Question about Kenmore 66832 Dryer
Dryer stopped working/appears to have no power, circut breaker not tripped...could a very small object (wire earing) that was caught in door mess with the door sencor (object has been removed-still no
The dryer worked, never any problems, up to this last load but now not power... light is off inside, no breakers stipped can you help?
  • tnixon62 May 20, 2009
    Yeah, well did that multiple times to no avale before asking. Anyone have any suggestions for possible causes or fixes? Thanks honeymokey for the attempt.
    President:
  • 3,113 Answers
Push the breaker down to off and reset.
Posted on May 20, 2009
  • honeymokey
    honeymokey May 20, 2009
    Get a voltage tester and check the voltage from outlet . Then follow the wires to the back and check there. This unit may have a fuse, but I will need a model number.
Siemens tumble dryer E46.38 no power
if it hasnt tripped a circuit breaker
how old is it
the control board fault
inside the casing and around the drum
some have small sensors with wires
that can be faulty ant stop it heat up and tumble
faulty safety door catch
faulty sealed wall plug
Jun 08, 2016 | Siemens Dryers
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 | Dryers
New plug changed from a 4 wire to a 3wire,won't run.
You have 3 lugs to hook up to. right lug gets red or black, left lug gets red or black. Center lug gets white. you can also hook green wire to center with white. Or hook green to the screw for the lug cover. What you did is correct.
Jun 14, 2010 | Frigidaire GLEQ332A Electric Dryer
Our Kenmore dryer just stopped. It appears no
Try resetting the dual breakers in the house electrical panel--push off, then on. If works, ok. If the breakers trip again, look for a shorted (to case) heating element within the dryer. The drum must be removed to service the heater(s).
Nov 25, 2009 | Tools & Hardware - Others
Have a dedicater 220v 20a circut break to a clothes dryer. The only work done but the electrician was a new main grounding wire and removed conduit and wiring in the basement. Now the breaker opens after 1...
Typically, a standard electric dryer is 30A 240V unless it is natural gas. If the wire is #10awg then you can put a 30A circuit breaker on it. If the wire is #12awg then you DO NOT want to put a larger circuit breaker on it or it over heat the wiring in the wall. If it was a short in the wiring the circuit breaker would trip immediately even with out the dryer plugged in. If it was a grounding problem the circuit breaker would not trip at all, it would just electrify the dryer chasis. It sounds like it is an over current problem, drawing more than 20 amps through the circuit breaker, or like the dryer has an internal problem that is causing the circuit breaker to trip.
Nov 21, 2009 | Gb Electrical 100 Amp GE Load Center
I have a Speed Queen dryer that just stopped last night. There appears to be no power getting to the unit--dryer does not start, light does not come on, timer does not advance--yet the circuit breaker...
Hello
Is there power at the dryer receptacle? Is the dryer wired directly or does wire from electrical breaker go to a receptacle first? Have it checked with a meter. If unit is wired directly have it changed to a receptacle and cord. Make sure there is power at the connections on the dryer. If everything is okay, then it is a dryer problem
John
Nov 09, 2009 | Speed Queen AES68AWF Dryer
Suddenly stopped working will not start at all any setting
assuming that the circuit breaker or fuse is not blown, this is most likely caused by the door switch. if the door is not closed, the dryer will not turn on, period. you will have to try to jump over the 'possibly bad' switch. first, shut off the breaker. second, wrap a putty knife with masking tape to prevent scratching up the dryer. then, use it to pop open the plastic catch on each front corner. take your time and look inside the small gap with a flashlight to help figure it out. after you have the top of the dryer safely tilted back, look for 2 wires running to the door. they will plug into a switch that is flipped when you close the door completely. you know what i mean, it probably used to click when you shut the door. unplug these wires from either side of the switch. use a piece of wire to connect them or just tape the metal ends together. this will bypass the door switch. make sure all metal parts of the wires are covered to prevent a short on the metal walls. be sure the now loose wires will not get caught on anything, like a rotating drum. close the lid most of the way. turn on the breaker and try to operate the dryer. if it now works, replace the door switch. be careful, opening the door will not shut off the dryer now. good luck
Nov 02, 2009 | Kenmore 62802 Electric Dryer
Lost power after opening door during cycle.
Try and flip the breaker to off again and push lightly then on , when a breaker trips somtimes just flipping it on it wont catch a latch inside the breaker to actually flip it on.
Oct 29, 2009 | Dryers
Maytag performa dryer quit working
Check your breaker first and then the wiring. Check power coming from the timer next. With a load and resistance that you had, you could have tripped one of the breakers.Since you have bypassed the thermal fuse, it probably is the timer switch.
Jan 26, 2009 | Maytag PYE2300AY Electric Dryer
This is the 2nd time my dryer in 1 year just stopped working and last time it cost me $100
http://www.repairclinic.com/0088_8_1.asp#Level1_1
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
There's no heat If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 23, 2008 | Frigidaire Dryers
Kenmore 66832 Dryer Logo
125 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
