Question about Epson Stylus® C64 InkJet Printer
Printer cartridge I have had my printer cartridges refilled, when i put them back in, the screen on the printer displayed, "Remove and check"
  • 121 Answers
You should always go with new,refilled cartridges can cause many problems.A lot of times when they refill they damage the circuit film which carries all the signals to the pc baord.
Posted on Oct 18, 2007
SOURCE:
My printer says to remove and check color cartridge...so i did and i clean it and put it back but it still says to remove and yeahh....what do i do???
Have you refilled your cartridge?
Which part did you clean it?
If you did, gentely wipe out the cartridge circuit part with Q-tip (with bit of alcohol).
And wipe out the circuit part in the printer where cartridge goes in as well.
And try back.
Sometimes by having some dust or bit of ink make cartridge unreadable.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 04, 2011 | HP PSC 1610 All-In-One InkJet Printer
Had printer cartridge refilled but when i put it back in the messege says incompatible ink cartridge-black
I would never use refilled ink. This is a lesson. You can still print, yet the cartridge needs a new "chip" they should have given you when they refilled it. You can try: remove the cart. turn off printer, unplug it, then put old cart back in. Do this three or four times and the memory of the printer can only remember three or four resets and then put refilled cart in. Hope this works for you. I was told this for an HP 7130 (similar, yet older version).
Brock
Sep 16, 2010 | HP 8500 Premier All-In-One InkJet Printer
Refilled cartridges
the pixma range need to have the chips reset or refilled before they become empty.
Put in a genuine cartridge and it should work. Buy a set of cartridges with dummy chips that allow the printer to use refilled cartridges.
Please rate my help++++Thanks for using FIXYA
Jun 03, 2010 | Canon PIXMA MP180 All-In-One InkJet...
Tri colour problembought to refilled cartridges one displays problem other table, is it the refilled cartridges or the printerwrong cartridge 344 not compar
Hello!
When the printer tells you "wrong cartridge", it is because it cannot recognize the cartridge.
Remove the color cartridge and gently wipe the electric contacts on it with a dry cloth. Put the cartridge back in and check for error messages.
If the problem persists, you will need to buy a new color cartridge, because the one you have is damaged- one of the contacts on it has blown, and when you place it in the printer, it won't recognize it, because one of the contacts is missing (that is why some printers give a warning sign "cartridge missing").
Hope that helps!
May 30, 2010 | HP PhotoSmart C4180 All-in-One Color...
It reads REMOVE AND CHECK COLOR CARTRIGE I just
Go back to Costco, tell them the cartridge doesn't work now they've refilled it and request your money back.
Put the refund to a propriety HP cartridge.
I've had this issue. not with refills but with generic copies, some work, some don't work. That's getting towards what HP wanted when they started chipping their cartridges.
Apr 26, 2010 | HP PSC 2355 All-In-One InkJet Printer
Canon mpc190s imageclass printer error wrong cartridge
Try to remove all ink cartridges, then remove the print head, clean the contacts on carriage with piece of cotton and little alcohol then put all back again.If this not help replace the print head.It's part number is QY6-0037-000.
Oct 05, 2009 | Canon SmartBase MPC400 All-In-One InkJet...
Message on screen says ink cartridge problem remove and check cartridge - but cartridge is fine
remove the cartridge clean the gold contact on the back with alcohol and a q tip
Aug 31, 2009 | Office Equipment & Supplies
Printer cannot find new black cartridge. Left cartridge missing.
The electronics are bad on your compatible and your printer can't recognize it's there. Return this cartridge and get your money back. The next cartridge you buy, ask if the electronics have been tested to be functional. I recommend refils from Cartridge World or Office Depot.
Apr 05, 2009 | Lexmark X4530 InkJet Printer
Check black cartridge message
This happens if you refilled the cartridges, and forgot to take out the air..
Follow this steps..
1. Switch on the printer, open cartridge bay, remove cartridge, dont close the cartridge holder flaps, directly unplug the power supply from the printer end.
2. take a soft cotton, lint free cloth, slightly swab it with pure water, wring the cloth so any excess water is removed, and clean the contact pins inside the printer cartridge holder..
3. clean the cartridge head by keeping it in hot water (about 50C) and then wiping it clean, keep it upright for a few min, and when both printer and cartridge is completly dry put it back in, voila it should not display the message now...
Sep 25, 2007 | HP OfficeJet V40 All-In-One InkJet Printer
Remove and check colour cartridge HP 23, HpPSC500 error
Did you trying cleaning the cartridge contacts on your machine?
Jun 23, 2007 | HP PSC 500 All-In-One Printer
Epson Stylus® C64 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
