Question about Sharp XR-11XC Multimedia Projector
My projector won't turn on. No fan or motor turns on.
The motor struggles to turn the fan on my Braun Paximat N24 slide projector. Any ideas please?
My guess is the sleeve bearings in the fan motor need oil. I use teflon based oil.
Jan 04, 2015 | Braun Office Equipment & Supplies
My projector won't turn on. I press the power button and the power/standby light turns on then turns off.
More than likely one of the fans is not running. That could be because of a blown in-circuit fuse or a bad fan motor.
Sep 30, 2014 | Sanyo PLC XF10NZ Multimedia Projector
My epson emp-74 won't show...the red light keeps on flashing
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Dec 06, 2012 | Epson (V13H010L32) Projector Lamp for...
Why won't my warning light turn off?
Probably a fan that doesn't rotate, or one of the many sub-voltages is absent on the mainboard due to short circuited capacitors ( SMD's)
Oct 25, 2012 | Eiki LC-SE10 Projector Multimedia...
Projector won't stay on, the projectors fan goes higher and then projector turns off
It appears that the mainboard is not getting a feedback from the fan movement. Check if any one of the fans is moving fast. If yes then this fan feedback is not being sensed by the motherboard. try to replace the fan by interchanging the fans if tge connectors are similar. trace tye fan circuit on the mainboard which finally sends the signals to the main chip on the motherboard.
May 19, 2012 | Christie Digital LX25 Multimedia Projector
Epson projector bulb won't turn on when rpalced
Apr 18, 2012 | Epson ELPLP09 Projector Lamp for PowerLite...
My LP70 INfocus projector fell then said one fan was not working, will turn off in a minute, and it did, now how do I fix the fan, get a fan part where and how? How much do repairs liek this cost? how...
Hello
Cooling fans have of different size and voltage ratings. The exact size is more important. You must have the damaged fan with you when you go to buy a new one. Its seating screw space, height, voltage ratings etc should be compared, and must be exact the same, otherwise the system main system control IC won't recogonise the replaced fan.
Actually this is a skilled work. If you have all the tools to open the projector, and have confidnce, go forward. Otherwise, get it repaired by any experienced service technician. OK.
Nov 22, 2011 | InFocus LP70+ Multimedia Projector
My projector won't turn on, only the power light shows red, the status light is blank. Tried the remote and manually turning it on.
Hello
If the power light is ON and status light is OFF; check if any objects are blocking the air inlet or outlet grill, and remove them if any, and carry out the following.
[1] Unplug the power cord from wall outlet.
[2] Make sure that the projector has cooled off.
[3] Plug the power cord into the wall socket.
[4] Press the power button.
Check whether the cooling fan has stopped. The problem is with overheating itself.
If these does not help you, your projector need service. OK.
Nov 18, 2011 | Mitsubishi HC1500 DLP Projector
Plugged in and turned on automatically said it overheated won't turn on or off
you fan could be bad and needs replaced try putting a a small fan next to the excaust vents than see if dies the same thing, if it does it could be than the fan needs to be replaced or the thermal sensor needs to be replaced. hope this helps
Jun 04, 2011 | Optoma DV11 Projector
I just bought a used NEC Multisync MT 840 projector with just over 600 hours on the lamp counter. I live in Japan. After about 4 or five minutes of working, the projector turns itself off and won't...
hi,
Possible problem is the faulty lamp cooling fan. Check the lamp cooling fan of your projector. if the RPM of fan is low then the lamp can get over heated. May be its has some problem.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector.
i have added a video how to oil the fan for make it easy for you.
ok
May 08, 2011 | NEC MultiSync MT840 Multimedia Projector
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
