Question about Xerox Office Equipment & Supplies
Tally5 accounts purpose
Which code no. we use to remove the error fuser temp... printer 3100mfp
    New Friend:
    Problem Solver:
  • 5 Answers
Printer supply cheke
Posted on Dec 31, 2013
5 Suggested Answers
  • 191 Answers
SOURCE: i own a Xerox Phaser 3100MFP and it keeps giving
please your xerox phaser is in fuser light is checked is not courently okthis parts is damaze? then changing the fuser temp and new added.
Posted on Sep 22, 2009
  • 78 Answers
SOURCE: model - Xerox phaser 3100mfp - while installation
could be faulty fuser.or you could remove and re instal fuser
Posted on Nov 30, 2009
SOURCE: Printer Error Fuser Temp. in xerox 3100mfp
SISODIYA COMPUTERS "I AM SOLVE THE PROBLEM FUSER TEMP ERROR "
BUTTON FAST PRESS STEP BY STEP
LET'S START
PREES- MENU BUTTON
* BUTTON(THIS IS STAR BUTTON)
# BUTTON
1 BUTTON
OK BUTTON
STOP BUTTON
MENU BUTTON
# BUTTON
^ BUTTON(THIS UP ARROW BUTTON)
OK BUTTON
YOU LAST BUTTON PRESS OK AND POWER "OFF" AND WAIT UNTIL 15 MINUTE AND PRINTER START PROMBLEM IS SOLVE FUSER TEMP
Posted on Jul 04, 2010
  • 525 Answers
SOURCE: Multifunction /Copier/Scanner Laser Printer Printer
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Then replace broken part.
Posted on Jan 21, 2011
Printer error fuser temp
You can find answers to Xerox questions at www.xerox.com/support
Solutions for : Printer Error Fuser Temp Message There are two configuration options available for this model; the Phaser 3100MFP/X and the Phaser 3100MFP/S. Fax features are only available on the Phaser 3100MFP/X. To determine the configuration of your machine, print a Configuration Page. See the Related Items below for additional information.
Solutions ranked by relevance:
  1. Make Sure the Power Cord is Securely Connected to the Machine and the Electrical Outlet
  2. Make Sure the Machine is Plugged Into a Functional and Stable Power Outlet Test the power outlet that the machine is plugged in to by connecting another device to the outlet. Make sure the outlet is functional and stable. If possible, have the line tested by an electrician. If necessary, plug the machine into another power outlet.
    NOTE: The machine should be plugged directly into the wall outlet, and should not be connected to an extension cord, power strip, or Uninterruptible Power Supply (UPS).
  3. Reset the Fuser Error Solution : Reset the Fuser Error CAUTION: The following solution will put the printer in the Diagnostics mode and is only valid for this problem. Follow the steps carefully; any deviation from the process can cause other settings to be changed and / or render the machine inoperable.
    If at any time it is necessary to cancel the procedure and start again with step 1, press the [Stop] button four times.
    NOTE: This procedure will delete all pending jobs that have been sent to the machine.
    To reset the Fuser error:
    (Click on one of the following links to jump to the corresponding section.)
    To reset the Fuser error for the Phaser 3100MFP / X
    1. Press the [Down] arrow (Menu) button on the Control Panel.
    2. Press the asterisk [*] button.
    3. Press the pound [#] button.
    4. Press the [OK] button.
    5. Press the [1] button. ("00100001" changes to "10100001" at SOS1)
    6. Press the [OK] button.
    7. Press the [Stop] button.
    8. Press the [Down] arrow (Menu) button.
    9. Press the pound [#] button.
    10. Press the [T] button on the keyboard. (Do not use the numeric keypad.)
    11. Press the [OK] button.
    12. Power the machine off, and then power the machine on.
    13. Press the [Down] arrow (Menu) button.
    14. Press the asterisk [*] button.
    15. Press the pound [#] button.
    16. Press the [OK] button.
    17. Press the zero [0] button. ("10100001" changes back to "00100001" at SOS1)
    18. Press the [OK] button.
    19. Press the [Stop] button.
    20. Make a copy to check machine operation.
    To reset the Fuser error for the Phaser 3100MFP / S
    10. Press the [Down] arrow (Menu) button until "T>>Printer" is selected.
Nov 27, 2013 | Xerox Phaser 3100MFP/S Laser Printer
How to Slove Fuser Temp. (XEROX 3100 MFP)
I have been struggling throughout the night to remove the Printing error Fuser temp following the suggested given but all were in vain. By accidently I managed to remover the error message by pressing # together* then switch on... super! vilho nhoni from Namibia
Jun 16, 2011 | Xerox Phaser 3100MFP/S Laser Printer
Screen displays "printer error fuser temp"
Disassemble fuser unit and inspect thermistor and thermostat for dirt or damges, and heater lamp for damages.
Good luck.
Feb 08, 2011 | Xerox Phaser 3100MFP/S Laser Printer
Multifunction /Copier/Scanner Laser Printer Printer Error Fuser Temp. in xerox 3100mfp
Sep 15, 2010 | Xerox Phaser 3100MFP/S Laser Printer
LET'S START
PREES- MENU BUTTON
# BUTTON
1 BUTTON
OK BUTTON
STOP BUTTON
MENU BUTTON
# BUTTON
OK BUTTON
Mar 12, 2010 | Xerox Phaser 3100MFP/S Laser Printer
You will have to replace the fuser. Call 1-800-835-6100 and follow the prompts to purchase parts. It isnt real expensive. Just make sure you still don't have some warranty left on the parts.
Mar 09, 2010 | Xerox Phaser 3100MFP/S Laser Printer
I own a Xerox Phaser 3100MFP and it keeps giving me an error message saying "Printer error Fuser temp"...Help
Sep 22, 2009 | Xerox Phaser 3100MFP/S Laser Printer
12 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
