Question about HP Officejet 5610 All-In-One InkJet Printer
Print Cartridge Problem
I have a HP OfficeJet J4550 All-In-One printer. I am unable to print as I get a message "Print Cartridge problem : [TriColor]. Refer to device documentation to troubleshoot. The cartridge is an original HP cartridge and his not empty. It has never been refilled.
  • 68 Answers
Wipe the cartridge using cotton.Clean also the wiper inside.
Posted on May 20, 2009
How to set print alignment in hp officejet K7100
During cartridge alignment, the error message 'Print cartridge alignment failed' displays on the printer control panel....
More Info visit this links...
Print cartridge alignment failed Error Message Displays on the All in...
Alignment Page Does Not Print
Thanks,
HP Printer Support
Jun 26, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
My printer display says: "print cartridge problem [black] reefer to device documentation to troubleshoot." What do I do, I can;t get my printer to print. I just bought new ink, so the cartridge can't be...
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Oct 26, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet J4550- "Print Cartridge Problem"
the official solution, which probably won't work since you did most if not all of it already: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01818839&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=3645097#N636
the unofficial solution, which will be more likely to work: http://www.land.netonecom.net/tlp/ref/letters/hpPrinters.php
perhaps the worst thing about HP is that they do not even mention the chip timeouts in their troubleshooting instructions.
Jul 13, 2009 | HP Officejet J4680 InkJet Printer
Printer will not print
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab71
Jun 25, 2009 | HP Officejet 5610 All-In-One InkJet...
Just stoped printing;print cartridge problem
Remove print catrige and clean it with cotton cloth then refix it.
May 19, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Print cartridge problem : [Tri- color]
Printer display says: Print cartridge problem : [Tri-Color]. Refer to device documentation to troubleshoot. I can find nothing in the 'device documentation' to help me.
Apr 03, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP Officejet J4550 All -in-one printer has print cartridge error
To answer the Apr 4th guy, what i did was shake the cartridge. You know how when you were a kid and a gameboy game didn't work and you had to blow inside of the machine. Its kind of like that.
Mar 25, 2009 | Office Equipment & Supplies
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
HP Officejet 5610 All-In-One InkJet Printer Logo
391 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
