Question about Mitsubishi WD-73640 73-Inch 1080p Projection TV
Tv has volume but only has black screen
Tv powers on and has volume but only shows a black screen a green light stays on above the status bar for awile then it turns red any ideas?
  • 147 Answers
SOURCE: mitsu hc3000 problem "red-green status light blinking and no input"
fyremd,
I had an older model (1500) and I think I read in the manual that it will shutdown @ 3000 hrs. You have to replace the lamp itself, not just the bulb. The average price (depending on where you shop) is around $200 dollars or more for a replacement lamp.
I hope this helps. Please let me know!
-Thanks
Posted on Mar 14, 2008
SOURCE: TV won't turn on.
Lamp is bad need new lamp
Posted on Apr 27, 2008
SOURCE: STATUS LIGHT YELLOW, LAMP LIGHT GREEN: TV TURNS OFF.
Actually, I think I found the problem. I took the light out and cleaned the filter (screen) on the light cartridge. I turned the tv back on and it still gave me the message. As the tv was still on, I tapped on the fan that sends air directly to the light cartridge and the message went away. About 2 days later, I got the message back but went I shook the tv and tapped it on the stand a few times, it worked. I think that particular fan is going out and seems to be a problem with other tv's as well. Any ideas where I can buy a fan? Hope this helps you all out.
Posted on Jun 24, 2008
  • 179 Answers
SOURCE: Mitsubishi wd52525 shows error code 37
error code 37 is either the dmd fan or the lamp fan. you can see the dmd fan with the cover off. you cannot set the lamp fan as it is under the light engine. I guess the easiest thing to do is get a lamp fan 299P282010 and a dmd fan 299P283010 and change them both.
Posted on Nov 17, 2008
tvguy171
  • 106 Answers
SOURCE: STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
The colorwheel is your problem. To confirm this, unplug the tv, then listen thru the air vents in the back as you plug the tv in. You will probably hear a ticking sound. If you do, that is the colrwheel. If the colrwheel is working, youwill be able to hear it "spin up". It will be a sudden high pitch whine. Let me know if I can be of further assistance
Posted on Dec 19, 2008
Get a black screen when turned on
Same thing happened to me. Unfortuanatley, I had to get a whole new phone because it was a "manufacturer defect"
Jul 05, 2015 | Televison & Video
I can hear tv but have black screen and red light on front
Check its back-light inverter board. If needy replace it. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/Pull up older posts. Now there is no back-light to your TV.
Dec 31, 2013 | Mitsubishi WD-73640 73-Inch 1080p...
Philips Magnavox 32MT3305 keeps shutting off with relay clicking. The green power light stays on but the picture and sound go out right after the orange status bar goes away. If the channel up or down...
the relay is the safety protective device..sometimes a defective component or something. maybe an overloaded power supply might caused this problem..so before any thing could gets worst..the relay will shut the unit..
Jul 18, 2011 | Philips 32MT3305 TV
I have a Sharp LC-46E77UN TV. Remote will start TV green light on. No picture, just stays black. PVR is on and connected to TV via HDMI cable. Cannot turn off green light. Must use power button on TV and...
THe problem is in the set top box. Or common called the tuner box. IT looses the 5 volts to the main display and thus the monitor will go into a shut down state. THESE boxes are factory repair only and must be sent off to repair.
Feb 20, 2011 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
How do you adjust volume on tomtom one
While riding, tap a corner of the status bar
  1. Horizontal status bar on the left corner where is shows the directional arrows
  2. Vertical status bar: On the top corner, where directional arrow are shown
After you tap the correct corner of the status bar, a volume slider appears at the bottom of screen. Move slider to the right to increase volume, or to the left to decrease volume.
Jan 02, 2010 | Tomtom ONE GPS Receiver
How do you adjust the volume on the reciver
Magnavox MS3252S431
Replace:
Q7461 C33725
O7463 C32725
C2455 47uF@50V
May 23, 2008 | Proton MM2701VT 27" TV
Magnavox MS3252S431
Replace:
Q7461 33725
Q7463 32725
C2455 47uF@50V
May 22, 2008 | Proton MM2701VT 27" TV
DLP HL-R5067W
Your model has a maximum resolution of 720p. What you might want to do is make sure that both your cable/sat box and game stations are outputting at no more than 720 resolution. It's easy to assume that all HDTVs may accept a higher signal, and while they might, some of the scene changes or handshakes may make that operation cause the symptoms you describe.
Feb 08, 2008 | Samsung DLP HL-P5663W 56" TV
Mitsubishi WD-73640 73-Inch 1080p Projection TV Logo
22 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
