Wher do i find dialga at on pokemon diamond
Before going, make sure to stock up on lots of Ultra Balls. Also be
sure to have lots of Dusk Balls, which can be found in Pastoria City's
Pokemon Mart. The reason is that you'll soon be catching Dialga/Pakia.
In addition, you might need (Super/Max) Repels if you don't want to
encounter wild Pokemon every few steps. You'll also need a Pokemon that
knows Rock Climb. Now fly over to Oreburgh City and head east, entering
Mt. Coronet on Route 207.
Surf across the water at the north. Go up the stairs and pick up the
Protein. Climb the rocks at the very east and go up the steps. Pick up
the Max Potion at the north and also the hidden Ether on the small
piece of rock nearby. Go all the way south for an Escape Rope. Go
north, then south again. Get outside through the exit temporarily,
climb down the rocks, and pick up an Iron. Go back into the mountain
and go as far north as you can. Cross the bridge and go south for TM80
- Rock Slide. Go north for a Revive. Now head east to get to the lower
level and go inside the cave opening. Go up the steps and you'll be
surrounded by three steps on all sides. Take the one on the right for a
hidden Max Revive on the southern-most rock. Go back and go north,
where you'll battle a Galactic Grunt. Go west and pick up the hidden
Super Repel on the corner rock. Fight the Grunt and exit through the
south.
Climbing to the Peak
Now you're outside in a snowy environment. The goal now is to climb to
the top of Mt. Coronet. Go east, north, and climb the rocks. If you go
east into the cave opening, you can go straight up the steps for a
hidden Ultra Ball. Smash the rock at the bottom-left corner and pick up
the hidden PP Up on the rock that's revealed. Go outside, head west,
then south (not through the grassy area). Push the boulder out of your
way and continue west. Smash the rock along the way and pick up the
hidden Max Potion. Head north and go into the cave opening. Back
inside, go straight and climb the rocks. Battle the Galactic Grunt,
smash the rock near him, and pick up the hidden Revive. There's also a
hidden Ether on a northern rock. Go east, battle the Grunt, and go
south a bit to pick up a hidden Escape Rope. Head out again by going
east.
Go all the way north for a hidden Rare Candy on the single rock. Go
south a bit and go down the steps. Check out the cave opening to battle
some Galactic Grunts and pick up a few hidden items, including a Rare
Candy hidden in one of the rocks in the lowest level. You won't be able
to go into the cave opening blocked by the Galactic Grunt. After they
leave later, however, you may go inside to pick up TM02 - Dragon Claw.
After that, get out of this cave area.
From the outside, climb the rocks westward and head west. You'll find a
TinyMushroom hidden on a rock and a Big Mushroom on the northern-most
level. You'll soon see another cave opening, which you should enter. On
the second rock, you'll find another TinyMushroom. Keep going east and
head up the steps. Battle the Galactic Grunt and pick up the hidden Max
Potion behind her. If you go south as far as you can, you'll be able to
pick up a hidden Stardust on a rock. Fight the Grunt and head west up
the steps. As you go north from here, you'll battle one last Grunt
before finally reaching the peak of Mt. Coronet.
Spear Pillar
At the top, you'll battle two Galactic Grunts before you get to the
final challenge. Walking forward, you'll find Commander Cyrus,
Commander Mars, and Commander Jupiter all in one spot! Commander Cyrus
will summon Dialga (in Pokemon Diamond)/Palkia (in Pokemon Pearl). As
the beast comes out, you'll see some impressive animation sequences.
After Cyrus is done talking, walk forward and Commander Mars will
challenge you to a battle. Suddenly, Rival comes over and gets into
battle stance with Commander Jupiter. A challenging double battle will
ensue (challenging mainly because Rival's Pokemon doesn't seem to help
much). After defeating the two of them, Rival will heal your Pokemon
and you'll observe Dialga/Palkia forming a galaxy as instructed by
Cyrus. Luckily, the Legendary Trio will arrive to mess up his plans.
Furious, Cyrus will battle you one-on-one with some pretty powerful
Pokemon. After defeating him, the Team Galactic will leave, and
Professor Rowan and Dawn will come. Professor Rowan tells you to help
Dialga/Palkia out and the way to do that is to capture it (or defeat
it)! The time has come...
Before going for Dialga/Pearl, save your game! Also, note that you
should NOT use your Master Ball. This Pokemon is easier to capture than
other legendaries in the game. Dialga/Palkia is at lv. 47 and it's very
strong. Dialga is a Steel/Dragon-type Pokemon and Palkia is a
Water/Dragon-type Pokemon. Try to get its HP as low as possible and
throw Ultra Balls and Dusk Balls at it (while listening to the
wonderful background music). Once you have captured it, Professor Rowan
will come over to praise you on your incredible feat. Afterwards, go
all the way north to pick up either the Adamant Orb (Diamond) or
Lustrous Orb (Pearl), which powers up Dialga and Palkia, respectively.
i have the same problem... it scrolls left, right, and down... and all of a sudden it will not scroll up. you can feel the "clicks" that are supposed to be there but when scrolling up it is very smooth. i've tried cleaning & powering off & on... i really didn't want to have to take it in if there is a quick fix.
