Question about Vornado (CR1-0073-06) Fan
Need 2 replacement knobs for my 2 Fans
Replacement knobs
Where can I purchase a replacement fan switch knob
What is the make/model of fan? What's a switch knob. Do you have a picture? fanman9952@aol.com
Aug 27, 2014 | Dryers
Temperature control keeps going down. Replaced the Temperature probe, replaced axial fans. Contactor works but cant get no power from board to close contactor. This second board I have replaced.
In a cold oven the resistance of the temp probe should be approx 10k ohms. If the control has the control knob separate from the control board, as in a separate potentiometer then I would suspect that as the problem. You shouldn't lose 2 control boards in a short amount of time.
Sep 25, 2013 | Blodgett ZEPHAIRE E DBL Double-Deck...
I have a Maxi Heat OH-107C. The knob to turn it down and off just broke. Where can I get a replacement?
King of Fans Ltd, Ft Lauderdale, Florida, (800-330-3287) is the manufacturer/distributor of your heater. They should be able to help you with a replacement knob.
Apr 08, 2011 | Heating & Cooling
I have 2 Hunter ceiling fans and the wall switch has 2 knobs which you push to click on or off.......after you click on...you can turn the knob and increase or decrease the fan speed. You can click on both...
Hello .. you should be able to find a replacement for your fan control at any building supply store, a home depot type store. Look or ask for a variable speed fan control. This is slightly different from a normal liight dimmer . You might also look for a replacement knob before replacing the whole switch, or matbe getting a replacement just to replace the knob ..
Jun 18, 2010 | Hunter Ceiling Fan Control Switch
Replacement Blade Knob for Duracraft Table Fan Model No.DFT-218W
I thought the same thing. It was hiding in one of the stryfoam pieces.
May 01, 2009 | Duracraft DFT-218W Table Fan
Moved refrig. and compressor will not kick in
The unit may have gone into the defrost cycle. The fans and compressor will be off during the defrost cycle. Has the unit been plugged in for more than 30 minutes since you noticed it stopped? If so, you will see a round plastic knob recessed about 8" back in the console on the fresh food ceiling. Rotate this knob clockwise with a flat blade screw driver until a distintive click, louder than the tiny clicks made while rotating the knob. If the fans and compressor come on, replace the timer (68233-3).
If the fans and compressor do not come on after rotating the timer, you may have a bad cold control of loose wire in one of the molex connectors from the move.
Apr 29, 2009 | Refrigerators
Fan switch
I would go to an ACE hardware or any other hardware store, bring in the old knob if you had it to find another that would match the shaft which it connects to, another place might be Radio Shack.
Jun 19, 2008 | Patton Electric U2-20 Box Fan
Vornado (CR1-0073-06) Fan Logo
51 people viewed this question
Top Vornado Dryers Experts
Dusty Ryan
Level 1 Expert
Mack Baxter
Bill Boyd
Are you a Vornado Dryer Expert? Answer questions, earn points and help others
