Question about Maytag Neptune MAH5500B Front Load Washer
Cold water just stopped flowing in,hot works
The machine had been working fine, then the cold water just stopped flowing in, only the hot water works.The machine is still under warranty,but we do not know who to contact.
  • 192 Answers
There are two electronically controlled valves in the back of the machine; one for hot water and the other for cold. It sounds like your cold valve is stuck closed or not getting the electronic signal to open. I recommend going to the following web site or calling 1-800-344-1274 for help from Maytag. They will want to know your model number and serial number so try to have that information handy when you call.
http://www.maytag.com/support/contact_us.jsp
Posted on May 20, 2009
Why would the hot water cycle of my washing machine not work?
The solenoid that opens to admit hot water is either defective or not being energized by control panel.
Jun 20, 2017 | Washing Machines
Hot/cold cycle stops before filling up
Your washer has a set amount of time to fill. If the flow is low and the time runs out, then all you will get is the amount of water that was able to fill. Check your lines to be sure that they all fully opened.
Aug 12, 2012 | Admiral 32 cu. ft. Washer
Water fm the cold side have very low flow. have check the hose for clog..clear. check the supply. strong. when the sector switch in the hot or hot/cold water flows but on cold low flow. unit is...
You need to replace the water inlet valve. Since you confirmed that the hot water side works fine, the cold water side is not allow a good water flow. It is a relatively easy repair. The part can be obtained a any local appliance supply house or online. To repair, disconnect the supply hoses to the machine, remove the back panel and the part is behind the panel. Hope this helps you.
Nov 08, 2010 | Whirlpool Washing Machines
Hi there my hotpoint washing machinewma 54 fills up without the machine being on
Hello. your fill valve is faulty and needs to be replaced.
here is how the fill valve is supposed to work:
The fill valve--which is about the size of a coffee cup--is sometimes also called a "water inlet valve." It controls the entry of hot and cold water into the machine. The valve has three major components:
  • A hot-water solenoid
  • A cold-water solenoid
  • A mixing valve body
The inlet valve has three hoses connected to it, for :
  • The hot water from the house
  • The cold water from the house
  • The water directed into the washing machine's inner tub (either hot or cold, or both) to fill it with water
When electricity flows to one or both solenoids, water flows through the valve into the washing machine's inner tub. When the electricity stops, the water also stops.
Aug 21, 2009 | Washing Machines
Slow cold water flow won't go back to full flow
I think the water inlet valve is nearly stopped up with sediment in the screen filter where the supply hose screws to the valve.Cut the water off at the hose and disconnect and look for the screen. The hot water usually doensn't do this because the water has time to settle everything out while it's in the hot water heater.
Aug 15, 2009 | Washing Machines
Cold water flows just fine, within 2 minutes the flow is down to
Make sure you clean both screens at each end of hose. If they are clean,you got dirt caught in valve. Good luck.
Jul 17, 2009 | GE Washing Machines
No cold rinse, only hot
Either the wires have come loose on the water valve or you have a defective water valve.Open the lid and look at the water valve. Are all wires connected?
If yes, replace the water valve.
Jun 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Cold water only works on rinse cylce not was
post model number in problem description
Apr 04, 2009 | Maytag Washing Machines
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
143 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
