Question about Nintendo DS Lite Console
Does not power up or turn on.
DS Lite is only 2 months old and today it stopped working.  Green power light only stays on for a second when turned on - and only when it is plugged in. When you plug it in, the red charging light stays on for a second then goes out. When it is NOT plugged in, no lights come on, even when you turn it on.  It was not dropped or damaged. It worked last night but this morning it does not. Thanks, Janet
  • 5 more comments
  • AtticusDS Oct 20, 2007
    I tried to charge it with the car adaptor - the red light just goes on for a second then shuts off, just like it does with the house charger.  How can I check to see if the battery will not accept a charge? I took it out and cleaned it like the first suggestion I was given.  Still not working.
  • ttoulou Nov 23, 2007
    my ds will not turn on, i replaced the battery with one already charged i left it plugged in all night for it to charge, and still nothing
  • Anonymous May 04, 2008
    Nintendo DS lite just over 1 year old and it will not turn on. try to charge didn't make any difference. tried friends battery in my machine didnt make a difference. When you press power button a flash happens on the screen then nothing
  • Anonymous Sep 30, 2008
    my ds won't do anything the orange light turns on when it is charging but it won't turn on!
  • Tessie123 Mar 08, 2009
    i was playing a game and then it froze and now it won't turn on and i tried charging it it won't turn on it will show the green light but there's no picture
  • Anonymous May 10, 2009
    i tried charging it
    i left it for a couple of months because i thought
    it would work afterward but it didn't
    where can i get it fixed in london
    for under 20
  • Anonymous May 12, 2009
    My daughters ds lite did the same thing.. She tried to turn it on and then it flashes right off. The screen doesn't even light up.... Any suggestions on what I can do? Or do I have to get a new one. This is her second DS lite this year and the first one did the same thing...
    Problem Solver:
  • 7 Answers
I think that this problem is caused by either f1 or f2 fuses being blown. The other problem mentioned where the green light comes on for a second then goes out again is usually caused by the cable connecting the top screen to the motherboard, it is either broken, damaged or incorrectly seated.
Posted on Nov 24, 2008
    Problem Solver:
  • 15 Answers
Most of the time its the top screen needs to be replaced since if you over extend the top screen flip by grabbing or pulling the connector can become faulty. Replace the top screen will probalble fix it.
Posted on Oct 30, 2011
I had the same problem. In my case, it was exposed to a tub of soapy liquid. I tried replacing the battery (didn't work) and tried tinkering around with it. I wound up just throwing it away. Still, there might be a chance that it can be fixed... maybe...
Posted on May 25, 2008
  • 64 Answers
Sounds like F2 on the bottom board has blown, I'd contact the retailer and if they're no use go direct to Nintendo, at 2 months old it should still be under warranty so I wouldn't want to touch it with a screwdriver.
Posted on Jan 08, 2008
Same here
Posted on Jan 05, 2008
    Problem Solver:
  • 3 Answers
It could be the power cord that is the problem, see if you can go to a shop or if you have a friend with one, see if you can borrow their cord to see if it works hope you find a sulution :)
Posted on Oct 20, 2007
Hey i have the same ds is not charging.I changed the charger.No good,still dosent work.Changed the battery,still dosent work.When i turn on the ds,it flashes the green light then gows out.
Posted on Aug 18, 2008
On power up the green light is on for 2 sec.
problem with the main board inside of the DS Lite. Its not staying on with the voltage being provided. To verify this. Plug your DS Lite into a working outlet and see if it stays on.
If it doesn't stay on then take the battery out and only hook up the ac adapter to it and see if it stays on.
At that point if it doesn't stay on, try to use another AC Adapter to see if it stays on, if it doesn't then you know for sure the main board is bad and you would need to get a new ds lite.
Jan 01, 2010 | Nintendo DS Lite Console
DS won't turn on
Hi Atticus,
I have seen this happen when someone plugs the wrong charging cord up to the DS lite, Is there any chance some one did this to your DS lite.It sounds also as if the battery is not making proper connection.
  1. REmove the battery from the compartment
  2. inspect the connector on the battery and where the battery connects to the DSlite.
  3. Wipe thee connections off some way. I suggest some contact cleaner for bith the battery and Battery compartment connections
  4. Try the DS lite again with the battery installed.
I hope this gets you in business  Atticus. Do not Vote until we get it working.  Try this and add a comment to this problem posting. I will answer as soon as I possibly can. Thank you very much for the opportunity to solve your porblem with a DS Lite.
Oct 18, 2007 | Nintendo DS Lite Console
I turn the DS lite power button on and the green
well go online type get ds fixed the they will tke it for 2 days
Oct 12, 2009 | Nintendo DS Lite Console
Green power lights on but both screens blank
ur ds froze or it did not turn on all the way.Take it to Game Stop
Aug 24, 2009 | Nintendo DS Lite Console
After charging, I try to turn it on and it flashes and turns off
wen u 1st got ur ds lite...u should of at least charged it for 5 hours and if u didnt u might need 2 by a new battery...
Dec 09, 2008 | Nintendo DS Lite Console
DS lite, power is on but nothing happens
Ditto... except my daughter is 10. Both screens remain black, are fully charged and green light stays on for more than 4 minutes.
Sep 14, 2008 | Nintendo DS Lite Console
Power problems with DS Lite
Really sounds like a dead battery. The DS will not work if the battery is bad even when it's plugged in. You get the quick flash of the power light and that's it.
Mar 29, 2008 | Nintendo DS Console
Nintendo ds lite - 2 months old
did you drop it a lot? If you did you may not be able to fix it...
Dec 26, 2007 | Nintendo DS Lite Console
Still not charging
i'm not sure that you can actually check if the battery does not accept charge, you might want to ring the distributer and see if they can send you a replacement battery :)
Oct 20, 2007 | Nintendo DS Lite Console
First Attempt to fix didn't work
that happened to me , i had to get a new one or i could wait about 2 mouthes 4 nintendo to put it up ,fix it, and send it back , so i got a new one , but go to or google it
Oct 19, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
1,454 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
