Question about Sewing Machines
Sunbeam how to use 70 stitch
How do I thread sewing machine 70 stitch SB700
bargainbox
  • 1388 Answers
SOURCE: My bottom thread is loose when sewing a straight stitch
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on Jul 24, 2008
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
  • 96 Answers
SOURCE: stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Posted on Dec 13, 2009
Sewtech1
  • 69 Answers
SOURCE: My Pfaff 7550 sewing machine will ball-up thread on underside
Make sure your tension is set on 5 and you don't have dirt stuck in your tension unit.
Posted on Jan 20, 2010
SOURCE: My sewing machine will not stitch, it is threaded right
how do you crrect the timing on a yamata 811
Posted on Dec 20, 2010
Sunbeam sb700 the thread will not come up from the bobbon when I turn the wheel.
Install a brand new needle and confirm it is installed facing the correct direction. If it still will not pull up the bobbin, the machine may be out of time. Search for sewing machine timing or take it for service.
May 28, 2017 | Sewing Machines
My pfaff2044 started sewing uneven stitches. It can sew nice then next second leave a big stretch then sew normal again and then itll leave a bigger stretch it also wont blind stitch.
3 Common Sewing Machine Problems (and How to Fix Them)
www.marthastewart.com/.../common-sewing-machine-rep...
Martha StewartSep 26, 2014 - We consulted Becky Hanson of Singer Sewing Company for her tips on ... The Problem: Stitches are coming out uneven or skipping entirely.
Basic Sewing Machine Troubleshooting - Sewing School
sewingschool.org/2011/03/16/basic-sewing-machine-troubleshooting/
Mar 16, 2011 - The thread breaks, my needle bends, or skipped stitches - UGH! Don't get ... Problem: My stitches are uneven and sometimes skipping!
My stitches are coming out uneven - SewingSupport.com
www.sewingsupport.com/sewing.../sewingsupport.../sewing.../my-stitches...
What to do if the stitches from your sewing machine are coming out uneven. Sewingmachine troubleshooting guide.
Dec 12, 2015 | Sewing Machines
Doesnt stitch
Do you chose the right spool and put it the right side up?
Apr 14, 2014 | Sunbeam SB1800 Compact Sewing Machine - -
I would like to know how to set the machine up for polyester/spandex material
You need a ball point size 70 or a jersey 70 if you can get it. Stitch length 2.3 to 2.5. Re tension, just normal tension setting. If the machine is sewing an evenly balanced zigzag on regular cotton fabric, then tension is fine. If you find the straight stitch on your fabric pops under stretch, then try using a very small zigzag to put some flexability into the seam.
Mar 28, 2013 | Bernina Activa 140
I cannot get my monogrammed letters to come out clear. what am I doing wrong?
Are you using interfacing or "stich and sew" type support under the fabric?
To get a good result you need to interface the fabric, and use machine embroidery thread to get a silky look to the stitching. If you are stitching onto linen then you can use a tear away stabiliser and go for a small sized needle, probably size 70.
Some machines may have a fine "stitch density" adjustment too that will allow you to stretch or close up the stitching to finesse how it looks.
However, if it seems to be missing/not fully catching the lower thread in some stitches, then your timing may be slightly out. Will it sew a wide zig zag okay?
Timing is probably best adjusted by a technician so if you try the above and its still not looking good, then take it for a service.
Oct 10, 2011 | PfaFF Creative 7570
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
Sewing Machines Logo
157 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
