Question about RCA P61830BL 61" Rear Projection Television
RCA Model P61830BL will not power up. Is there a fuse?
We have tried to power it up from the front panel switch, have unplugged it for several hours and tried again - still nothing. Is ther a changeable fuse?
2 Suggested Answers
fillmore85
  • 62 Answers
SOURCE: My RCA Bigscreen HDTV will not turn on.
If this is similar to the d52w20 then I almost garantee you need to replace a capacitor. You can check to make sure that's what you need by unplugging the tv, taking off the back cover and feeling the top of 3 capacitors. On my d52w20, CP150 (rated at 2200uf 16V) was blown and the top was bulged out. You should also check CP120 and CP114 to see if either are blown. I don't have a clear picture of where it's located, but I have a picture of what you should see after you take off the back cover.
http://i265.photobucket.com/albums/ii209/fillmore85welder/KodakMoment003-1.jpg
In the middle of the picture you see an aluminum heatsink in the shape of a 'C' with the opening facing away from you. That is where CP150 is located. CP120 and CP114 should be located nearby, but if you can feel a bulge on any of the tops of those 3 capacitors replacing them should fix your problem. Replace the existing capacitors with a higher voltage rating of either 25v or 35v.
"4 capacitors on the power/deflection board. CP110 220uf 200v. CP120 220uf 35 Volts. CP114 220uf 35 volts. CP150 2200 16 volt. also check entire delfection board for cold solder especially around flyback. bad connections here can cause problems like some of the fp fuses blowing and cutting off convergence supply"
Posted on Jun 04, 2009
Hello...Have RCA L40FHD41YX9 ,serial number J203C40GV. Watching t.v., picture and sound go. Unplug, then replug...blue light in front, but still no picture or sound. Please advise
Fred, Unplug for a couple hours then try, if does not reset, board,capacitors or power supply gone bad.
Check the attached links for TV's problem.,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Fix Your TV Instantly
how to fix 42 RCA flat screen
RCA 276046 Power Supply Unit PSU Boards Replacement Guide for RCA LCD TV...
http://v6.tvrepairtips.org/anon/supertips?page=1&make=&model=LTV46W1%20HD&problem=
Mar 07, 2016 | RCA Televison & Video
I have an RCA 32" LCD HDTV/DVD Combo model 32LB30RQD it has power, but no picture or sound and no turn off the blue power light.
Probable defective power supply board in the set. ebay RCA model # for replacement power board. Replace board
Dec 29, 2014 | RCA Televison & Video
Won't turn on
Unplug the unit , leave it unplugged, after an hour remove the top cover, look for a fuse near where the power cord enters the unit
. it will be near the power transformer and labeled F1 they are usually 4.5amp 125/250v. the reason for powering the unit down and leaving it off is to let the power capacitors bleed off.some fuses are in holders and some solder in. Hope this helps. If the unit has a bar code anywhere on it you can read the bar code with an app for cell phones and get all the info there. Also try schematicsunlimited.com
Apr 29, 2014 | RCA RTD615I 5.1 Home Theater System - 600...
46LA45R RCA 46" TV does not power up following a power loss
If a power loss someone needs to open set and see if when power came back it popped the line fuse, follow power cord inside to the fuse which it goes directly to.
Dec 11, 2012 | RCA 46 46LA45RQ LCD TV
Have a projection tv...RCA model 61830BL. Had
Hi the green cross it cant move that the reference for red and blue adjustement ;just try to put the red and blue cross over the green pattern then quit/
if that doesnt work you probly have the stk-xxx ic
who control the color alignment ,are blow/
you will have to replaced and make the convergence
check if you have an auto adjustement for that most projection tv have one...
hope that help..
Mar 28, 2010 | RCA P61830BL 61" Rear Projection...
Front panel
Either replace front panel board or all contact switches on that board the one with vol- vol+ ch- ch+ power, menu.
Dec 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Projection TV - RCA P61830BL
Hello, I have a Tv RCA P61830BL, I need a new convergence board but cannot find out where I can purchase one from. Can you help?
Aug 25, 2007 | RCA P61830BL 61" Rear Projection...
TV turns off than on, off than on, until I unplug it.
If you haven't tried this, go into the menu, under "Time" see if the "time on" and "time off" feature is on, if so, turn it off.
Jul 15, 2007 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
123 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
