Question about Samsung RS2578BB Side by Side Refrigerator
Leaking water dispenser, how do I get to the solenoid valve in the freezer door?
The solenoid valve in the door that goes to the water dispenser is bad, but I don't know how to get to it.
  • 1 more comment
  • dennis bogush Jan 08, 2014
  • bobalix Jan 09, 2014
    http://www.appliancepartspros.com/samsun...
    This link has a video on how to replace the solonoid valve.
  • 451 Answers
Most solonoids are in the back of the unit where the water connects to the refrigerator there is a usually a fiberboard cover that you remove to gain access to the soloniod. Hope this helps.
Posted on Dec 31, 2013
Testimonial: "This solenoid is in the freezer door, it is right above where the water comes out, does anybody know how to pull out that part, it looks like it should be able to come out from the front, but I'm not sure."
4 Suggested Answers
  • 833 Answers
SOURCE: water solenoid
if that's your problem...here's one place: www.samsungparts.com
Do you get ice and no water? Or neither?
Might be the solenoid or the switch. There is a diagram on the back of the box...use a multtester to be sure.
Posted on Dec 19, 2007
sandy82
  • 10 Answers
SOURCE: WATER ON THE FLOOR UNDER FREEZER DOOR
dear jim
there is drain line get chocked up with ice.Please open freezer evaporator cover u will find there is ice blocked in drain tray,melt it with hot water,check drain heater attached to the drain tray,if defective replace it,it will work fine
regards
sandy
Posted on Jun 08, 2008
garing
  • 998 Answers
SOURCE: water leaking fron ice maker/water insert
change water shut off valve
Posted on Aug 07, 2009
Water dispenser does not work, any time it is used water just drains out of bottom of freezer area onto floor. Ice cubes works
Hello Melissa;
My name is Peter. I am a retired field service refrigeration technician.
I am sorry to say you have a serious problem.
The water supply line to your ice maker runs up the back of your refrigerator from the ice maker solenoid. It is a separate water supply line.
Your water dispenser water line runs from the water dispenser solenoid under your unit and up from the bottom of you freeze door.
You have a plastic tubing leak within your freezer door. Calling a service company to replace the freezer door tubing - a good service technician would not replace the tubing - the damage has already been done.
The insulating material in your freezer door is soaked. The water in the door will cause the door liner to expand and crack. There is no way to completely dry out the insulating material.
The only fix is to replace the freezer door. So, $300.00+ for the door and $150.00+ for the service tech. No, a hair dryer will not do it.
May I suggest:
1.) Remove the bottom toe plate (Kicker plate) in the front of your refrigerator.
2.) Turn the leveling screws counter clockwise so you can pull the refrigerator out to get behind it.
3.) Unplug the unit.
4.) Remove the screws from the bottom cover.
5.) There are two connectors to the solenoid valve to the water dispenser. It is the larger diameter tubing running under your refrigerator.
This will disable your water dispenser. If you see cracks on the inside of your freezer door, seal them with a high temperature silicone adhesive.
If you elect to purchase a new unit, check out Sears Outlet (Scratch & Dent) Stores.
May 08, 2015 | Refrigerators
No water from dispenser Matag New filter solenoid valve working, tube to dispenser seems to be blocked
Hello Hans;
There could be several areas that would effect your water dispenser not working:
1.) When you depress the water dispenser do you hear a 'Click'? If not you have a bad water dispenser contact switch.
I would send you a diagram but I do not have your model number.
2.) In the lower back of your fresh food section is your water dispenser water tank. At times this can freeze near the freezer section. Look in the lower corner of the freezer & your fresh food section for ice build-up.
3.) You could have a bad water filter. This does happen often. Remove the water filter and test you water dispenser.
4.) Do you have water leaking out of the bottom of your dispenser door? If so you have a split in the tubing in your water dispenser door.
5.) Is your ice maker working? Often the water valve to your refrigerator becomes plugged up and you do not get sufficient water pressure 60 PSI to operate your water dispenser solenoid valve.
Nov 15, 2014 | Maytag MFD2561HE Stainless Steel Bottom...
Bernie,
Your water dispenser is controlled by a solenoid valve that is often in tandem with the ice maker water valve (meaning two valves side by side). Check and make sure the water is dripping from the water outlet tube only, in which case the solenoid valve is leaking. However...sometimes what happens is that the door that isolates the ice shoot (and the inside of the freezer) from the outside can get stuck open. Either blocked, mineral build up, broken etc..and water (melting ice) will drip down and out. This can lead to other problems so be sure the flapper door from the ice dispensor is ALL the way closed.
Oct 12, 2013 | Sub-Zero 661/F Side by Side Refrigerator
Maytag MSD2272VEB00 leaking water
Laura,
Your water dispenser is controlled by a solenoid valve that is often in tandem with the ice maker water valve (meaning two valves side by side). Check and make sure the water is dripping from the water outlet tube only, in which case the solenoid valve is leaking. However...sometimes what happens is that the door that isolates the ice shoot (and the inside of the freezer) from the outside can get stuck open. Either blocked, mineral build up, broken etc..and water (melting ice) will drip down and out. This can lead to other problems so be sure the flapper door from the ice dispenser is ALL the way closed.
Oct 12, 2013 | Maytag Refrigerators
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
The water on the freezer door will not work ice does dispense. this is a ge side by side model GSL25JFTA BS. kbaker23322@yahoo.com
most likely you water solenoid is bad. need to make sure you get voltage(120v) to water solenoid. if voltage then the only other thing that could be wrong besides the solenoid. would be a kinked hose or the line (has a small chance) has frooze inside the door panel if sprung a leak.
Aug 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Leaking water at dispenser
There is air in the line. Run at least 2 quarts of water through it. If not that there is a leak somewhere between the valve and the output where air is getting in.
Aug 26, 2009 | Maytag MFI2266AE Side by Side Bottom...
The water will not stop coming out of the door dispenser
1 of two things. 1)the switch at the dispense flap has failed. 2) the water valve solenoid that the sitch activates has failed. you will need to pull the unit away from the wall and remove the bottom panel...on the right side you will see the valve assembly. remove the power connection to the vavles....then turn your water on...water out of dispenser means bad solenoid/valve....no water means bad dispenser switch.if its the switch you can leave the solenoid to the dispenser unplugged until you get the part.
Jun 11, 2009 | GE Profile Stainless Bottom-Freezer...
Water dispenser not working
2 possible problems.
#1 water valve for the water side is stuck in the closed position.  Only way to tell is to pull the bottom kick panel out and look for the water line disconnect.  Separate the line, close the door and try to draw water through the dispenser.  If the water comes out of the disconnected line, then the water valve is good.
#2  if water is coming out of disconnected line, then the problem is in the freezer door.  There is a heater that keeps the water line from freezing inside the freezer door.  It is not repairable!!  The freezer door has to be replaced.
Nov 21, 2007 | LG LRSPC2031 Side by Side Refrigerator
No water dispensing to the icemaker. Water does dispense through the door dispenser. KitchenAid ksbs25fkbl00
Unplug your refrigerator and leave the freezer door open for 2 hours (The food in the freezer will only partially thaw).
The line supplying the water to the ice maker has frozen...this will un-thaw it.
Oct 18, 2007 | KitchenAid Superba 21.6 cu. ft. Top...
Samsung RS2578BB Side by Side Refrigerator Logo
69 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
