Question about Panasonic KX-T7630 Corded Phone
How do you save numbers for one touch dialling?
I want to save a phone number for one touch dialling, can someone please tell me how you do this?
  • Panasonic Master
  • 2,460 Answers
Press PROG the button and dial 2 + 9 + the number and STORE.
If your outside line access code is something different, insert it instead of "9".
carl
Posted on May 20, 2009
How do you put speed dialing in a samsung GT-C3520
To Set speed dial numbers do the following:
1. In Menu mode, select Phonebook.
2. Select a contact to assign.
3. Select More -> Add to speed dial.
4. Select a number (if necessary).
5. Select a speed dial number you want to set.
The contact is saved to the speed dial number.
Note:
• You can call this contact by touching and
holding the assigned speed dial number in
the dialling screen.
• The first 3 speed dial numbers will be
assigned to the top 3 list on the widget toolbar.
May 16, 2014 | Samsung GT-C3520 Unlocked Quad-Band GSM...
Tip
Ericsson CODES DESCRIPTIONS
*#06# For checking the International Mobile Equipment Identity (IMEI Number)
Shortcuts:
Save a Missed Call into your phone directory Scroll to "Missed Call", press "Yes" to display the required number. Press any number (i.e. 0 to 9), then press "clear" once to clear that number, then press & hold "<" until you see "Store". Press "Yes"
Hide your number when calling when you don't want the other party to know your number) After dialling the required number & before pressing "Yes", press ">" twice to choose "Hide Id?" & then press "Yes". Also works for pre-programmed & last dialled numbers just press "No" & wait for the number to appear on the screen first then follow same procedure
Check you battery level when phone is off Press "No" quickly one time & wait for the battery meter to show up!
Save a number into your phone memory (not SIM card) Follow normal procedures to store a phone number. When prompted to set a storage position, press "#" once & key in desired location, or press "#" twice for next available position
Call a phone number from SMS message You can call from within a SMS message if the phone number is written in it. Just scroll the message until the phone number appears on the display, then press "Yes" to call
on Aug 30, 2009 | Nokia 9500 Communicator
Nokia e 52 does not save log
Try deleting files from phone memory......goodluck
Jun 01, 2012 | Nokia E52 Smartphone
Nokia C6-01 How do I delete single dialled or received calls from the Log? I can delete from the dialled screen but the call remains in the Log.
Hello Sinyoro,
In the Call Log eg. Dialed Numbers, highlight the number/contact you want to delete, press "Option" and then select "Delete", this will delete only the selected entry. Make sure you don't press the "Delete All".
Hope this helps.
Thanks.
Jan 01, 2018 | Cell Phones
My samsung phone.. model 3850 is my phone password.. I forgot the password because of my sun...he change the phone password. Can't you help my problem???
Dear,
if your mobile gets on, then try dialling *2767*3855# in your dialling screen, it will hard reset your mobile, deleting all your mobile internal data like multimedia, virus, password etc.
so remember before dialling this number, backup all your data.
regards!
Aug 17, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Pls tell me how can I see the time i talked in my phone? how can i see the time of all talking? and where can i see how mch sms did i send and accept? pls tell me! THANK YOU!! I got nokia n8
To see your call durations on a Nokia phone.
  • Press Menu
  • Press Log, which is a green and blue arrow
That will get you into recent calls,,,,,,,,Missed, Received and Dialled calls.
Scroll down to Call Duration which will give you total time for , Last call, Dialled numbers, Received calls, and All calls.
SMS, go to Messaging
  • Inbox tells you how many sms received
  • scroll down to Sent messages to show how many sms sent.
But that depends on your settings on your phone, go to,
  • Messaging
  • Options
  • Scroll to Settings
  • Scroll to Other
  • From there you can change Number of saved sent messages you can store.
I hope this was helpful
MobileJB
Jul 13, 2011 | Nokia N8 Cell Phone
How do I programme the memory on an answercall sp100 phone?
1. Pick up handset OR press 'handsfree' and wait for dialling tone.
2. Press 'store'.
3. Dial number you wish to put in the memory.
4. Either press 'M1', 'M2' or 'M3' to save as one touch speed dial numbers OR press 'store' again and then press any number between 0 - 9 to save two touch speed dial.
5. Replace handset and you're done.
In future if you wish to dial a one touch number then so long as you remember which button you ascribed to it you can do so with M1, M2 or M3. If it was a two touch number then you will need to press 'memory' followed by whatever number you ascribed between 0 - 9.
Hope this helps!
D. Nisbet
Sep 12, 2010 | Cell Phones
Storing speed dial numbers?
To Set: Do not lift handset, Press FNC button
Press the desired “One Touch” Key
Enter number to be stored (remember”0” for external numbers), Press FNC button to save
To Dial Lift Handset, Press desired One Touch key
Jun 26, 2009 | NEC ETJ 16DD-1 Corded Phone (necetj16dd-1)
Listing contacts
to list a contact the easy way just type the number it and press options and it will display save go from there
if some one called and u missed it when the screen shows one missed call it should show the number if not it was private u can also go in to call log and go to dialled calls.recived calls.and missed calls and will show u the numbers
Jun 28, 2008 | Nokia 6288 Cellular Phone
One touch dial or speed dialling.
Hi Menu => Contacts =>Speed dials. Good luck.
Aug 28, 2007 | Nokia 1100
Panasonic KX-T7630 Corded Phone Logo
174 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
