Question about HP ac200w Action Cam
My HP AC200W Stuck in wifi mode when i turn off the wifi the camera also turns off,what's the problem??
I found a solution to the problem when the camera is blocked, when changing modes having this. I had this problem, and what I did was "off" or "forget network" for the option that gives us the HP Xcam app! to see what the camera is seeing with WIFI coneccion. It was this simple solution to the problem under lock me.
I guess it lacks any supplement or pluggin for this function to see what will record work perfectly.
I hope this information will help many.
Posted on Feb 03, 2015
2 Suggested Answers
SOURCE: HP Digital Camera - M425 - Stuck in review mode, won't switch to capture mode
I just fixed my daughters camera with this problem. First go to the capture mode and see if the reason you are in review mode is because the camera thinks it is docked. If so, look at the dock port on the bottom of the camera. ( May need to magnify it to see in there ) Look for any green corrosion between the contacts. Her's has this corossion between two pairs of the contacts. I took a jewelers screw driver and scraped out the corrosion and then blew canned air in there to remove it. Turned it on and now it works fine. I have a feeling that the battery compartment is venting through this port and the small amount of acid vapor produced as the batteries discharge is causing the contacts to get this corrosion.
Posted on Nov 05, 2008
HP 4515 internal reliance monitor printer seems to be stuck in this mode.
new more info, lots more
what is stuck
what mode is it stuck
even show pictures, omg.
do the HP long reset yet?
1.
Restart the computer.
2.
Reset the printer.
a.
Turn off the printer and unplug the power cord.
b.
Wait a minute, then plug the power cord back in
and turn on the printer.
are the drivers loaded? for HP this printer and your unstated OS?
https://support.hp.com/us-en/product/hp-deskjet-ink-advantage-4510-e-all-in-one-printer-series/5285997/model/5383027/manuals
Apr 10, 2017 | HP Computers & Internet
How do I disable wifi on the S9700? The disable function cannot be selected when going through the menu process
The default is OFF. If you turn the camera OFF and then back on the default mode is enabled. The wifi will be off.
Jun 09, 2015 | Nikon COOLPIX S9700 Digital Camera Black
I AM UNABLE TO CONNECT THE SMART PHONE TO THE NIKON AW120. IT DOES NOT ALLOW ME TO GO THERE IN THE CAMERA
I do NOT have this camera. The Camera has to be in WIFI mode. (This mode uses more power) If you have done that you have to have a APP (Nikon WMU) on your Phone. If you do NOT connect rather quickly to the Camera it may shut OFF WIFI Again the WIFI really uses more power so if you do not connect it will turn it off. This may drive you nuts. Please make sure the batteries in the camera are fully charged and make sure for a test they are near each other.
Jan 04, 2015 | Nikon COOLPIX AW120 Waterproof Digital...
When i turn the camera on and switch to picture mode the screen is completely black, and if i take a picture, the picture turns out completely black
Very easy to fix for your camera. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Recommend Fix 5A in the link, by gently flicking with your fingertip as described in the article.
Dec 22, 2010 | Canon PowerShot SD1000 Digital Camera
How to turn of the flash and on the wifi in nikon S52 digital camera?
Press up on the multiselector to set flash mode, then select Off.
For the other modes, refer to "Using the Flash" in the manual.
May 06, 2009 | Nikon COOLPIX S52 Digital Camera
Jan 13, 2008 | HP Photosmart M425 Digital Camera
Camera-video mode
Is it a switch or a dial? have you tried new batteries?have you removed them and let the camera sit with the batteries out over night? The button or mode switch could be bad.
Apr 09, 2006 | Fuji FinePix 2650 Digital Camera
HP ac200w Action Cam Logo
123 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
