Question about LG Prada KE850 Cellular Phone
My phone says out of battery when I try charging it or even try turning it on.
Everytime I try to charge my phone or turn it on without a charger it says out of battery
    President:
  • 1,263 Answers
When this happens most times it's because the battery will no longer take a charge or hold one, replace the battery and the problem will be solved
Posted on May 20, 2009
  • 3 Answers
Did That didnt Work
Posted on Jun 06, 2010
My lg optimus won't turn on our charge. Not even when I installed a new battery. What's wrong?
The Optimus S cannot be charged without the phone coming on. In order to restore that battery to where it can be charged within the phone, it needs to be plugged into an external battery charger. Once it is "topped up" to a nominal charge, the standard charger will be able to charge the battery.
A relatively cheap wall wart charger can fix this issue
May 28, 2015 | LG Cell Phones
I have a problem getting my phone on. i have a motorola electricify. it wont turn on even when i try to reset it hold the volume down button. it wont do a thing. it wont charge. everytime i plug the c
Kyle
let it set on the charger for a couple hours without attempting to turn it on. See if the battery icon appears.
If that doesn't work you can try MOTOROLA ELECTRIFY Master Reset Factory Data Reset
Mark
Motorola Support
Sep 14, 2014 | Motorola Mobility MB853 Electrify US...
The screen on my phone went completely black and will no longer turn on from what iv tried i cant hear or seen anything and there is no sighn of water damage what do i do?
I will try and keep this short. I have a Motorola Razr (puchased in the USA..... this will make sense later) and I lend it to my brother when he visits me from Canada. (Roaming charges for Canadians using their phone in the US is insane) He too has a Motarola phone that he brought with him. The Charger that he brought with him was for a Canadian phone. Apparently, you cannot use a charge for a Canadian phone, on a USA contracted phone..... I'm not sure why, but it is the case. He attempted to charge my USA phone with his Canadian Charger and the screen went blank. The phone was still on and could even receive calls. Even when the calls came in, the screen still remained blank. I won't bore you with any more details.
Here is how I fixed it:
- Unplug phone from Canadian Charger
- Take the battery out of the phone.
- Plug in USA built charger (without the battery in the phone)
- The phone attempt to charge
- Screen should turn on. Wait till screen indicates (Cannot charge battery)
- Plug battery in.
- Hold down power button to turn on the phone.
- Phone should be in working order.
I don't claim to be an expert. This may only apply to my particular situation. Hope it helps if you happen to use the incorrect charger. Take care.
Mar 22, 2011 | Motorola Mobility RAZR V3
My phone want turn on even when its been charged
Try this:
Try charging your phone, see if the battery is charging or not. If it is, try turning on the phone. once opened, remove it from the charger, if it goes off, then the battery is broken.
If you connect your phone and it is not charging, there problem lies on the charger or connector of the phone/charger. Try using other charger, if it works, the problem is you old charger.
Try using other battery then open it, if it does turns on, your old battery is broken.
Thanks.
regards,
longgee
Dec 27, 2010 | Motorola Mobility Clutch i465 Cell Phone
My K810i phone doesnt turn on..
let it sit in the charger for 1hour then try to turn on your phone. it could be that the charger cannot charge the battery and turn on the phone at the same time and the battery is too weak to turn it on and needs a better charge.
Nov 11, 2009 | Sony Ericsson K810i Blue Smartphone
My iphone 2g wont turn on, i replaced the lcd, it worked ok, my batter was low. so it died and i was trying to turn it on, but it wont turn on. when i plug in the wall charger nothing happens,but when i...
I have a feeling that when you ran the battery down it is now struggling to get and hold a charge.
If you have a friend with a similar battery perhaps try that, or go to a mobile store and ask them to try a new battery for you.
Nov 09, 2009 | Apple iPhone 3G
Won't Charge or Turn on
First try drying out your phone for a day or two with lots of dry moving air gently blowing past and around it, the phone must be unplugged and battery removed during this process, then once everything has been dried try charging the battery in another phone just like it, if it charges and see it it will power the phone, if the battery works put t back into your phone and try to turn it on. If it doesn't work in your phone but it does in another then its the phone, if the phone works with another battery its the battery but dry them both totally first, even a few tiny specs of moisture can screw up your phone when power is running through it, so be careful. Cheers!
Mar 02, 2008 | Motorola Mobility RAZR V3
Nokia 6010 won't turn on
I have nokia 6010, seems to be having similar problem. Tmobile trouble shoot suggests battery contacts, or battery charger, or battery itself as problems. Even better check this out. might help. Oh. might be battery, plug in the charger, battery must have a small amount of charge to turn on, say 10 min. then try to turn on. See if it's charging.
Jan 18, 2008 | Nokia 6010
LG Prada KE850 Cellular Phone Logo
200 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
