Question about Dryers
Starts automatically when I set the timer
My Kenmore gas dryer starts running as soon as I set the timer (without pushing the SART button. And when the timer gets to (0), The buzzer sounds and won't stop until you open the door or turn the signal off. I also think that after the timer gets to (0),the timer dial is still going because the dryer was running again after I was upstairs for a couple of minutes, it was on the next cycle around the dial.
  • Dryers Master
  • 8,220 Answers
Replace the start button. if i am not ostaken this strat button is a small black box shaped switch with 4 wires.(useless mexitronics,my opinion). To replace this one you simple release the tab and twist the switch a quater turn and it will drop out. No need to destroy the whole dayum front panel amig. LOL
Posted on May 20, 2009
  • 585 Answers
This could be a problem with the start button switch (it should click when pressed/released) or with the switch on the motor.
Dryer stops but the timer continues on
Fixed! The "push to start" button was stuck. Must have been some dust. I pushed the knob a few times and that's all it took. Works fine now.
Dec 12, 2009 | Kenmore Dryers
Kenmore mod 110 87870110 gas dryer- at first push
the vent could be plugged and unit is going into thermal overheat if it works in timed dry properly then the moistier sensor is faulty.
Dec 01, 2009 | Kenmore Dryers
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer keeps on going and going
The timer is bad. It is located behind the knobs and can be replaced really easily. The price for a new timer is about 35 dollars. If this helped please rate
Feb 12, 2009 | Kenmore 64902 Electric Dryer
Kenmore model 110.63932102 Dryer will run, however the timer does not move. We also have to play with the start button to get it to start some times. Opening the door does not break the cycle and as soon...
1. Opening the door does not break the cycle
The door switch needs to be replaced
2. the timer does not move
The timer should be replaced
3. Start button
This could be in the start button or at the motor
Dec 17, 2008 | Kenmore Dryers
My Kenmore dryer turns on as soon as the timer is set .
Two possibilities:
1) Least likely cause. Start button is not opening when released. Don't know how far you wish to go with this but it will require some troubleshooting.
2) Most likely cause. Motor start switch has a set of contacts that close when the dryer starts and this set of contacts "seals" around the push button. If this is the case, a new switch is in order. Switch is normally replaceable without replacing the motor.
Other option is use "as is".
Nov 20, 2008 | Kenmore 62602 Electric Dryer
Kenmore Dryer
The start button works like a push-on switch that engages the timer switch. It's all one unit. It isn't engaging because the internal lever the engages the switch is either broken or worn out. The start timer/switch will need to be replaced.
Jul 09, 2007 | Fisher and Paykel DG05 Gas Dryer
Dryers Logo
166 people viewed this question
Top Dryers Experts
