Question about Refrigerators
CyberCool 320L Three Door Under Bench Drinks Bar Fridge manual
Manual
Sanyo refrigerator showcase spasmodically freezes up
The temperature controller is erratic and should be replaced.
Sep 10, 2016 | Sanyo Refrigerators
Where is the power converter located in a 2007 forest river Cherokee camper
Look for breaker panel, usually a brown cover/door. Under fridge, on end of bench seat, or under, even the washroom on wall is used now. If all else fails, turn on all lights (12V) and listen for a small fan to come on. That's the converter cooling fan that usually comes on when you add load.
Feb 27, 2015 | RVs
2011 Melbourne Jayco Circuit Brakers
Any more they could be in numerous places but look for a brown cover/door usually. Look low, such as under fridge, under bench seats, as well as on wall in bathroom, bedrooms etc.
Feb 25, 2015 | Jayco 2011 Melbourne 29C
What are chocolate bar drinks?
Chocolate bar drinks just use certain chocolate bars such as mars or snickers as the base of their drinks, which often involve melting the bars down and adding milk etc.
Feb 25, 2013 | Wine & Spirits
I have a lemair RS250S fridge only have had it for awhile lost manual need to know which way to turn dial to turn it colder.Please
Hi, From what I can see from my manual, 6 is the coldest temp and 0 is off. We have just had ours on 4.5 and the diet drinks have exploded. So I suggest that you keep it under 4.
HTH
Dec 30, 2010 | Refrigerators
My Frigidaire refrigerator side by side is freezing drinks.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 22, 2009 | Frigidaire FRS26H5AS Side by Side...
I have an admiral GC2224GEKB
You may have to open the door to let the dispenser thaw since it's in the door.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 03, 2009 | Refrigerators
Refrigerator - freezing drinks
I think you have already found your fault. The t/stat is the culprit here. You have already used the correct trick to establish the fault.
Aug 17, 2017 | Refrigerators
Refrigerators Logo
144 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
