Question about City Interactive 2606 Code of Honor 3: Desperate Measures
Please insert code of honor 3 disc appears after installation of game
After the installation of game it does not run shows please insert disc
Game launch problem
Try taking the game from the disc,putting it on your desktop,then load it onto daemon tools and run from there,it could be a faulty disc drive,if not,it could be a faulty disc,try cleaning it,or for 2-3 pounds you could get it re-lasered in any decent games shop ;)
Mar 03, 2014 | Video Game Consoles & Games
Tip
Want to play your expensive PC game without damaging it ?
By far the best software to use is Slysoft's Game Jackal it allows you to save profiles of the discs not images so that when the shortcut to play is clicked it will know you have the disc that you installed the game with.
If works for about 90% of all games it's at v4.0.2.3 as of March 2010 you will have to pay but it's well worth it to prevent damage to your original disc.!!! Buy now this easter for a massive 25% off the lifetime license use the code FAIRUSE
http://static.slysoft.com/SetupGameJackal4023.exe
Simply the best Free application that is guaranteed to find just what you are looking for is PROTECTION iD by CDKiller and TippeX it will scan the executable file after the Game has been installed and identify the protection and the version that has been used.
Most PC games require the installed EXE file to search for the original game disc in the DVD or CD drive to allow the game to run if you use Alcohol52% Free Edtion data-type function you can create a disc image on your hard drive. This will allow you to fool the computer into thinking that the image has the correct protection that the game wants to find in order to run. Clever eh!!!
This has been tested on Tiger Woods PGA Tour 2008 which has SecuROM v7.33.0014 protection which Game Jackal can't handle at the moment...
SECUROM ERROR CODES
(1000) - Insert original instead of backup
(4001) - Please insert original disc instead of backup
(4003) - Take the disc out when it is trying to be accessed
(5024) - Required Security Module can't be activated ( only when you are using sysinternals process explorer check out this link showing SecuROM on the game Spore when using Process Explorer !!!
http://www.thearchitect.co.uk/weblog/archives/2008/09/spore_arrives_drm_copyprotection_is_a_bug_not_a_feature.html
If you try to run the program with either a copied disc or without a disc inserted you will get the disc not inserted error this which is the whole point of using SecuROM to protect Gamer Pirates but we are only interested in backing up our expensive single copy of the game.
SOLUTION - rip an image of the disc or a back-up with Alcohol52% FE using the secuROM datatype, place the image files TW08.MDS and TW08.MDF in this new folder you need to create it !!!
C:Program FilesEA SportsTiger Woods PGA TOUR 08Image
THEN - Mount the image using Daemon Tools Lite
*(Note: you can't use the DaemonTools SecuROM emulator one your virtual drive this only works with Alcohol52% datatype SecuROM rips.!!!
**(Double Note: Remember to take out your backup of the disc before you try this OK !!!!)
on Jan 07, 2010 | EA - Electronic Arts Tiger Woods PGA Tour...
Getting insert disc error
Most games require the disc to be inside the optical (DVD/CD) drive during game play..
Oct 05, 2017 | Codemasters Brian Lara International...
Please insert the FIFA 07 play disc
please insert the fifa 07 play disc in to the drive and select Retry > select cancel to quit out
Sep 26, 2012 | EA Sports FIFA 07
My 360 will let me play a little bit of a game at a time. after playing maybe 5 or ten min or so it will freeze up. the last two times that it froze up it asked me two clean the disc, or contact xbox3660...
You specify the xbox 360 do you know what year model you have? If it as earlier model then likely you are running into system instability with many reasons for the error being possible.
Does the error only appear with one particular title or across your game library?
If it is just one game then attempt to install the game onto your hard drive and play the game after that. To install the game onto your hard drive you will need to do the following:
Install Xbox 360 games on your hard drive from a game disc Note Installing an Xbox 360 game on a hard drive requires between 4 and 8 gigabytes (GB) of free disc space.
  1. Insert the game disc into the disc drive.
    Note After you insert the disc, the default option is to automatically start the game. If the game starts, exit the game, and return to the Xbox Dashboard.
  2. From the Xbox Dashboard, go to My Xbox.
  3. Select the game you want to install.
  4. Press Y on your controller.
  5. Select Install to Hard Drive.
    A progress indicator appears while your game is being installed on your hard drive.
Notes
  • Installing an Xbox 360 game might take several minutes.
  • Multidisc game? Install each disc to your hard drive.
Jul 18, 2011 | Microsoft Xbox 360 Console
I bought a dvd disc of gta san andreas but after installing it, a small window appeared "WRONG DISC INSERTED. PLEASE INSERT THE CD/DVD"... HELP ME PLEASE...
Sometimes its 2 disks, one install disk and a play disk. if you have the install disk in your computer you can't play the game. if you dont have a play disk, you can download a crack here. Good luck!
Jun 10, 2011 | Rockstar Games Grand Theft Auto: San...
My Playstation 3 wont load any games the menu shows up and i go to the GAME section and it wont show the disc. Please help. Thanks.
The most common reason for the Wii not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Wii including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your Wii going again!
Aug 20, 2010 | Sony Playstation 3 (PS3) Console
No disc inserted problem
i have installed crashday and also copied and pasted the exe file inthe place where the game has installed but still its asking to insert the cd or wrong disk inserted. please help me.
Apr 23, 2010 | Atari Crashday
My PS3 console will not play any disc which is inserted. Everything else seems to work it even shows the little disc that appears on screen, appears and spins but thats all it does.
It needs a new blu ray laser installed. If you do a search on YouTube there are lots of videos showing how to do this yourself or find someone in your area that can install a new laser.
Mar 14, 2010 | Sony Playstation 3 (PS3) Console
City Interactive 2606 Code of Honor 3: Desperate Measures Logo
174 people viewed this question
Top City Interactive Computers & Internet Experts
David Payne
David Payne
Are you a City Interactive Computer and Internet Expert? Answer questions, earn points and help others
