Question about Electrolux Washing Machines
My electrolux front loading washing machine says no water during the clen tub? cycle only, then water pours down the front of the machine
Durning the "Clean Tub?" Cycle, the washer starts to beep with only 3 min. remaining for the cycle to finish. I have to cancel the "Clean Tub" cycle, then re-start the washer on "Hand Wash" cycle, in order to rinse all remainging bleach residue from the washer. Why does it only beep and say "No Water" during the "Clean Tub" cycle. On all other cycles, normal, hand wash, delicate, heavy duty, and casual cycles. These are the ones I use. I do not know how the washer would preform on Sanitize, whites, colors or fast wash, because I don't use those cycles. I have read about possible clogging of filters or hose screen, but it seems if that were the problem, the washer would indicate "No Water" on the other cycles, not only when I am performing the "Clean Tub", ( or System Clean Cycle, as referred to in the manuel). Any guess as to what is going on? Is there a different action involved, with 3 min. Remaining on the " Clean Tub" cycle, than normally used to fill washer with water, for all other cycles mentioned above, that I use?
SOURCE: GE Front Load Washer
Removing the lower front panel (3 screws nearest floor), and opening the round, white water pump filter cap (be ready to catch about 2 gallons of water!) is the best place to start. All you need is a Phillips head screwdriver and a large, flat pan (deep turkey tray works well)!
YOU WILL NOT BELIEVE what I found in my filter housing this morning (see photo below)!
The washer is working fine now, although I may go back and remove the entire water pump so it can be dismantled, thoroughly cleaned, and reinstalled.
Posted on Sep 22, 2008
  • 61 Answers
SOURCE: water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Posted on Jan 20, 2009
jumptrout51
  • 3361 Answers
SOURCE: amana washer only works on delicate cycle
Open the control panel. Unplug the timer and then plug it back in good and firm.
If it does not work correctly after that,
Replace your timer.
Posted on Mar 12, 2009
SOURCE: washing machine will not advance through the wash cycle
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
Posted on Aug 12, 2009
tomsat69
  • 219 Answers
SOURCE: My new electrolux front loader is not filling with
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
Posted on May 18, 2010
Wash machine quits mid cycle
Your Circuit Control Board is starting to Fail.... The Electrical Reset is the give away....
Mar 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
I was getting the F H error code on my washer. I hit cancel twice to clear the code to see of a cycle restart would remedy. Now the wash cycle is stuck on 45 min. remaining & the cancel button is no...
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code.
  • 1 Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3 Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • Apr 29, 2013 | Washing Machines
    My Bosch dishwasher is driving me crazy! When it finishes a wash cycle it beeps twice every 10 minutes until the door is opened. We can't run the dishwasher at night after dinner unless we're SURE we...
    Hello there,
    It would help to know the model number of the dishwasher, but on many Bosch dishwashers, you can switch the cycle cycle completion signal off as follows:
    1. While holding the right-hand CANCEL/DRAIN button, also press and hold the ON/OFF button
    2. When the LED above the CANCEL/DRAIN button illuminates and the beeping starts, release both buttons
    3. Press the right CANCEL/DRAIN button repeatedly until the beeping tone is at the desired volume, i.e. silent!
    4. Press the "ON/OFF" button again to set the volume.
    On models with the wash cycle buttons on the top edge of the door, the CANCEL/DRAIN buttons aren't always explicitly labelled CANCEL/DRAIN. These buttons are also labelled RESET on some models.
    On models with 3 and 4 wash cycle buttons, the right CANCEL/DRAIN button is the third button when reading from left to right. On models with 5 wash cycle buttons, the right CANCEL/DRAIN button is the fourth button when reading from left to right.
    Please try the above then let me know if you need further assistance. Please state the model number or series (i.e. Integra) of your washer if/when replying.
    Hope this helps.
    Regards,
    BElectric
    Mar 16, 2011 | Bosch Dishwashers
    Finished Clean Washer cycle and my bleach dispenser full
    It's normal for all washers with a sanitize or tub clean cycle to leave diluted bleach in the dispenser
    Feb 11, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
    Need to reset washer it is stuck in mid cycle and wont continue nor start over
    doesnt this model have the cancel button by the start button.......if so........switch on then hold cancel for 10 seconds...........
    cheers
    Jul 24, 2017 | GE WBVH6240F Front Load Washer
    Reset wash cycle
    Changing Cycles, Options and Modifiers
    Not all Options and Modifiers are available with all cycles. Cycles,
    Options and Modifiers can be changed anytime before HOLD TO
    START is selected.
    Options and Modifiers can be changed anytime after HOLD TO
    START is selected and before the start of the selected Option or
    Modifier.
    To cancel a cycle and select a new cycle
    1.
    Select PAUSE/CANCEL twice.
    2. Select desired cycle.
    3. Select the desired OPTIONS.
    4. Select HOLD TO START (for approximately 1 second) to
    restart the washer at the beginning of the new cycle.
    To cancel a cycle
    1.
    2. The washer powers down, the door unlocks, and clothes can
    be removed.
    NOTE: If the water level or the temperature is too high, the
    washer will drain automatically before the door unlocks.
    To change Options or Modifiers after the cycle has started
    1.
    Select PAUSE/CANCEL.
    2. Select the desired OPTIONS or MODIFIERS.
    3. Select HOLD TO START (for approximately 1 second) to
    continue the cycle.
    To drain the washer manually
    1.
    2. Select DRAIN/SPIN.
    begin the drain.
    4. When the spin is complete, the door unlocks. Items can be
    removed from the washer.
    Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Estimated time 2minutes blinking with an "F" what does this mean?
    Are you certain its not blinking F 02 I have a similar problem and the only way I can get it to finish is to hit pause and let it sit overnight befor hitting start again, I cleaned out all the huses and the pump filter which were a mess wet lint and change respectivly, This helped (now I get one load done before it stops)
    Mar 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
    Whirlpool DWF B00 W
    Raise temperature of your water supply. Open door and press hi-temp srub,then energy saver, then reapeat this within 3 seconds. Close door and hit cancell.
    Jun 02, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
    Washing Machines Logo
    421 people viewed this question
    Top Electrolux Washing Machines Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
