Question about Sony Cyber-shot DSC-W50 Digital Camera
The soluction not working
Receive "access" error when I turn on my camera. The lens continually tries to open and close. This repeats until I get a message: to power off and restart again. I tried that many times with no success. I change my battery with no success. I changed my memory stick also without any success.
I have tried to do a reset, however I cannot get access to any function keys to begin the reset function
Tap side of camera with base of hand with 2 or 3 sharp taps.  Then turn camera on.  Problem should be solved.
Posted on Oct 27, 2007
Turn on but not working
Most all cameras have a "FORMAT" mode that is accessable through your MENU options. Find It and try RE FORMATING YOUR CAMERA. You may lose stored images but it will reset the Camera back to Factory settings. Good Luck
Oct 09, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Error 50 c
  1. Power off your printer.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the printer on. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
Hope this helps.
  1. Lower the scanner unit until it is completely closed.
  2. If you receive the error message again, replace both cartridges.
Jul 29, 2009 | Lexmark X6170 All-In-One InkJet Printer
Access Probelm with DSC-W50 camera
abrakati,i have the same problem,still unsolved.however,to access the menu i depressed the button to view 'shots' taken.while in that mode i was able to access the menu but resetting did ****.i still get the same malfunction.chris.
May 27, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
I receive ''access'' error
The "Access" will stay there until your camera passes it's self lens test. The test runs 3 times, then gives up with an error message. The cause of this problem is most likely a grain of sand somewhere in the lens. Only a camera tech could possibly ever hope to find it. Replace the camera lens.
Nov 12, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
well well well a simple way to fix it if u r scraed to whack thn tap the lens,menu part ,sides wid a pensil or a pen...bit little harder atlest d cam should get little vibrations well it really works...belive even i had d same problem just after 15days just d previos day to a holiday...thn i just tapped itwid ma fingure n u wont belive it worked...
Feb 12, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
This soluction not working
Hi REYPERLA
I`m afraid resetting the camera will not work. The camera has a lens problem and is therefore giving the error.
Contacting your nearest Sony service centre is your only solution.
Sorry about the bad news : (
Dawiem
Oct 18, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Access problem with DSC-W50
It's a problem with the lens. Usually, the internal focus lens jams up, or is out of alignment. It has to be opened up to be fixed, and the lens might have to be replaced. Occasionally, you can give the camera a good whack in your hand while it's powering up. Just be very careful not to hit the lens, or the LCD; as they can be permanantly damaged. Hit it with your palm on the corner, or edge. Also be sure the camera doesn't fly out of your hand...then it, or something will break, obviously.
Sep 06, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-Shot (DSC-W50) Access Problem
did you try to reset the camera or call sony?
Aug 31, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
87 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
