Question about Food Processors
Need wire codes for mini chopper - Food Processors
I need to find a replacement lid for a Toastmaster 1122 mini food chopper. I believe the part # is 70645 or 70465.
just an ideah here try looking at the goodwill stores i see food choppers there all the time also maybe salvation army
Jun 15, 2014 | Toastmaster 1122 Food Processor
I need an instruction manual for a Oster Food Chopper FPSTMC3321
Oster has not made a manual for your specific model available online. The User Guide for the Oster 3320 3-Cup Chopper with With Attachment, which appears similar to your model may be of assistance. This User Guide may be downloaded here.
Jan 08, 2012 | Oster Food Processors
Wont run
I've had a similar problem. If you open up the case and examine the wiring you might find that there is a loose wire right next to the switching mechanism. Solder the wire back on and the chopper should function. I've had the similar issue, my chopper was accidentally dropped & stopped working after that. After I soldered back the short wire, chopper came back to normal operation. Hope this helps.
Feb 08, 2010 | Ultimate Chopper Food Processor
NEED TO BUY A NEW REPLACEMENT ULTIMATE CHOPPER
I did some additional web searching due to the fact that the Ultimate Chopper website or 1-800 # doesn't support this product anymore. I located a website (Maxi-Matic, USA) that has an identical Ultimate Chopper (names Super Elite Cuisine Chopper) - model EC-750 - Phone # (626) 912-9877. They have replacement parts including the clear plastic cover lid.
Oct 25, 2009 | Ultimate Chopper Food Processor
Replacement parts for the "Power Chopper blender"
same problem too!
I have my chopping blade broke, I need the new one.
please email me (mamakoi_saja_yahoo.com) where I can order one.
Jan 27, 2009 | As Seen On TV Power Chopper PC4 Food...
Cuisinart DLC-1SS Mini Prep Chopper
Here is a link to the manual
Also, this product has an 18-month warranty
http://www.cuisinart.com/share/man/69_man.pdf
-Tha Mp3 Doctor
Jul 29, 2008 | Cuisinart DLC-1SS Mini Prep 2.63 Cups Food...
Blade will not release
Our blade just came apart at the seam just above the blade, so we know what's inside. There is a small v-shaped piece of spring wire that is spread apart from the stem that is mounted to the machine. When the button is depressed (it's on a tiny spring, like a mattress spring, and that's what makes it bouncy), it spreads the v-spring wire and releases it. If you can get the seam apart, it will release the v wire and not damage the machine. Replacement blades are available on-line for $13.95, and whole machines are available on e-bay. Good luck.
Nov 16, 2007 | Ultimate Chopper Food Processor
Food Processors Logo
23 people viewed this question
Top Food Processors Experts
Ross Keen
Are you a Food Processor Expert? Answer questions, earn points and help others
