Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Not printing. trying to connect a kodak esp3 to my air port express through the usb port, the printer is on the network but when i try to print is says to make sure its connected and powered on. is this possible or am i trying an imposible?
  • JDTec
    JDTec May 11, 2010
    Do you have is set as "shared" on the network?
  • 68 Answers
I think youre printer was not a wifi ..Try to share the printer or connect (right click then connect)
Posted on May 20, 2009
How do I connect hp deskjet f4280 to a wireless network?
Bluetooth wireless printing is not supported on this model - you could try a Cisco-Lynksys WUSB54G wireless-G USB adapter or a IOGEAR USB 2.0 Print Server, 1-Port GPSU21 both available on Amazon
Dec 23, 2014 | HP Office Equipment & Supplies
I have a wire less router the ESP3 kodak rinter is connected to my desktop and the desktop to the wire less router. How can I have my laptop print on the ESP 3 via the wireless router?
go into control panel and printers
right click on the printer and click share, then go onto the laptop and add printer and tell it its a network printer and search for it then once you have done that you can print from your laptop
Feb 13, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have Windows XP. I was finally able to connect the Kodak ESP 5250 with the USB cable and print. However, I can't get my computer to print wirelessly. The printer is connected to my wi-fi. Do I need to...
In Windows XP:
Start/Settings/Printers and Faxes
Right click /Properties
Check Port tab
If the printer port connect to USB, install another instance of printer, connected to WiFi
Nov 07, 2010 | Kodak ESP5250 All-In-One InkJet Printer
My kodak ESP3 will print and copy but it will not scan as it did just a few weeks ago.
When some device suddenly goes haywire, the first thing to try is refreshing its driver. Drivers are just software programs, and sometimes they get corrupted.
So try updating your printer's driver. The latest version is available for free download at
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=12666/12667&product=EKN034524
While you're at the Kodak site grabbing the current driver, look around in the FAQ and see if others have reported a similar problem - or drop Kodak a note and they should respond.
If a new driver doesn't work, try updating the scanning software (it may be updated too by now), attaching your printer to a different USB port, or changing out the USB cable - in that order.
If none of the above work, your scanner could have "gone south" - but if so, check if the warranty will cover your trouble for replacement.
Sep 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
My printer will not print anything on the paper, I have checked and it has ink and is hooked to the computer by the USB port
Kodak ESP3:
Print a demo sheet.
1. Verify that inkjet paper is loaded in the paper tray.
2. Press and hold Scan + Copy/Resume simultaneously until the On/Off light flashes green.
Does a blank print appear? If so:
contact Kodak at 1-800-421-6699.
To expedite the call, provide the agent with the one of the following reference IDs - PH02 for image quality problems or BP01 for problems with blank prints.
If slowly and in increments, reference BP02
Sep 24, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP3 installed 2 new cartridges black light
For that problem kindly try doing the ff:
* Re-seat the inks both color and black then try printing
* Re-seat the Printhead of the printer then print again
* if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Sep 22, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
My KODAK PRINTER ESP3
it is a problem with print spooling. and the firmwware also needs to be upgraded of the printer . click on start, go to run,type services.msc in search boz of run. find print spooler,right click it,stop it and then start it. click on apply and the ok. Go to control panel,printers and faxes ,set ur printer as default printer.try to print after dat ur issue will be resolved
Jul 19, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Mi printer does not print
a) Load the Kodak Inkjet Printer Software CD into the
CD-ROM drive. Follow the on-screen prompts
when the instructions appear.
If instructions do not appear, click Start, then Run.
Select CD-ROM drive and type setup.exe, then
press ENTER.
b) Connect the USB cable to the printer when
instructed. Continue to follow the on-screen
prompts until installation is complete.
Do not connect the USB cable to
the printer until instructed during
software installation.
USB
To set the printer as the default:
In XP:
Start Printers and Faxes
Right-click the icon for the printer you want to use as the default printer, and
then click Set As Default Printer.
In Vista:
Start Control Panel Hardware and Sound Printers
Right-click on the printer you want to use, and then click Set As Default Printer.
Here is the setup guide:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/ESP3/1K3687-ESP3-setup_en.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 23, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Wireless laptop cannot connect to network printer
Found this solution:
  1. On Vista PC go to "Control Panel" - "Printers" - "Add printer".
  2. - Believe or not, click "Add a local printer" (I know you want to add a network printer but that way it doesn't work).
  3. - Click "Create a new port" - "Local Port" - "Next"
  4. - In the next box you have to enter a port name like this:\\PC name\Printer name where "PC name" is the network name of the XP PC or Network Share where you have the printer and "Printer name" is the network name of that printer. Be careful with this names. Check in your XP PC "Control Panel" - "Printers and faxes" - "your printer" - right click - "share" - "share resources name"
  5. - Choose the manufacturer and printer model of the printer you are adding.
  6. - Now the printer will be added and you can print a test page or print something to test it.
Let me know if it's working for your config as it worked for me
Jan 23, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
212 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
