Question about Hotpoint RGB745 Gas Kitchen Range
What does F-1 mean on the electronic display of stove?
On a hotpoint free standing gas range with electric ignition, the stove beeps and F-1 is displayed on the time rectangle. We no longer have the manual. The stove is approximately 10 to 15 years old. What does F-1 mean?
    Scholar:
  • 85 Answers
F1 is a failed thermistor control in the control board. Board must be replaced to fix. Part is in vicinity of $120.00
Posted on May 20, 2009
Why does my hotpoint, electric ignition gas stove beep -F1-
You are having connection issues, or a failing keypad. Disconnect the power. Pull down the control panel and disconnect the thin, flat ribbon connector that goes from the keypad to the control board, then re-connect the power and see if the F1 returns without the keypad attached. If it returns, get the computer board rebuilt at Corecentric Solutions. If the F1 doesn't return, buy a new keypad... Help Me Find My Model Number RepairClinic com
Jul 31, 2016 | Hotpoint Kitchen Ranges
I plug my gas stove in and the display says bad line and beeps steady
"bad line" error means the control panel is not seeing a proper voltage to the oven. Have the power connections checked with a voltmeter all the way to the control panel. If voltage is present, you may need a new control. 25316221-dz1fkxf1fwolart5ai0divhk-4-0.jpg
Dec 10, 2014 | Hotpoint RGB745 Gas Kitchen Range
Can't seem to access Hotpoint Stove Pilot Light?
Your range uses electronic ignition, not pilot lights. For surface burners the igniter sparks when the gas valve is turned to the "light" position. All burners should spark when any gas valve is in the light position. For the oven the ignitor is also electric but does not spark but rather heats up or glows. What is the problem with your range?
Nov 30, 2014 | Hotpoint RGB745 Gas Kitchen Range
My parents have a lofra 90cm gas stove and can't find the electric start for it. They are using a lighter to ignite it.
Purchased a Savoir-faire free-standing stove (model C900) about 5 years ago and need to replace the rubber seal (2270mm). Brand doesn't exist any more - where can I source this product?
Feb 24, 2011 | Lofra MXUD66GGI Gas Kitchen Range
Tappan gas range electric pilots will not light
The gas line in your Tappan could be closed or
stucked up. Have it check.
Sep 23, 2009 | Tappan TGF320 Gas Kitchen Range
My gas stove top and oven will not ignite . . . do I need to worry about an explosion before it can be fixed?
Hi, If this model has standing pilot lights, you need to turn the gas off. If this is an electonic/spark ignition stove, you will not need to worry about any gas excaping.
Vic
Jul 08, 2009 | Hotpoint RGB745 Gas Kitchen Range
"BAD LINE"
most likly it's a problem in the electrical going to the stove call an electrician
Jun 22, 2009 | Hotpoint RB526 Electric Kitchen Range
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 | Ovens
Hotpoint RGB745 Gas Kitchen Range Logo
328 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
