Question about Lifespan Exercise & Fitness
I have E06b coming up on my lifespan chief treadmill.Can you tell me how to reset the treadmill by useing the console. thanks,Brenden
2 Suggested Answers
Unlucky320
  • 176 Answers
SOURCE: Can anybody tell that where can I get Johnson t7000 treadmill upper console ,thanks
Here's the service manual: Which is always helpful: http://img.trimdax.se/pdf/92-2200.pdf
Also you can always try Amazon.com or Ebay.com .... Be sure to find exact part number. Then you can always put that part number into your search engine and it should tell you what options are available.
Posted on Sep 02, 2015
T700 treadmill console not working. Plugged in & worked; reached 3mph & removed safety magnet. Console went black; won't come on. Power switch lights up; lower board led light shows power on.
The treadmill will not run if you remove the safety magnet. Replace the safety magnet and reset the treadmill. Should start working again.
Thanks.
Aug 15, 2016 | Exercise & Fitness
I have a TS01 Newfittness treadmill and the dashboard is not working properley the slow button s not working and stop and start not working anyone has any ideas
Hi, I had a problem with my lifespan treadmill and had to replace the electronic console display, I bought the console display from a store that sells lifespan treadmills and paid $100.00...All the best with it....
Apr 05, 2016 | Exercise & Fitness
Lifespan TR 1200i Treadmill Theres a creaking noise coming from inside the main covered (engine) compartment when I walk fast and run. I've taken the cover off and can't figure out what is causing the...
The LifeSpan TR1200i Treadmill can have a little bit of flex in the frame when being used on wood floors or carpet. With the large plastic hood tightened down securely, the flexing causes squeaks. Further tightening can cause unwanted deformation of the hood leading to breakage. The cure is to loosen the 4 screws that bind the hood to the frame until the hood is sitting on the screws without binding. The weight and size of the hood will keep it in place.
Mar 12, 2015 | Lifespan Exercise & Fitness
Where is the reset button on the lifespan treadmill TR1200i?
follow the power cord till it goes inside the treadmill. the reset should be nearby
Sep 01, 2014 | Exercise & Fitness
DC-6 error on Lifespan Treadmill
Follow attached link to see user manual.
Unplug treadmill.
On page 13 of the users manual, read step 5 part B regarding the wiring harness. Unplug and plug back in each of the connectors of the wiring harness. Plug the treadmill back in to see if it now works. https://s3.amazonaws.com/lifespanfitness/pdf/Manual_TR4000i.pdf
Jul 30, 2014 | Lifespan Fitness TR4000i Folding Treadmill
Lifespan Pro3 - treadmill E1 error message
Hello
yes, your correct this could be the lower board with the issue.
The lower board could have blown a fuse, which you can check and replace quite easily. If the fuse is good look for other burnt spots on the board. The lower board may need repairing/replacing.
If the machine stopped while in use (after about 10min) then you will have a few other problems to check. Try adding silicone spray under the belt and if this has already been done then the running belt may need replacing.
E1 is never a good thing...
gymWorld.net.au
Jan 10, 2014 | LifeSpan Fitness Lifespan PRO3 -Treadmill-...
Lifespan treadmill has a dC-1 code
Reset the error follow the steps. God bless you
    • 1 Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
    • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
Mar 25, 2013 | Lifespan TR800-DT Treadmill Desk
E6 error code on lifespan tr200 treadmill
please proceed according and fix it. God bless you
trouble +cause+ solution
E6 Faulty Safety key Check Safety key or switch
Elv. Motor not moving Check Elv. Motor
connections
Elv. Motor screw binding Clean screw, lubricate or
remove obstruction
Elv. Motor out of range Check motor zero position
Elv. Potentiometer Calibrate elevat ion motor
Jan 20, 2013 | LifeSpan Fitness TR200 FoldNStor Compact...
I have got E06 error in Lifespan Treadmill.
I have read that the speed sensor near the front flying wheel connected the front roller, sometimes get malfunction. I have just tapped it gently with a screwdriver and this seems to have done the trick. Hope this will help somebody with a similar situation.
Else
Call Vision Fitness Customer Service, they'll help you reset the treadmill by using the console. This will help clear the problem. I've been told that this error occurs when the incline controls are not used often. I've cleared the error using their instructions but after several months it does reoccur. And no I don't use the incline option often so that might explain it
Oct 01, 2012 | Lifespan Exercise & Fitness
Exercise & Fitness Logo
Top Lifespan Exercise & Fitness Experts
Shehu Pro
Shehu Pro
Mike
Mike
Electro Med Services...
Are you a Lifespan Exercise and Fitnes Expert? Answer questions, earn points and help others
