Question about Garmin nuvi 255W GPS Receiver
PROBLEM UPDATING MAPS
Purchased a Garmin 255w, registered device on garmin website,proceeded to download update for map, download failed at 73%. Tried again, same thing. Spent 2 hrs with garmin tech support only to have them tell me to return it and exchange for a new one. Brought new on home, same experience with download exactly at 73%. Spent another 2 hrs on website and phone. Message on gps unit reads "No Detailed Maps Found That Support Routing". Followed instructions on website FAQ covering message on unit but when it says "touch map info" this button is grayed out and is unusable. Can you help me before I return it once again and exchange it for a different manufacturer.
    Scholar:
  • Garmin Expert
  • 186 Answers
Plug your GPS into your PC and do not use the Garmin Express program. It will mount as a drive. Delete the maps and software. Then run Garmin Express and do a complete install of the maps and software.
Posted on Apr 12, 2017
bestdarngood
  • 3037 Answers
SOURCE: No detailed maps found to support routing
Have you tried updating the unit at Garmin's Website?
Let me know if you need help, I can get you the right web-link if needed.
Benjamin
Posted on Feb 28, 2009
SOURCE: My Garmin Nuvi 255w Car Gps
You must call Garmin at 1-800-800-1020 they will walk you through plugging in nuvi to your computer (must have usb cord) and it will upload then go to my computer and choose garmin drive then click garmin folder and either find the folder they say or make new one like I did with the guy on the phone and put in code. The only information needed is the numbers on the bottom of the device.... super fast fix!
Posted on Mar 12, 2009
SOURCE: When i turn on my Garmin Nuvi 255w, the screen
Didn't work, Garmin has restored map available on their web site.
Posted on Dec 23, 2009
  • 7 Answers
SOURCE: WHEN I POWER ON MY NUVI 255W IT SAYS NO DETAILED
sounds like the map folder in the gps software got corrupted. you will have to connect your device to your computer, get on the Garmin website, and let the garmin site update your device. Once updated, it will re-install the correct folders and maps to their proper place. the gps should work as before after that.
Posted on Mar 31, 2010
  • 1514 Answers
SOURCE: after i updated my nuvi 255w now it is saying ''
The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
To retrieve unlock codes you need to have your satnav registered with garmin. If you haven't already registered it connect the satnav to your computer and go to https://my.garmin.com/mygarmin/customers/myGarminHome.faces and click Register your garmin device. Follow the prompts. You'll be asked to create a username and password. Write them down and keep them safe. You'll need them anytime you need to update your maps or solve problems in the future.
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
  1. Plug your Garmin device into the USB port
  2. Double-Click on My Computer or Computer located on the desktop
  3. Right-Click on the Garmin or nuvi drive
  4. Click Explore
  5. Double-Click on the Garmin folder
  6. Right-Click in a blank space in this window
  7. Move your mouse over the word New
  8. Select Text Document
  9. Press Enter / Return on your keyboard
  10. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  11. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  14. Change the Save As Type to All Files
  15. Type gmapprom.unl in all lower-case letters for the File name
  16. Select Save
  17. Close the Notepad window
  18. Delete the New Text Document file
  19. Disconnect the GPS device from your computer
Creating an unlock code file for Mac:
  1. Open the TextEdit application located in the Applications folder on the Mac HD
  2. Click Format
  3. Select Make Plain Text
  4. Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
  5. Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
  6. Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
If you have a second maps you may also need to unlock it e.g. if the first map is USA and second is EUROPE this may also need to be unlocked
  4. Click Explore
  11. Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  15. Type gmapprom1.unl in all lower-case letters for the File name
  16. Select Save
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
  5. Select the checkbox next to the maps to be enabled on the device
Posted on Sep 21, 2010
Update file on garmin corrupted
Same happened to my Garmin Nuvi 760, power failed during upload. Files corrupted. Garmin could not locate it with Sat. Told me to trash it and they would give me $70 towards purchase of a new one, which would not fit in my cars receiver. My solution was to purchase a used one that had a good Garmin File folder. I copied the folder to my pc. It was important to remove the device file from the copied folder. I then formatted my corrupted 760. Then copied the folder from my pc into the formatted 760. Next step was to use Garmin Express to replace the missing device file, do the updates, and reinstall the maps. Product code to unlock maps was inside the rear plastic housing to unlock the maps. Whole process took about 4 hours and it works like new now.
May 02, 2012 | Garmin nuvi 255W GPS Receiver
How do I update maps on my Sat Nav
Welcome to FixYa!
  • To update your Garmin device, go to his linkhttps://my.garmin.com/maps/chooseDeviceType.htm?
  • Select your device type.
  • It will request to install the Gamin Communicator Plug-in.
  • Make sure that you connect your Garmin device to the computer before proceeding to install.
  • After the installation, it will automatically download for an updated map.
Note: Sometimes, there a re no available updated maps.
To confirm if there a re available maps, contact Garmin:
Monday - Thursday: 8 AM - 6 PM, Friday 8 AM - 5 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
Thank you for using FixYa.
Have a great day.
Jas247
Jul 12, 2011 | Garmin nuvi 255W GPS Receiver
How do i download a maps update on my nuvi 300
Garmin offers two kinds of updates on its website: software updates are free. Map updates are not. You'll need a USB cable to connect the Garmin to your computer. Then go to http://www.garmin.com
On the web site, first register your product. Then look for "Support" and follow their instructions for updating your software. After you've done that, look for "Maps" on the menu at the top of the screen. You can either purchase updates one at a time, or buy a lifetime (of your device) subscription. By the way, maps are huge files, so plan on it taking several hours to update your maps even with a fast internet connection
Jun 17, 2011 | Garmin n vi 300 GPS Receiver
Need too know how or get some help updating my Garmin?
On the web site, first register your product. Then look for "Support" and follow their instructions for updating your software. After you've done that, look for "Maps" on the menu at the top of the screen. You can either purchase updates one at a time, or buy a lifetime (of your device) subscription. By the way, maps are huge files, so plan on it taking several hours to update your maps even with a fast internet connection.
Apr 18, 2011 | GPS
We have a garmin nuvi 255w. We need to know what is the latest map update. Our gps has "CN North America, NT 2010.30" version on it. Is ther something newer than this.
Maps for most GPS devices are updated several times a year. Your map is from 2010 and should be updated. You can go to the garmin site and pay to download and install upgraded maps or do a google search for map upgrades and you'll find some services offering lifetime upgrades for a few dollars more than the Garmin one time upgrade. I did this and have had no problems updating the maps on my Garmin Nuvi 250.
Mar 13, 2011 | Garmin nuvi 255W GPS Receiver
I was just given the Garmin 255W as a Christmas gift.Can you purchase the lifetime maps or do you have to pay for each update after the 60 day free update is over.
There are no lifetime maps for your Garmin nuvi. Garmin updates their maps over time, so there are no lifetime maps available for the device. There are free maps and you can buy maps from Garmins website.
Dec 28, 2010 | Garmin nuvi 255W GPS Receiver
Dont know how to get new maps
https://my.garmin.com/maps/nuMaps.htm
follow this link. If your first registering the unit. They give you first 60 days to download one free map update. Or you can purchase new maps by clicking the map updates link on the page.
thank you,
Lee
Sep 08, 2009 | Garmin nuvi 255W GPS Receiver
Attempts to download new maps failed even after updating software
You may need to contact Garmin Support at their website and have them mail you a CD.
Apr 06, 2009 | Garmin StreetPilot C330 GPS Receiver
Benjamin
Feb 28, 2009 | Garmin nuvi 255W GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
824 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
