Question about ASUS K42F A1 Notebook
Base system device manager - ASUS K42F A1 Notebook
Where can i get base system device drivers for my machine
This will be the official support site for your model
http://support.toshiba.com/support/modelHome?freeText=2059342
base system drivers could be related with chipset, rapid storage, HDD protection. make sure you update all your drivers
Oct 16, 2014 | Toshiba Satellite A305D-S6848 Notebook
Base system decive
when you get a base system device in the other devices category in device manager it usually means that either the chipset drive has not been installed or a lot of the time it's the sd card reader driver.
Nov 05, 2013 | ASUS K52F Notebook
I am having difficulty obtaining drivers O 3000 N100 OS XP Base System Device PCI bus 5, device 6, function 2 Base System Device PCI bus 5, device 6, function 3 Base System Device...
Base System Device drivers are usually installed by what the manufacturer calls "Chipset" drivers. If you are running Windows XP, there is an Intel Chipset driver available at the Lenovo Support Page for your model. If you are running an Operating System other than Windows XP, I would go to the above page and compare the drivers listed there with what you are seeing in Device Manager. Install the ones that are missing. Hope this helps!
Mar 09, 2011 | Lenovo 3000 N100 Notebook
Installing web cam on ubuntu system
installing a logitech web cam on ubuntu linux based system
Apr 24, 2010 | Logitech Webcam
Base system device
Thank you to all that have replied to my query, and for your time. However, i have now solved this problem, it was the drivers for the sd card reader and now everything is back up and running..
Happy computing everyone. Tony.
Jun 11, 2009 | HP Compaq nc6000 Notebook
Base system device and network controller driver error in device manager at win XP
"Base System Device" is your card reader, I had the same problem. If you dont use it jst disable the device, otherwise the drivers should be on your alienware Master CD, if not get a tech support guy to send 'em to you.
May 25, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Dell Inspiron 710m PC Notebook Problem
Go to "Device Manager" and look if any yellow or red alerts are being displayed next to any devices. To access the "Device Manager" go to the 'Control Panel", "Administrative Tools", "Computer Management" and select "Device Manager" located in the left side column.
If there is an alert, double click on that device to determine the problem, i.e.… device not configured, cannot start this device, etc…
It sounds like all your software drivers got blown away or can’t load. If that’s the case, try running diagnostics. Press and hold the <Fn> key while powering the system on. This will initiate a diagnostic routine to check your hardware.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 31, 2008 | Dell Inspiron 710m Notebook
I need drivers for laptop sps 1210
all Drivers for your computer can be found here
u most look what u already got what not
If it helped rate fixya
Aug 03, 2008 | Dell Inspiron 9100 XPS Latitude D400...
ASUS K42F A1 Notebook Logo
24 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
