Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Red color domination on tv - Sony FD Trinitron WEGA KV-32FS120 32" TV
    Top Expert:
  • Sony Master
  • 75,304 Answers
Check all the solder terminals at its video output card, for any loose soldering. Re-solder all the suspected solder terminals, by applying a lit tile more solder to each terminals. This video output card can be located at the neck of the picture tube itself, will directly plugged on to the back of the CRT. Check all the solder terminals of CRT base connecting socket too. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/Pull up older posts.
Posted on Dec 31, 2013
  • matt martin
    matt martin Jul 08, 2014
    You have a bad picture tube. There are three color guns in this picture tube. The green gun is shorting. You could opt for a picture tube tester to burn it clean, chances are this TV has outlived this. Good advice...go find a new TV. Thanks for asking, Matt of Martins TV.
TV has RED and GREEN colors distorting the color output of the TV. Can not simply adjust color and hue. Red and Green still remains controlling and dominant. How do I fix this?
If it does this on all inputs then it is the tv itself. You can try different sources and cables to see if the problem is not the tv. If the problem is the tv I would suggest having the tv repaired. It looks like a nice unit so it would probably be worth fixing. I would find a reputable local shop to take it to.
May 25, 2015 | Sony Bravia KDL60EX720 60-inch 3D LED TV
Sont Projection Tv colors
Your red tube is weak or defective. If weak, gain can be adjusted up on the red tube.(cheapest cost) If red tube circuit is defective that will have to be fixed by a technician.(cost between $100 to $200) If tube is worn out, it will have to be replaced(250 to 500). Any work should be done by a qualified tech. Prices will vary depending on your area.
If set is over 5 years old, I recommend replacement.
Mar 13, 2014 | Televison & Video
Colors are way off. Too much orange, colors eratic.
You need a convergence kit. Search Goo*le and tvrepairkits.com will have a kit make for your specific tv.
Replace with the kit and your colors will be better than ever!
Thank you!
Jun 14, 2011 | Hitachi 57F510 57" Rear Projection...
I have a 55" rear
U tries go into the tv colors setup and turn down the color RED,might help?Tv could have a problems known a convergence problems,it dead very common problems for old DLP tvs.The tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board.The tv convergence board require changes 2 STK convergence ICS and some or all of it resitors too.For fixing the convergence board to solved convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 08, 2011 | Hitachi Televison & Video
Its glittery white because i briten the color but when darken it gets green
you must re-adjust in the RGB (Red-Green-Blue) setting. depending on the brand of your TV, because there are set manually from the TV (you must open the cover of the rear of the TV). and there is a set directly from the remote only, with the open "factory settings", then you can re-adjust RGB color, especially green, not too dominant with the other colors (RED-BLUE). how to set is that you need to neutralize the color, (color TV sets to zero level) so that the image becomes black and white. if the green is too dominant, then Decrease the level of Green Bias or Green Cut off/ G-drive.
Aug 05, 2010 | Televison & Video
TV Flickers up and down and screen is shifted to the right w/ red color dominating the screen.
Hi
The most likely problem is the auto focus module.
A costly repair.
If you are going to fix it ask for a rebuilt one.
Part# CS00022 R
Feb 29, 2008 | Hitachi 50UX58B 50" Rear Projection...
Tube set zenith tv
This is very typical of a Zenith set.Your picture tube will have to be replaced.One of your 3 primary colors (red,green,&blue) have turned off leaving you with the color of the dominant color.I would heave it.
Feb 10, 2008 | Televison & Video
SONY 57' HDTV color projection TV, red color dominance on-screen
these tv's have a problem with bad crt's you could try to replace the red but a better choice would be all three
Oct 22, 2007 | Sony KP-57WS500 57" Rear Projection...
Picture problems
CRT green gun is not working properly , maybe dry soldered or no green drive signal. Pink and red colour is due to missing of green colour.
Sep 09, 2007 | Sanyo DS27820 27" TV
the last hitachi that had this problem i fixed it bad finding bad solder conenctions throughout the board that the convergance ic's are on, also i foind some on the two main board in my repair. hopefully resoldering the convergance foard will fix the jitter or jumping around problem. if the picture is too red you can also try turning down the screen control slightly. good luck
Jan 02, 2007 | Hitachi 51F500 51" Rear Projection...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
67 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
