Question about Microwave Ovens
Microwave will not start after timer is set. Cannot set the time of day either
Cannot set the time. The cook time can be set with dial but will not start. Only 1 month old
  • 90 Answers
Take it back to supplier under guarantee.
Posted on May 20, 2009
It not cooling
If you're talking about a microwave oven:
[1] plug the mains cord in to the wall socket
[2] switch the socket on
[3] put food to cook on glass turntable, never use empty oven.
[4] close oven door fully until it clicks
[5] set the power
[6] press 'start' or turn the timer-dial,depending on your model.
It will start to cook immediately.
The humming sound is the energy heating the food in timed bursts of power.
If nothing happens or it won't cook, post clear description of fault with problem, make, model.
Hope this helps,
Clive.
Oct 19, 2017 | Microwave Ovens
How do I turn on the microwave and set the clock
well setting the clock comes first if my memory is right
Jan 14, 2016 | Microwave Ovens
Microwave stops after 59 seconds
Check that a "favourite" setting has not been selected. The unit may think that is the time that you want to cook. Im not sure about your model but see if there is any clear or cancel buttons to clear any pre programmed selections. If not, unplug the machine for 15 minutes to reset the controller and try it again.
Nov 25, 2013 | Electrolux Microwave Ovens
Timer button not working as it should
The only way to fix the problem is to replace the timer mechanism, the hard part is finding one, and maybe on the pricey side. Try www.ebay.com type make and model of microwave oven, and scroll through the list.
Jun 04, 2012 | Microwave Ovens
I am having difficulty setting the clock on my Baumatic BAF9006 90cm dual fuel cooking theatre can you please help
HELLO.
Setting your microwave clock is explained below.
It is a standard 12-hour clock (12:00-11:59) and does not show a.m.or p.m.
The microwave oven and timer must be put off.
  1. Touch Clock.
  2. Touch the number pads to set the time of day.
  3. Touch Clock or Start.
Thanks.
Sep 21, 2011 | Microwave Ovens
I have a GE sensor microwave oven. Tried to heat food and sensor eror came on. Everything is running even the timer but no sound but the timer is running. Cant this be reset pls help
HELLO.
This is the solution to reset your microwave.
1 Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
1. Set the clock by pressing the "Clock" button.
2. Turning the dial on the GE sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
3. Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the GE sensor microwave oven.
4. When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
5. Press the "Start" button to allow the clock to begin on the GE sensor microwave oven.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Setting the clock
hello,
simple to fix up your self please follow this instruction below
  1. Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
  2. Step 2 Set the clock by pressing the "Clock" button.
  3. Step 3 Turning the dial on the sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
  4. Step 4 Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the sensor microwave oven.
  5. Step 5 When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
  6. Step 6 Press the "Start" button to allow the clock to begin on the sensor microwave oven.
thank you for using fixya.
Jul 31, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Even though timer starts the microwave doesn't start cooking
read this post
Parts:
magnetron: W10131681
HV capacitor: 815124
HV diode: W10201950
HV transformer: 8171873
Of note: generic parts are cheaper and will work as well.
Oct 20, 2009 | Whirlpool GH7155XHS Microwave Oven
We have this old Radarange Amana MICROWAVE from the 70's and dont quite know how to use it.
Normally the dials are the timer for cooking time plus cooking power level dial, for defrost, medium, high, etc.
It may also have a start button to start it cooking. If not, then you place the food inside, shut the door, then rotate the timer dial to however many minutes you want.
If this does not answer your question, maybe you can take a photo of the controller and post it.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 04, 2008 | Amana Microwave Ovens
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
Microwave Ovens Logo
65 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
