Question about Dell InspironTM 1501 Notebook
Dell Inspiron 1501 laptop screen will not work.
I have a dell inspiron 1501 and the Fn+F8 will not work. I can use external monitor but no matter whether the external is hooked up or not the laptop screen will not work.
  • 2 more comments
  • jasonkovach May 21, 2009
    Thanks problem has been solved. The wiring for the LCD was broke.
    Thanks for the ideas. I solved the problem. The wiring for the LCD were broke so I fixed that and wha...la.
  • dmyers2k May 11, 2010
    Have you tried going into the BIOS using the external monitor and setting the LCD as the primary display, or even setting the BIOS defaults.
    The other question is does the LCD panel ahve a very faint image showing? One has to look very close to notice it; but, if the backlight goes out on the LCD panel, there will be a very faint image present.
    If the LCD panel is completely black with NO faint image, you might want to check if the LCD cable to the motherboard being reseated fixes the problem
  • JDTec
    JDTec May 11, 2010
    Do you mean that the laptop screen does not work? or that both the ext. and laptop screens do not work?
  • Dell Master
  • 32,281 Answers
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 21, 2009
Dell 1703fpi
Dell 1703fpi LCD monitor,
http://philadelphia-pa.americanlisted.com/computers/dell-1703fpi-17-lcd-monitor-vgadvi-usb-hub-50-phoenixville_21225579.html
I got that part Dan.........
What I need is what Model Number of Dell Inspiron it is.
This is on the Bottom of the Inspiron laptop.
Why?
Because I do not know if the Dell Inspiron laptop you have, has a DVI port, or a VGA port; for an external monitor......
Generic information while I wait.........
Example of Digital Visual Interface port, and corresponding cable,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
Example of Video Graphics Array port,
http://en.wikipedia.org/wiki/VGA_connector
Can be on the side, or back of laptop.
Laptop OFF, monitor OFF, connect the matching video cable from the external monitor; to the laptop.
Now turn the laptop on.....
By factory default settings, the display should now show on the external monitor. (Dell 1703fpi)
No?
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external monitor
3) External monitor ONLY
Press, and hold down on the Fn key. (Usually 2nd key from left on bottom row of keyboard)
AT THE SAME time tap once on the Display Toggle-Over key.
Which one is that? Dunno.
Laptop model number was not stated.
For a Dell Inspiron though, it's usually the F8 key.
(F1 through F12 keys at the top of the keyboard)
Hold the Fn key down, and at the same time tap once on the F8 key.
Still no?
Hold the Fn key down again, and tap once more on the F8 key.
IF, F8 is the correct key for Display Toggle-Over, and there is no display on the external Dell 1703fpi; then I suggest you have a problem with the video chipset; on the motherboard.......
Awaiting reply in a Comment.
Regards,
joecoolvette
Jul 03, 2013 | Computers & Internet
My dell inspiron m5030 has a white screen any ideas what it is?
LCD video cable. Plus, to connect and activate an external monitor, you click Fn + F2, not F8.
May 20, 2012 | Dell Inspiron M5030 Laptop
Inspiron 1501 where is Fn key?
If you want to switch on the monitor, please use the switch on button which wiil be displayed as 'U shaped button. Fucntion keys Fn will not switch on the laptop. Please see the instruction manual to switch on the inspiron.
THanks
Apr 02, 2012 | Dell Inspiron 1501 Notebook
Can the dell inspiron m5030 work with a projector
You can switch to anexternal monitor by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
Nov 12, 2011 | Dell Inspiron M5030 Laptop
How to hook up dell inspiron 1501 laptop to tv with vga
Do the following:
1. Get a VGA cable (male-male) and connect to your TV and your laptop
2. Select your TV's source as PC (check ur TV manual)
3. From your laptop, select video output to external monitor by clicking on the Fn key and the F8 key at the same time
NOTE: Please rate our help to keep this free service online
Jan 12, 2010 | Dell Inspiron 1501 PC Notebook
My dell inspiron screen stays black and powers up
Try this
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
You might also try an external monitor and see if you get any video that way (Fn+F8 toggles to enable external video)
Jan 05, 2010 | Dell Inspiron 1501 Notebook
Funtion F8 not working s video from laptop to TV
Before connecting the external monitor,Shut down your computer,connect the external monitor,Restart the computer and the external monitor should load and The FN+F8 should now work.
May 21, 2009 | Dell InspironTM 1501 Notebook
Screen not lighting up
if you see all lights are green ( power, HDD) it means your computer is working
since you see nothing on screen...press Fn+F8
Press and Hold Fn( blue color key beside Ctrl key on lower left) then press F8
Mar 11, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1300 can't connect external monitor
I was having the same problrm for my dell inspiron 1300. It is not FN + f5. It is fn +f8. Notice the Crt/LCD...
Jan 04, 2009 | Dell Inspiron 1300 Notebook
Dell InspironTM 1501 Notebook Logo
1,103 people viewed this question
Alun Cox
