Question about Dell E153FP 15" LCD Monitor
Monitor blinks when trying to reboot
If the monitor has been sitting idle for 20-30 minutes, it will start blinking if you try to move the mouse and use the computer. The current solution that has been used is tapping the monitor on it's side until it "recovers" and stops blinking(it is not my monitor). This sometimes takes quite a few taps, but ones it comes back on, it works like new. There are no noises or signs other than this that the monitor is malfunctioning.
Will I be able to fix this problem or is it best to just by a new monitor?
  • 472 Answers
Re: monitor blinks when trying to reboot
A common fault with this monitor is both bad capacitors and also dry joints, both will cause your problem.
Both faults are easy to correct if you have basic electronic knowledge, but if not, would be best left in the hands of your local technician.
Voltages inside of these monitors can kill and for the cost of the repair it's hardly worth risking your life.
If you choose to see a tech, then please just advise him of what I have said. It should give him the impression you know what you are talking about and stop him ripping you off.
Posted on Apr 08, 2008
0 characters
3 Points
At the desk top, I moved the mouse to begin and the screen went black. All it gives is a blinking orange light. Pressing the switch doesn't matter. Upon rebooting , blinking light persists while you can...
Sounds as though you have a backlight issue. How old is the monitor?
The keyhole with the lock sign is for a security lock to lock the monitor to a desk so it cannot be stolen.
Mar 08, 2011 | Acer AL1916W 19" LCD Monitor
Samsung 22inch lcd monitor goes blank after 1min idle system.
disable all power management options in your system BIOS
May 13, 2010 | Acer X193W LCD Monitor
Hello sir, I have samsung 22in lcd monitor and nvidea fx5500 card. since last more than 6 months, my monitor goes blank If system remains idle (means I don't move mouse and don't touch keyboard) for 1 minute. After monitor goes blank I have to move mouse to brink it back to on. The power led keep on during this problem. I tried everything including power options in windows but could not fix it. Is it bios setting to be checked or could it be windows bug? Please help
Mar 23, 2010 | Acer X193W LCD Monitor
My hp vs19d power button blinks on and off slowly. what does it mean? if i let the computer sit for say 3 hours the monitor will stay blank. even after moving the mouse to wake things up
the monitor is in sleep mode ... have you tried hitting the keyboard Space bar?
if you disconnect the video cable from the pc does it display ( video disconnected) ? if it does it then is probably the sleep issue
Oct 06, 2009 | Computer Monitors
Monitor looks as if there is no CPU
If the power supply is coming to CPU before activation of CPU then it must be receiving current from UPS. Don't try unplugging, You may get shock. Thank you, Sir.
Sep 17, 2009 | Computer Monitors
My Gateway monitor FPO 1975W is blinking?
Hi there, it sounds like this monitor is going out on you. Try a different monitor if you can, see if that fixes the problem!
Apr 06, 2009 | Gateway FPD1975W 19" LCD Monitor
Sceptre LCD monitor blank screen, blinking power light
Something has failed or is failing in the monitor. It may be serviceable, but may not be cost effective to do so unless something has just come loose. I'm assuming you have no problems with the new monitor. Your time line is a little confusing.
Dec 13, 2008 | Sceptre Dragon Eye D219A (White) 21 in.CRT...
No picture; power LED blinking amber/green 2-2-2-2...
You can TRY to look for cold solder at the board esp popwer section.
Apr 24, 2008 | NEC AccuSync 120 (White) 21" CRT Monitor
Dell E153FP 15" LCD Monitor Logo
Top Dell Computer Monitors Experts
Brian Sullivan
Brian Sullivan
William Miller
William Miller
Are you a Dell Computer Monitor Expert? Answer questions, earn points and help others
