgotten my password
I have been trying to track pin code over cell number 0823183755, which is unfortunately misplaced. Therefore I cannot be in a position to access my new password
Unable to open phone as it asks for a password which i am unable to provide, how can I bypass this . It is a 5"3g %.1 quad core
there are 2 passwords in affect on a phone
one is a PUK code that is only available from your service provider
ring them on another phone , provide proof that you awn the account and they will give it to you
the other is a PIN number that is your personal password that you have to enter to open the phone
if you have forgotten your pin number then you will ahve to seek advice on how to reset the phone and use a new pin number
Apr 12, 2017 | Quad Cell Phones
Number lock is forgotten on tolly luggage bag
Jun 07, 2013 | Cell Phones
How to reset my motorols bt51 with the unlock code forgotten ?
Just type any password until your phone asking PUK code. PUK code is a unique number to unlock your phone if you forget your pin number and can be found from your sim card paper or asking from network provider. With puk code you can unlock motorola bt51 from old pin and you can set new password, but please pay attention when you entering that code don't make mistake for many times. It will not make your motorola unlocked your sim card also locked.
Aug 06, 2011 | Verizon Communications Motorola w385...
I have forgotten the password of my alcatel lucent ip touch phone, how can i unlock it again
HERE'S THE ANSWER TO YOUR PROBLEM:
1. Enter the last four digits of your phone number on your cell phone PIN screen.
2. Enter 9999, and if that doesn't work try 1111, and if that doesn't work try other four-digit numbers you may have entered.
3. Shut off your cell phone, take off the back of your phone and pull out the battery. Record the IMEI number which is under the battery. Re-insert the battery and power on the phone. Enter the last four digits of the IMEI number on the PIN entry screen.
4. Call your service provider and request the unlock PIN if none of your attempts so far have worked. You will have to prove you are a customer by stating your cell phone number, address and Social Security number.
5. Turn off your phone. Hold the keys "3," "*" and "Call" and switch the phone on. Hold the three buttons down until the word "Formatting..." appears on the screen. This should reset the phone lock code.
6. Go the links in the Resources section and have your IMEI number ready. These websites will ask for your phone model and IMEI number and then charge you a set fee for the unlock code.
Read more: How to Unlock a Cell Phone Password ' eHow.com http://www.ehow.com/how_4810931_unlock-cell-phone-password.html#ixzz1Qc2uBsBY
Jun 28, 2011 | Lands Phones
Forgotten password AND puk number
To unlock your phone from forgotten password, follow the information from this link.
When you enter a wrong pin number three times the phone asks you for a PUK number. The PUK code is generally eight digit number This PUK number is an unlocking code which helps you to unlock the phone and use it. If you enter a wrong PUK number 10 times than you simcard gets rejected. Then you will have to buy a new simcard. It might happen that your phone might ask you for PUK2 after you enter your PUK number. You can find the PUK code is in your SIM card documentation Starter Pack. If you do not have this then contact your phone service provider. Your cell phone service provider can give you the PUK code once they have confirmed your identity to prevent any stolen SIM access.
Mar 05, 2011 | Nokia 2630 Cellular Phone
N95 FORGOTTEN PIN CODE
HI If you are asking for pin contact your service provider , he will give you a default pin . If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Donot try PUK code many times or else your sim will be blocked and you will need a new sim.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no.
Sep 28, 2009 | Nokia N70 Cellular Phone
Pin code
if you have not changed the pin code then try the last four numbers of your cell number. This works for Alltel customers.
May 28, 2009 | Samsung SGH-X200 Cellular Phone
Garmin nuvi 300 asking for pin number
Unfortunately, even if you perform master reset on Garmin GPS unit, it does not reset Garmin Lock security feature, which password-protect most Garmin electronic devices to deter theft. If you forget the PIN or password unlock code to unlock the Garmin unit, the best solution is to bring it to Garmin to get unlocked. “Secure Location” does not unlock a locked Garmin unit either as it’s only a temporary fix as when it’s turn on outside the security location, the device is locked again."
So unfortunately, there is only one option: You have to send your nüvi into the Garmin, who can unlock it. Remember original receipt.
Apr 07, 2009 | Garmin Nuvi 300T GPS Receiver
Forget my nokia n73 lock code
If you need the SIM Pin number to switch the phone on, then you have to enter any Pin number 4/5 times, then the phone will request a PUK number. This number was on the plastic card that your SIM card was attached to. If you don't have it, only your Network Service Provider can supply it to you.
If it's the Security code you need, to get into certain settings IE. Erasing received calls, missed calls, timers etc... The Nokia default is 12345 if you didn't change it, but if you did change it and you've forgotten it, let me know, I'll tell you how to retrieve it.
The IMEI number doesn't have anything to do with the SIM Pin number. It is used to identify, track, and Blacklist your phone.
Mar 23, 2008 | Nokia N73 Cellular Phone
Forgotten pin number
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Sep 03, 2007 | Kenwood KDC-519 CD Player
Ubisoft Rayman 3D Logo
55 people viewed this question
Top Ubisoft Video Cameras Experts
Are you an Ubisoft Video Camera Expert? Answer questions, earn points and help others
