Question about Apple iPhone Smartphone
My iphone wont let me lock it or turn off what do i do?
I tried to use the lock button but it won't work and the on screen helper thing won't lock it either..it's stuck on a page and I can scroll or click it just won't let me leave that screen and it won't let me use the home button either please help me..
Have you tried switching it off and back on again sounds like its frozen
Posted on Dec 31, 2013
SOURCE: My iPhone is stuck at apple/loading page
U tried the safe mode? Get there by holding the sleep and home buttons down (same as rebooting) then once the phone is off, release the sleep button, but keep the home button down. iTune should then notify you that the iphone is connected in safe mode. Unfortunately I had the same problem ended up restoring the phone.
Posted on Jan 15, 2009
  • 502 Answers
SOURCE: my iphone doesn't turn on!
For some reason I can't imagine you completely bricked your iPhone just by attempting the downgrade, but if you really can't revive it by trying the hard reset there seems to be a hardware issue with your board. There are iphone repair guides that show you how to replace it and parts are available on ebay.
Posted on May 04, 2009
okcfirewall
  • 80 Answers
SOURCE: My iphone got stucked on the apple logo
here is a small tutorial that my help you....good luck I hope this helps please don't forget to rate
http://www.youtube.com/watch?v=u4xLvpazV24
Posted on Jul 23, 2009
SOURCE: my iphone wont turn on or charge!!
That happened to me. Push the home and on/off buttons simultaneously until the apple logo appears, then wait until it has fully restored the system. This should work. Good luck
Posted on Jul 28, 2009
  • 33 Answers
SOURCE: My iphone 3gs shut off
If something isn't working right, restarting, force quitting an application, or resetting
iPhone will likely solve the problem.
Restart iPhone: Press and hold the Sleep/Wake button until the red slider appears.
Slide your finger across the slider to turn off iPhone. To turn iPhone back on, press and
hold the Sleep/Wake until the Apple logo appears.
If you can't turn off iPhone or if the problem continues, you may need to reset. A reset
should be done only if turning iPhone off and on doesn't resolve the problem.
Force quit an application: Press and hold the Sleep/Wake button on top of iPhone
for a few seconds until a red slider appears, and then press and hold the Home button
until the application quits.
Reset iPhone: Press and hold the Sleep/Wake button and the Home button at the
same time for at least ten seconds, until the Apple logo appears.
Posted on Oct 16, 2010
IPhone 4S won't turn on
Try holding down your Home Button and your Lock Button at the same time for about 10 seconds or until you see the apple logo. This will restart your phone and should resolve your problem!
May 01, 2013 | Apple iPhone Cell Phones
MY IPHONE DIED AND NOW WONT TURN BACK ON
First check to make sure your charger is working, plug it up to the computer and see if the battery charging display comes up.
Second I would check to make sure the battery is actually charging.
Third try a cold boot, hold the power and home keys down while it boots it could just simply be locked up.
Jan 09, 2013 | Apple iPhone4 4G iPhone 4
My i phone is locked
Before we get started, you'll want to disable the iTunes helper application that may get in the way of the installation. Make sure iTunes is not running, then open OS X's Activity Monitor in the Utilities folder of the Applications folder. Search for or scroll down to iTunes Helper, select it, and then click on the Quit Process button in the top left of the screen. You'll also need your iPhone, your data cable, and a Wi-Fi connection to the Internet.
Apple doesn't support the installation of third-party applications on the iPhone, but enterprising developers have created a program called AppTapp that will let you install including chat clients, games, and other pieces of software - including those that are needed to unlock your iPhone
Download and install AppTapp. Once you run the program, the first thing it will do is ask what version of the firmware you're running. If you've just updated your iPhone, you probably have Firmware 1.0.2-select that and click on Continue.
Assuming all goes well, you should get a screen that begins with the words: "Congratulations! You have successfully installed AppTapp Installer onto your iPhone." You should then find a new application on the iPhone's home screen called Installer.
The next instructions will require downloading some applications from the Internet to your iPhone-so make sure your iPhone is connected to a WiFi network. Launch the Installer program, and you'll see a long list of various applications that you can install. Scroll down, then select and install-in order-Community Sources, BSD Subsystem and OpenSSH.
NOW PERFORM THE GSM UNLOCK
First, download and install Unlock.app, lockdownd, and Cyberduck.
Then go to the iPhone's General settings and set Auto-Lock to Never. Next, you'll need to get your iPhone's IP address on your local network. To do this, go to Settings: Wi-Fi and click on the blue arrow next to the network that you're connected too. Write down the IP address, as you'll need it for later.
Now, open Cyberduck and click on the Open Connection button in the top left of the window. In the connection window, type the IP address that you just noted. Make sure that SFTP (SSH Secure File Transfer) is selected, and that you are using Port 22. For the username, type root, with the password of dottie.
Once connected, navigate from /private/var/root to the main directory by choosing the / item. Next, navigate to /usr/libexec and drag the file named lockdownd (the one you downloaded earlier) into it. It will ask if you want to overwrite the existing file-click on Continue to do so.
Now, in Cyberduck, drag the Unlock file from the Mac's desktop into the /Applications folder at the top of the main window. Once that's done, turn off your iPhone and remove the SIM card, then turn your iPhone back on and choose the application on your iPhone called Unlock
Afterwards,there should be a white screen that says "All files found. Ready to go. Press Start." Once you press start, it will take about 20 minutes for all the files to install.
The progress messages will appear at the top of the screen as it progress-once you see "Completed" then you're finished. Insert a new SIM card of your choosing into your iPhone. Congratulations, you've just unlocked your iPhone!
Jun 22, 2010 | Apple iPhone 3G Black Smartphone
Iphone 3gs wont charge, wont switch on, not showing on itunes! just dead
The only thing you can do with this issue is :
Hold the sleep /wake button and the home button at the same time for 2 full minutes
if you see a white apple appear- your good - just charge for 4 hours you should be fine
if the iphone still dose not turn on then - it need service
https://selfsolve.apple.com/GetWarranty.do
Apr 18, 2010 | Apple iPhone Smartphone
Iphone 2g not starting back up after reboot..
When the device is locked up like this hold down the lock and home buttons. After a few seconds the device will turn off, immediately let go of both buttons. Now press down and hold the home button. Hit the power/lock button one time. Continue holding the home button until the phone boots up. It will need to be connected to iTunes for recovery at this point.
Jan 27, 2010 | Apple iPhone Smartphone
Iphone wont power on
You may need to press and hold the sleep button. If not try to treat it like an ipod. Hold the center button at the bottom and the top one at the same time. Should reboot.
Aug 30, 2009 | Apple iPhone Smartphone
Iphone Battery died now it wont charge or turn on
Hello ! I was in panic attack !!! did everthing and nothing seems to wake up my iphone. I forgot to charge it so battery went full empty, then I plug it on the wall charger, and nothing happend. I let it all nite, and next morning,... surprise !!!!! still the red icon, No battery, the iphone didnt restart!!!! How I fix it?
1-unplug it from the wall charger 2- press middle button and startup button, same time 3-when red battery dissapear, plug the charger. 4_ do this many times. Didnt work for me the first time, but at the end it works !!!!
NOW MY IPHONE IS WORKING GREAT !!!!! GOD BLESS YOU ALL !!!!!!!!
Aug 21, 2009 | Apple iPhone Smartphone
My iphone wont turn on or charge!!
Jul 28, 2009 | Apple iPhone Smartphone
My iphone camera just shows a black screen when i touch the camera app and wont allow me to take pictures what can i do
pls see this First !! B4 reset
Straight from Apple Iphone Manual
Camera is not functioning
  1. Tap Camera, then point and shoot. Note: If you take a picture with iPhone turned sideways, it is automatically saved in landscape orientation. If you do not see Camera on the any of the multiple Home screens, check to make sure that Restrictions are not turned on by tapping Settings > General > Restrictions. If they are, set Allow Camera to ON or tap Disable Restrictions (in iPhone 2.1 software or later).
  2. If that doesn't work, clean the camera lens with the cleaning cloth that came in the box with iPhone.
Mar 27, 2009 | Apple iPhone Smartphone
IPhone won't shut off.
From the apple.com website - the 2nd one worked for me:
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
Nov 12, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
35 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
