Question about Dryers
My Kenmore gas dryer starts running as soon as I set the timer (without pushing the SART button. And when the timer gets to (0), The buzzer sounds and won't stop until you open the door or turn the signal off. I also think that after the timer gets to (0),the timer dial is still going because the dryer was running again after I was upstairs for a couple of minutes, it was on the next cycle around the dial.
  • Dryers Master
  • 8,220 Answers
Replace the start switch, thats all it could be.
Posted on May 20, 2009
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
I have a Kenmore dryer 70 series. The buzzer won't turn off once the cycle is finished until I open the door. If I move the timer into the middle of the cycle and close the dryer, it will start again w/o...
It sounds like you have a faulty switch. The switch located behind the start button controls both the on/off setting and the buzzer. You can either replace this switch (which will likely take care of both problems) or you can take it apart and adjust the contacts. You can test them with a multimeter before and after to make sure you've got them adjusted properly.
Aug 21, 2010 | Kenmore 62602 Electric Dryer
Kenmore mod 110 87870110 gas dryer- at first push
the vent could be plugged and unit is going into thermal overheat if it works in timed dry properly then the moistier sensor is faulty.
Dec 01, 2009 | Kenmore Dryers
When I push the start button a buzz sounds and the
sounds as if the motor is not starting,try to turn tumbler manually.if tumbler turns but motor does'nt start check motor.
Oct 16, 2009 | Dryers
Starts automatically when I set the timer
This could be a problem with the start button switch (it should click when pressed/released) or with the switch on the motor.
May 20, 2009 | Dryers
Batch complete sounds when start button is pushed
door switch or timmer or the knob on the timer may not be turning the timer
Nov 27, 2008 | Maytag PYE2300AY Electric Dryer
Clothes Dryer will not stop or be quiet
On some Kenmore which is made by whirlpool, there is a resistor connected to the timer control. when the machine is off can you listen to the timer switch and hear it running, making a clock ticking sound? If so, you need a new resistor. Being a dryer, when you open the door and it stops the button needs to be reset before it starts again, right? So I wouldnt be looking at the door switch as much as the start button. It may be the evil one.
Dec 23, 2007 | Kenmore 63942 Dryer
Dryers Logo
107 people viewed this question
Top Dryers Experts
